Question about Dell Computers & Internet
I have a dvd+r stuck in my delldesktop tower
The tower tray closes half way and the dvd dropped off the tray how can I get it out?
  • 54 Answers
Shutdown the computer. There should be a small hole (tiny pinhole) on the front panel of the DVD player. Unravel a paper clip and insert it into the hole. Keep pressing and it will manually eject the DVD player tray. Hopefully you'll be able to get access to the DVD and remove it.
Posted on Jan 09, 2013
My CD tray will not close after removing a fragmented disc that got stuck
You have damaged the CD loader tray, best thing to do is just replace it, they are not repaired.
Jul 15, 2017 | Dell (0R649) CD-RW Burner
My CD tray will not after removing a fragmented disc that got stuck
It sounds as if there is either still some obstruction within the CD tray mechanism or path, or else the CD drive itself has failed and should be replaced.
I would recommend replacing the CD drive, especially if it has already caused one CD to break into fragments.
Replacing a CD drive should be reasonably easy if you have a tower computer and are happy to open the case.
Depending on the design, there are normally only 2 screws on each side of an optical drive and 2 cables on the rear to disconnect (3 cables if you have a direct sound connection from the drive to the motherboard).
Some case may have a quick release method for removing the optical drive. You should consider replacing the CD drive with a combination CD R/W DVD drive unless you already have a second DVD drive installed.
Jan 17, 2012 | HP Computers & Internet
I need to get a dvd out of the tray
Don't! first of all make sure that the dvd didn't tear into pieces, if teared then nothing to do, buy a new DVD Drive, if not you would notice a little hole in the front of it, try with a pin into that hole and push it, the tray have to come out, then everything will have to work as normal.
Jan 10, 2012 | HEWLETT-PACKARD Pavilion Slimline s5510f...
My DVD tray on my Yamaha DV C6480 (it holds 5 DVDs) got stuck in the half open half closed position. It may have come off the track. I opened the case and reinstalled the DVD Tray. Now the tray...
This happens to us all the time. Here is the note I keep on how to fix it quickly:
When tray gets messed up, the drive wheel (with pegs that interlock with pegs on the tray) needs to be such that the tray slides in and out freely. Push tray all the way in. Turn on.
Hope that gives a hint.
Nov 04, 2010 | Yamaha DV-C6480 Multi-disc DVD Player
DVD tray stuck in the closed position
Is it jammed?
Still has a CD/DVD still in it?
Is so try cycling the power to see if it will kick it out.
Otherwise it's most likely a hardware problem like a bad tray motor, broken gear, or perhaps a bad/stuck switch on the tray assembly.
If it's still under warranty, call the manufacture technical or customer support for a possible replacement.
Jul 20, 2010 | iLO DVDR04
My ACER tower DVD disk tray is stuck.
Considering the low price of a DVD drive, I would just replace it. It sounds like the tray has been bashed, maybe by a leg or object dropped on it?
The emergency hole is likely on the side of the drive inside the case. If you have no experience changing a DVD drive, ask a friend for help. DVD drive installation is covered on the web. It is pretty easy. Just unplug the power first!
Apr 02, 2010 | Microsoft Windows Vista Home Premium with...
DVD stuck in player
make sure that the dvd is unplugged from the outlet and remove the screws of the cover, you should be able to access the dvd from inside the player without the cover on.
I hope this helps
Jun 28, 2009 | RCA DRC225N
DVD Tray stuck open
the tray is not catching (underneath the tray is ridges). unplug the dvd player from the wall for 5-10 min...plug back up and give the tray a lite push while tapping the open/close button
Jun 17, 2009 | Yamaha DVD-C920 Multi-disc DVD Player
The Dvd's door keeps opening and closing
Did you drop the dvd player or bump it at all? if not there is a small object stuck in the tray housing(more than likely) also see if the tray is off kilter especially if it's closing then opening. It's really hard to tell w/out seeing it but that's probably what's wrong.
Aug 27, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
