Question about Canon Realis SX50 Multimedia Projector
Canon sx 50 projector won't turn on and warning light is flashing
Replaced bulb and projector wouldn't stay on for more than 10-15 minutes before shutting off and "warning" light flashing. Eventually it stayed on and we watched several movies and football games where is was on for over 4 hours consecutively. Two weeks later it shut off again after just 10 minutes of play and now will not turn on at all. "Warning" light just keeps flashing. I have already made sure the light bulb door is closed all the way. (This is what was listed in the manual as a potential solution)
5 Suggested Answers
Noggin
  • 944 Answers
SOURCE: canon lv5210 projector
This link allows you to download the manual. if you need it; http://www.usa.canon.com/app/pdf/projector/lv7215_7210_5210_manual.pdf page 41 especially worth a look page 43 gives all details for lamp replacement if you still think is the problem. Almost certainly the problem is to do with overheating - which is either a bulb problem or a malfunctioning fan. See if the fan runs when you turn it on and check it is clear. Hope this helps :)
Posted on Mar 15, 2007
mandeville
SOURCE: Canon LCD Projector LV-S3
It sounds like the bulb is either blown or not properly seated.
Posted on Jul 28, 2008
SOURCE: Warning light stays solid on
The same problem as mine, is there a Canon technical support to help us fix this problem.
Posted on Aug 05, 2008
heatman101
  • 43501 Answers
SOURCE: after some time warning light
The machine is getting too hot...
Used canned air like you would use on a computer keyboard to blow the dust and dirt out of the projector
heatman101
Posted on Jun 19, 2011
Sharp projector Bulb replaced but still won't work?
check the ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Nov 08, 2012 | Sharp Projector Lamp For Xv-z90 Xv-z90e...
Canon LV-S1 projector keeps shutting down after a minute or less
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Jul 15, 2012 | Canon LV-LP12 Projector Lamp for LV-S1,...
Optoma HD66 replaced lamp, LAMP WARNING light keeps flashing, still won't turn on?
i just had the same problem i took the top of the projector off and cleaned the color wheel and sensor seemed to have fixed the problem that is for now. seems to happen to me once a year on the dot but last time it was warranty. good luck hope it helps.
Mar 17, 2012 | Optoma Office Equipment & Supplies
I have a sony and it uses the KDF-E60.i turned the tv on then after like 5 min. the tv turned blank and the sound turned off and a while after the screen came back on and then the sound came back on.i ask...
so this is a projector , if the unit is turning off and giving led signal error like green flashing, your bulb needs a replacement. its a warning that it has nearly end of his lamp life. dust and poor ventilation can shorten the lamp life. its a good idea to clean the blower and ventilation inside the projector.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
Keeps going to double red light shuts down, then it resets and turns on for 5 minutes and then turns off again, what could be the issue? thanks
I've seen this happen almost exactly on a Canon projector. The problem was the bulb. After the bulb was replaced the problem went away.
Please remember to rate this solution to show your appreciation!
Jun 01, 2011 | Epson PowerLite 7900P Multimedia Projector
Sharp xvz-10000 projector.\r\nI replaced the lamp and RESET the timer and projector worked fine. Now about 2 months later I have to unplug to reset the unit and when turning on the first blue light stays...
Have a nice day!
Jerry
Lampdeng Limited
Nov 18, 2010 | Sharp BQCXVZ100001 Projector Lamp for...
Dell 2300mp projector
check this out...
http://www.ihatedell.net/forum/phpBB2/viewtopic,p,36316.html
have almost the same problem. lamp light turned on-->replaced the bulb, now when you turn it on tryies to boot and then the lamp light is on again (but the bulb is brand new).... and no light at all coming out of thing... I guess dell just don't know how to built projectors right way.... and theirs tech support guys are.... they just don't know about projectors more then manual
Jun 20, 2008 | Dell 2300MP Multimedia Projector
Cinego d-1000 starts with picture and then shuts down
the warning doesn't come on all projectors. Replace the bulb anyway!
Jan 26, 2008 | Radio Shack Cinego D-1000 Multimedia...
Canon Realis SX50 Multimedia Projector Logo
old marine
old marine
