Question about HP Officejet 4620 All in One - CZ152AB1H
4620 claims paper jam is stopping cartridge
Cannot get any more info on screen
SOURCE: deskjet F380 printer unable to print
Hi
Seems to be problem in sensors for that you need to open the printer and clean the sensor, If you are not expert in that then please check service centres for servicing.
Boopathy.T
Posted on Aug 17, 2008
yooperbud
  • 8637 Answers
SOURCE: HP laserjet 5000N - Paper jam under the cartridge every time try to print
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 29, 2009
SOURCE: hp j3680 printer claims paper jam after ink
most probable cause is cartridges inserted incorrectly causing carriage jam while printing
Posted on Aug 04, 2009
Arachneo1215
SOURCE: paper jam but i removed all the paper
Ohh, I had this same situation. What you have to do is disconnect everything. Ok, after that, connect the USB port on another port slot. Then connect the power cord. after that, your PC will say found new hardware, etc... Then go to Start, Control Panel, Add or Remove Programs all the way at the top. Then what you must do is uninstall every component of your printer. Then shut your computer down ( to allow it to process the info). Then install it again with the CD of installation. If you don't have the CD, google the name of your printer with the words installation. Then try printing another Document not the one you were trying to. After that cancel the printing. Finally, just print the document you want, and Viola!
Posted on Aug 28, 2009
  • 59 Answers
SOURCE: hp printer c 5180 paper jam stopped the ink
>follow the steps on this link
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=17133&lc=en&dlc=en&cc=us&lang=en&product=1153481
Posted on Sep 25, 2009
Printhead stops and message claims there is an obstruction, but nothing there.
Make sure the ink cartridges are fully seated. Also, check for paper jams in the front (remove paper tray), and the back.
Jul 19, 2014 | Lexmark Pro901 All-In-One Inkjet Printer
I have two HP Printers - desktop 3522 and Officejet 4620 - paper jams all the time! What is my problem?
i think you are not using proper paper, try some other type of paper like diffrent grams, havy paper is better
Jan 10, 2013 | HP Computers & Internet
Blurred officejet 4620 photo
Have you checked to be sure that -
  • you've designated the paper type as one of the photo type papers?
  • you've designated the print quality as either Normal or Best (NOT Draft or Quick or similar low-quality print)?
  • you're using one of the photo-type papers?
  • none of the ink cartridges is low on ink?
Sep 17, 2012 | HP Officejet 4620 All in One - CZ152AB1H
Check paper error persists despite no paper in feeder or paper jam. cannot use auto document feeder due to this error. can i reset the sensor or do something else to clear the error?
I had one of these printers claiming there was a paper jam, when there wasn't. As others have suggested, three hard slaps above the paper tray, and hey presto, it works.(This seems to be the resolution to all problems. It will probably refill the cartridge too ... hmmm)
Feb 16, 2011 | Canon imageCLASS MF6550 All-In-One Laser...
Our printer is not picking up the paper from the tray and is saying it is jammed. There is not jam.
Hi there !
Is your printer had jammed before and it stop printing in the middle of printing? For some reasons, paper can jammed due to printing interruptions, printer turn off, improper loading or feeding of paper, roller feeder had problem and others.
If jams before and paper have let inside the printer, please do the following first:
1. Check th paper tray, see inside if the paper is jammed inside that compartment. If there is paper jammed, remove, turn off your printer and turn on. This will solve your problem.
2. If not, open the printer cartridge door, remove the toner cartridge and look for paper jammed inside. If these is paper inside, remove it, turn off the printer and turn it on.
3. If you cannot see the paper jammed inside, the paper maybe inside the heating area. To remove paper, just turn off your printer and turn it on to roll over the paper jammed inside of it.
4. If the printer is blinking and saying there is paper jammed. You have to check the cartridge toner by opening the cartridge door, remove the cartridge and return it back but be sure it is well firmly fitted.
If following the 4 diagnostic procedure and you cannot locate the jammed paper, the problem lies on the toner cartridge itself. When toner cartridge is not rolling over, it will stop feeding the paper and it will cause printer to jammed.
To diagnose the problem, put old printer cartridge and if no toner power, just shake it well and I am sure there is still small amount of powder inside it and if it prints, the toner cartridge you purchase is defective. Reason, factory defect or improper refilling and part is not working well.
I hope it is helpful and thank you for using FixYa !
Jan 06, 2011 | HP LaserJet P3005n Printer
Paper jam
It seems that the sensor lever is pressed somewhere in the printer ..
Remove all the papers out of the printer .
Remove the cartridge
Open the front and with the help of air blower - blow some air and clean it ..
there might be a paper particle causing the problem .. (DUST)
Jan 07, 2010 | Epson CX8400 All-In-One InkJet Printer
Have a BROTHER HL2140. Paper jam: Can't remove drum unit & toner cartridge: Help
Solved by opening the front and removed paper: not required to remove cartridge. Info on Problems with Printers. Thank You
Nov 08, 2009 | Brother HL 2140 Laser Printer
Hp j3680 printer claims paper jam after ink cartridges put and attemptto run test sheet.What should I do?
Aug 04, 2009 | HP J3680 Officejet All In One Printer
Samsung SF5100 has a loud buzzing noise
Hi there you might have a faulty toner cartridge is it a original or has it been refilled? I suggest to install a new toner cartridge and hopefully that will cure the fault. If this dosen't there maybe a small piece of paper stuck in the cartridge or after the toner cartridge within the heat section open the back of the machine (the jam door) and check there is no paper.
If the printed document is getting stuck just after the toner cartridge it will most likely to be the heat section will need replacing.
Hope this helps you and please rate me
Thanks J
Dec 31, 2007 | Samsung SF-5100 Plain Paper Laser Fax
MP810 paper jam
I bought a brand new canon with my first pc years ago and it was the first and last ia m afraid, it worked for two...yes two...print jobs, i had it a wee k then it just stopped and said a jam, but it turned out to be the paer sensor. Brand new and they had to swap it. Seems a big fault with these. However, the next one seemed to be ok, but i had occasional cartridge issues. I have never had an ounce of trouble with my lexmark apart from alittle toddler paperjam!!!
Oct 05, 2007 | Canon PIXMA MP810 All-In-One InkJet...
HP Officejet 4620 All in One - CZ152AB1H Logo
18 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
