Question about Canon EOS 30D Body Only Digital Camera
I'm getting a thick blak line from the bottom of the picture horizontally when I take a picture with my canon 30D shutter speed 400 upwards. the line gets higher and higher till at 2000 it covers
    Sergeant:
  • 321 Answers
Use Digital lens its form only when u use manual lens
Posted on Jan 10, 2013
jackboy
  • 2985 Answers
SOURCE: PICTURES FROM CANON A430 POWERSHOOT APPEARS BLURRED AND HAVE HORIZONTAL LINES
Yjis is a component fault.
Contact Canon you may qualify for a free replacement.
Posted on Dec 22, 2007
pishta68
  • 593 Answers
SOURCE: grainy pictures
grainy pictures are possibly casued by a very high ISO (sensativity) setting, you should be on 100 or lower for best normal shots. Higher settings are for low light and custom shooting in strange lighting or aperature/shutter speeds. Try full auto setting.
Posted on Mar 03, 2008
  • 153 Answers
SOURCE: i have error 99 in my camera canon 400d
Error 99 is a general fatal error.
which includes the problems above mentioned by Q4SteveB but also many others.
It can be caused by a dicky shutter, problems with the CF card interface.
If cleaning and trying a different lens has not worked. Not definitive but as a rule of thumb...
If it letting you take one picture then giving error 99.. and the picture is saved to the card (but may just be black) this is most likely the shutter needs replacing..
If it takes a picture and gives error 99 but there is no picture on the card or the picture is 0KB its a CF interface problem.
If you get an error 99 when you plug in the USB its a USB interface error, you can try a different cable but unfortunately in most cases if another lens or cable wont work it needs repair
Posted on Jun 04, 2008
  • 51 Answers
SOURCE: Error 99 on 30D Canon
Had this problem before and i found this guide online
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Posted on Jan 30, 2009
SOURCE: Canon A80 camera-red tint and horozontlal lines on pictures
I had the same thing happen to me last November. Canon has a recall of sorts on a wide range of older cameras. Apparently there is an issue with the sensor. Canon will fix the camera free under this recall program.
Here is a writeup of my experience with Canon's customer support (good):
http://atinkerersmusings.blogspot.com/2009/03/repair-canon-digital-camera-ccd.html
and a direct link to Canon's site
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Posted on Apr 16, 2009
Nixon S8100 fairly new camera, nice pics if the subject doesnt move but horrible pictures if object moves. Very blurry.
If everything in the picture is blurry, you are moving the camera when you press the shutter button. If only the subject is blurry and the background is clear the problem is too slow shutter speed. If this is cause by movement of the camera you must learn to SQUEESE the button while being sure you don't move the camera. It just takes a little practice. If this problem caused by a shutter speed that is too slow, it is remedied by increasing the ISO "film" speed. Even though you have no film, the camera has a "speed" setting that relates to that. The higher ISO value increases the camera's sensitivity to light and thus allows for faster shutter speed. Normally the ISO choices are 100, 200, 400, 800, 1600. Try using 400. The ISO setting is in one of your camera menus. 400 is fast enough to solve your problem in all but very fast movement of either the camera or subject. Using ISO above 400 will cause your pictures to look grainy and not as sharp. Use the highest speed only when absolutely necessary. Slower ISO numbers produce the finest grain and thus the sharpest pictures. It a trade off between ISO and shutter speed because the exposure is a combination of the ISO and shutter speed and lens opening. Each one effects the exposure by half or double.
Apr 16, 2011 | Nikon Cameras
Can't control shutter speed
Well you can get the Canon Battery Grip For EOS-40D/30D/20D Model# BG-E2N, which has a separate set of controls including the wheel. OEM is about $170 Chinese clones $80. The camera body will probably sell for about $200 as is on eBay.
Nov 17, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Eos Rebel SLR (non-digital) takes blurry grainy indoor pictures, even with flash, even when I put a lot of lights on. I use Fujifilm 400. I have used my 300mm telephoto and my regular short lens,...
Sounds like the shutter is making long exsposure and you are actuallly getting blur- this can even happen with flash if the shutter stay open too  long.  without film, look in viewfinder and see what shutter speed the cmaer awants to use- it may be set incorrectly and is set on manual shutter speed- the shutter speed numners are actually the bottm part of a fraction, so 30 is 1/30th of a second- to prevent blur you want the numbers to be 60 or higher.
Aug 23, 2009 | Canon Photography
Pictures are very over exposed with many white horizontal lines through them. Solution?
Hi!
The lens shutter cable is broken or the shutter blades are stuck - happens when lens get wet or something adhesive gets in the lens. It's a hardware problem so I'm afraid you will have to give it away for a repair. I must warn you that it is considered a complicated repair, so it could be expensive.
Hope this helps!
Tom
Jul 29, 2009 | Canon PowerShot S1 IS Digital Camera
Horizontal Lines throughout the images
What Canon technician told you that your camera did not have a CCD? You sure that he was from Canon? And also the cost of repair would likely be more than the latest A480. Also note that you can get an A470 for around $70 these days. But no this is likely not CCD failure and is more likely a stuck shutter.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Note that the article says to set your camera to 15 second exposure. This is not possible with the A430. Instead set it to manual mode, turn the flash off, and go into a darkened room. Take your picture there. Open the door while the red and yellow lights are flashing. Now the possibility for success with this method is not that great so don't get your hopes up. But it's worth a try before shopping around for a new camera.
May 30, 2009 | Canon PowerShot A430 Digital Camera
Black line across top of all my developed pictures
You have light leak somewhere to the film.
Usually from the bad film door seal.
Mar 29, 2009 | Canon EOS Rebel GII with 35-80 lens 35mm...
Canon Power shot S21S
if you have a book for your camera you need to read the menu,it will help you on the issue of shutter speed and light. bottom line is the faster the motion the faster the shutter speed with respect to lighting conditions. hope this help you soom jerry
Sep 18, 2008 | Canon PowerShot A75 Digital Camera
Help black line on bottom of picture.
After a bit of experimenting, I have found a solution that works in my case. The problem was the shutter speed. At 1/200 I got the black line on the bottom of my pictures, but when I tried it at or below 1/100 it was gone. Hope this helps.
Jun 15, 2008 | Nikon D50 Digital Camera
Canon sd 550 (and sd 200) shutter speed
If you check out a review site such as www.steves digi cams. com or even the Canon site to check out the spec of the camera to discover what shutter speeds are available. When shooting fast moving subjects try panning the camera on the object as you press the release this will[to a degree] keep the primary image sharp[ish] whilst blurring the background
Feb 26, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Shutter speed
You can get much information from the EIXF file generated by the camera with each picture. i think you right click on the picture and select properties. Ed
Aug 31, 2005 | Canon PowerShot S400 / IXUS 400 Digital...
Canon EOS 30D Body Only Digital Camera Logo
80 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
