Question about Acer Aspire Computers & Internet
My laptop makes loud beeping noise and screen comes up all fuzzy & crazy
When i turn on my laptop the screen comes up all purple and pink fuzzy and its acts likes ifs going haywire, then a very loud beeping noise starts, and does stop until i turn it off?? any ideas
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 114 Answers
Sounds like hard drive is bad, replace with new or buy new computer
Posted on Apr 18, 2013
  • 205 Answers
SOURCE: Beeping noise and blank screen
The beeps are part of the POST (Power On Self-Test). Here's a link to the Lenovo site that might help you interpret the beeps you're hearing:
http://www-307.ibm.com/pc/support/site.wss/MIGR-46018.html
Good luck.
Posted on Nov 19, 2007
StuntJay20
  • 24 Answers
SOURCE: My laptop beeps everytime I try to turn it on and it makes a beeping noise.
Try removing the laptops battery for 1 minute & putting it back in. That should fix the issue.
Posted on Mar 19, 2008
bob_computer
  • 3153 Answers
SOURCE: Loud beeping noise when trying to turn laptop on
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes P
c
More beep codes
Power up the pc and see if the fans are working.
Posted on Nov 07, 2009
RescueTechLA
  • 2653 Answers
SOURCE: When I open my laptop the screen becomes green and
Your lcd cable has a short. You just need to replace it. Every laptop is pretty much the same.
Here's a general guide for what to expect.
Posted on Nov 23, 2009
ICmanServer
  • 129 Answers
SOURCE: Tiny laptop. Loud constant beep during start up, will not start.
This problem is commonly happen form the memory or RAM. At this time you need to check the memory. Remove the memory and turn it on identify in there is sound provided. This could be a problem with the system memory, an expansion card, or the motherboard.
Try to use another RAM or use the another memory slot. Clean the RAM and also the memory slot.
ICman
Posted on Dec 23, 2009
Compaq laptop green pink screen pixalted
One of the things is to hook it to another monitor and see if that still happens. If it does not then it is most likely the screen on the laptop. Not to worry though it could be the cable that connects the laptop motherboard to the screen. When you open and close the lid, it flexes the cable and the little wires in can break. The cable is not cheap though. One way to test this is to change how far the lid opens by flexing it open and closed to see if the screen changes. If it does then it is that cable.
Jan 19, 2014 | Compaq Computers & Internet
Tablet wont turn on
Blue means that your system is not charging, when it is charging it should be pink/purple. when the battery is full it will turn blue. If the blue/pink light stay on it may mean that your battery is no longer charging completely. If it is still under warranty, get a replacement battery for free... otherwise it may be time to invest in a new battery.
Jan 16, 2014 | Computers & Internet
HDMI input doesn't work
replace Main PCB (it has the I/O ports & circuitry on it)
Nov 26, 2013 | Bush Televison & Video
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
The screen has a picture but it is green purple & pink & a little fuzzy,channels turn fine sounds of seems to be a tuning problem is this worth fixing or time to throw out tv is 3 years old
hi
This is not a tuner problem . The blue color is missing and the cause is the main board if you are handy with tools you could find the part#
printed on he board and find it on ebay
Sep 29, 2010 | Emerson EWL3706 37 in. LCD Television
My display is pink & fuzzy.
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 12, 2009 | Dell Computers & Internet
When turning on the xbox the screen turns pink
OK did you ever try to hack your system did you open the inside of it did you drop or smash it or leave it in extreme temps if not it might be the result of poor cable connection,first turn off your Xbox 360 and check out the cables that are connected to the system. Remove them and re-connect them firmly. Now switch on your Xbox 360 again. There is a good possibility that you will find the fuzzy purple screen gone. If you still find a fuzzy purple screen then this might be a bit more complicated problem that your system is experiencing. Usually system overheating is one of the major reasons that cause various Xbox 360 errors
May 05, 2009 | Microsoft Xbox 360 Console
Pink & fuzzy bottom screen
I have a new screen that I will put in it for $24.
ninja_freak318@hotmail.com
Dec 13, 2008 | Nintendo DS Lite Console
My Big Screen making a loud beeping noise!
The beeping noise is usually related to the Horizontal out put transistor or flyback being faulty or one of the coils are loose near the flyback. If you remove the rear cover without touching anything can you tell if the beeping is coming from the large transformer with the red wire coming out of the top or is it coming from a black transistor on a aluminum heat sink.
Jul 22, 2008 | RCA P52930BL 52" Rear Projection...
Computers & Internet Logo
138 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
