Question about Bosch Drills
Weak power from my bosch 11224vsr hamer drill
jeff_drakesr
  • 155 Answers
SOURCE: Bosch 11224VSR
Must use an SDS style bit.
INSERTING:
Clean the insert shank end of the accessory to remove any debris, then lightly grease with a light oil or lubricant Insert accessory into the tool holder through the dust shield, while twisting and pushing inward until it locks automatically into place. Pull outward on the accessory to be certain it is locked into the tool holder.
REMOVING:
To remove an accessory, pull and hold locking sleeve backward and pull bit forward. All accessories should be wiped clean after removing.
Please rate this answer of it's helpfulness. Good Luck and have a great day. Jeff
Posted on Apr 04, 2010
comax
  • 154 Answers
SOURCE: i have a bosch hamer
The kit you are looking for is what Bosch calls a service pak the P/N 1617000430. It comes with all the o-rings, brushes and oil to do a complete overhaul. Go to Boschtool.com and look under "find a service center" then find one in your area.
Posted on Jan 14, 2011
  • 14 Answers
SOURCE: hammer action power there but weak
Bosch makes a special grease that is actually a mulit-viscosity oil thats a gel at room temp. At high temp it becomes liquid oil that lubes the gearcase and when the tool has cooled off it reverts back to a gel for containment purposes. If you use any other type of grease on these tools it will appear as if it is losing power, when it is actually being "bogged" down by conventional grease. The proper grease is Bosch part# 1 615 430 001-000. Retail price should be around $20 for a 225ml tube.
Posted on Mar 01, 2011
  • 885 Answers
SOURCE: Bosch 11224VSR drills and hammers but not both. Makes loud stripping noise.
If both functions, hammering & drilling, work correctly on their own but not together your selector knob may be the issue. On the back of the knob is a driver pin that moves the necessary parts to make your tool drill, hammer, or both. If it isn't moving those parts to the exact right place, one or more of the functions may not work. Try moving the selector halfway between positions and see if the gun hammer-drills. If it does you have problems with the selector or drive pin. If it still does not you may have internal parts problems that can only be diagnosed by working on the tool with the knowledge of how it works and how everything inside should be.
Posted on Apr 20, 2012
jeffpetree
  • 36 Answers
SOURCE: Hammer function does not work on Bosch 11224vsr
Its usually a problem with the selector knob... depress the button fully and turn it passed the selection markings and pull it out to remove it
Posted on Dec 09, 2012
What type of oil for bosch 11224vsr rotary hammer drill
special grease is used not oil order number 1 615 430 001 is the right grease for it
Apr 08, 2013 | Bosch SDS-plus BULLDOG Xtreme Rotary...
How do I remove the striker pin on bosch 11224VSR
If you mean the front striker pin you will need to remove the circlip up inside the spindle. You can see it through the two little holes just above the spring.
Nov 06, 2012 | Bosch 1" Sds+ Bulldog Rotary Hammer Drill...
Aug 29, 2012 | Bosch Factory - Reconditioned 7/8" SDS -...
Apr 19, 2012 | Bosch Drills
I have a bosch hamer drill 11241 and i am looking for a repair kits or some parts. becouse the hamer is not working. the drill works ok i live in toronto canada
Jan 09, 2011 | Bosch 11240 1-9/16" SDS Max Combination...
Bosch 11224VSR how to change bit
INSERTING:
REMOVING:
Apr 03, 2010 | Bosch Drills
Hammer action power there but weak
It is hard to understand what you are asking, however I have found that with the SDS drills one does NOT want to crowd them but just let the tool work with light pressure...
Feb 07, 2010 | Bosch SDS-plus BULLDOG Xtreme Rotary...
After drilling a hole with a 14" long 1" bit...the drill ceased to work...I've also had the same problem with 2 other drills(both bosch), where one of the 2 doesn't work on hammer anymore because the...
need to check the hamer piston. also if your switch is going out are you useing a long cored (yellow) need a cored rated no less than 15amp 50'. to long burns the switches out ever time. let me know I'll check my manuels. good luck
Oct 12, 2009 | Drills
Hammer drill quit
If it is an 1199, forget it. Replace the brushes and do NOT use for hammering. It is a design problem. My unit was repaired 4 times and hammered about 5 holes each time before same failure.
Jul 02, 2009 | Bosch 1617014127 Brush Set For 11224vsr
Drills Logo
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
