Question about Samsung N145-JP01US Netbook
MY Samsung 32" LCD TV Screen broken ,Can I connect My monitor having same pixels but 20"to the main board of TV ,using monitor back light circuit & TV flat strip connection to LCD Panel.
Samsung LA32C350D1 ,Screen broken.with a res. 1366*768 pixel.I want to use my Monitor 20" with same res 1366*768 with this TV.Power supply no problem,I want to use Back light circuit of the monitor & video or data connection from the main board of the TV,My question is ,is data cable to LCD of Monitor & TV main board is compatible.
PcExpert
  • 293 Answers
SOURCE: Problem with Samsung SyncMaster 150 N
The LCD's backlight may be damaged.
Posted on Sep 18, 2007
hokuwho
  • 306 Answers
SOURCE: easynote r1004 d.c. input socket broken
You really have to completely remove the motherboard from the case to do this. If you cannot find the exact replacement jack (not called socket in parts catalogues) you can just run the wires out of the case to whatever jack that will accomodate your adaptor. If you do not have the remove/replace procedures and still want to tackle this then make sure that you keep track of where EACH screw goes as they do vary in size/threads and pay careful attention to the ribbon connectors that connect to the keyboard, display and touchpad. The bottom of the laptop has little icons that relate to what the screw releases (like a keyboard icon) and even the screw designations molded into the bottom case. If this is a maiden voyage into laptop repair then research or you will learn the hard way. An ESD strap is essential here and all drives/battery/PC modules removed. Good luck. ~Steve
Posted on Oct 19, 2008
Fix-4U
  • 293 Answers
SOURCE: I have power, but no picture
Hi...there,
Seems your lucks just run out....you've got a busted backlight inverter. It's time for a upgrade...
Posted on Nov 21, 2008
  • 12 Answers
SOURCE: i want to connect my samsung NC10 laptop to my TV
has the tv got pc/vga in ? also doseur pc have s/vid out
Posted on May 18, 2009
jmgldsmth
  • 2005 Answers
SOURCE: Samsung NC10 LCD screen has a "broken glass" look
sorry but, the screen is gone
Posted on Sep 06, 2009
POLAROID P40LCD12 SCREEN AT BOTTOM COMES ON BLUE FADES THEN GOES GREEN ABOUT 5 INCHES LOST ON BOTTOM TV WORKS OK BUT THE SCREENS STARTS BLUE ABOUT 5 INCHES FROM BOTTOM THAT FADES AND TOP HALF PIC OK BUT...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 02, 2017 | Polaroid Televison & Video
Why does my TCL tv stay dimmed and very dark screen? I've reset it and everything?
Apr 30, 2017 | Televison & Video
Tv is dim and can't brighten
Apr 28, 2017 | Televison & Video
I have a VIZIO 60 inch tv with problems on the screen, the right side does not see the image and on the left side if, who can ?? it has a solution??
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board...
Apr 26, 2017 | Vizio Televison & Video
I have an LG 47LN522-UB LED TV that stopped working after three years and need help diagnosing a problem with it.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 26, 2017 | LG Televison & Video
I have an Element tv that has no picture, good sound but basicaly a black screen. Do i need a didgital board or a main board?
Apr 26, 2017 | Element Televison & Video
I have a lg55la6200 led/lcd smart TV. When I turn it on it stays on for about 15mins and then the screen turns off but sound still on. I have done the flashlight test and can see the picture.
Apr 22, 2017 | Televison & Video
Samsung UN55EH6000 has audio, but no backlight LED as seen with flashlight test.
http://electro-medical.blogspot.com/
Feb 29, 2016 | Samsung Electronics UN55EH6000 - 55in...
Samsung 32" LCD TV with picture problems. Only the bottom of the screen has picture.
Jun 03, 2017 | Panasonic TC-20LA2D 20 in. LCD Television
Vertical line and shadowing on samsung 32"lcd tv
Clean the connectors from the main to the Tcon along with the flat cables that go to the panel, next would be repalce the tcon board,if that doesn't fix it you may have a bad panel
Dec 28, 2017 | Samsung 32 in. LCD Monitor TV
Samsung N145-JP01US Netbook Logo
81 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
