Question about Toys
Fixing an old wind up toy
The spring has broken this old wind up toy. I have taken the toy apart and removed the old broken spring and now need a replacement and perhaps a clue as to how to remove the key without wrecking the tin the holds the movement.
SOURCE: replace rubber seal on my zanussi washing maching
the only way to fit door rubber to tub on a zanussi is to use washing up liquid it takes two mins
Posted on Apr 06, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Broken torsion spring needs to be replaced
There are indeed two springs that "cross" each other, and they must be both be replaced to ensure full strength.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 25, 2008
c17hydro
  • 2984 Answers
SOURCE: How to remove and replace the wiper blades on a 2006 BMW 325i.
My suggestion....go to Schuck's/Kragen?Chief's?Auto Zone....they will install them for FREE.
Posted on Mar 11, 2009
SOURCE: replacing funnel/funnel frame on LG fridge model # LRSC26944TT
I am a year too late to help this person but also recently had to replace Funnel Frame on my LG Fridge model # LRSC26925SW. Literally just finished so sharing a quick tip. Not sure if it's same on all models but worth an easy shot. Tried the screw driver thing with no luck as it was just digging into the plastic even at the one little tab hole at bottom of the Frame... So instead, I stood to left of Fridge and cupped my hands around the edge of the door and into the left side of the curved part of the bezel (more towards the bottom) and simply pulled towards me and out away from door (almost like clamping my grip tighter) and the bottom portion popped open with enough gap to work the rest off gently by hand. Pull out from the bottom first and then slide the assembly down to release the top. Once you replace the funnel frame and are ready to reassemble, work the top of the Bezel with the display in first and slide upwards, you'll know when it's in the right place and then snap the remaining three sides a little at a time with the side of your hand (firmly if necessary). It didn't break any clips in case you are wondering... they are designed to release and clamp in that fashion... Ice dispenser now works as good as new... Funny part is all I "really" needed was the Funnel, but LG changed the part and it would only fit if I also replaced the Funnel Frame. Good Luck to the next person reading this!
Mike W
Posted on May 15, 2010
Jahn27
  • 1554 Answers
SOURCE: Whirlpool Cabrio electric dryer WED6400SWO. Start
Remove the three screws securing the User Interface board cover then using a flat-blade screwdriver, pry the two locking tabs out and unclip them then remove the User Interface board cover from the console.
Lift the encoder locking tab and turn the encoder counterclockwise as far as it will go the lift the encoder straight up so that the shaft slides out of the rubber console seal. Remove encoder from the console without flexing the encoder ribbon cable wires at the User Interface board or they could break.
Carefully pry the front edge of the user interface board up using a flat-blade screwdriver then pull the board forward and remove it from the console.
The new User Interface board can now be installed on the console by following the above steps in reverse order. Make sure the console rubber seal does not become dislodged when installing the encoder shaft.
Let us know if you need further advice. Please make sure you accept the most helpful or informative solution. Accepting a solution will not stop you from communicating with the expert. You can still communicate with the expert as long as you need assistance regarding the issue stated herein.
Posted on Jan 29, 2011
How to fix winding mechanism on Fisher Price #995 Record Player?
normally there is a small ratchet pall that clicks as you wind it up and holds the spring energy
either that or the end of the coil spring has broken off
May 06, 2016 | Fisher Price Vintage RECORD PLAYER Music...
Install recoil spring on RYOBI08420
Requires the removal of the engine/starter cover so you can rewind the spring as you will need to get it back in place.
Once you make sure the spring isn't broken or badly bent and installed correctly, you will wind it up until it stops and back off one turn and install your pull rope.
If the spring is damaged then it is best to replace it as it will give problems.
Dec 10, 2014 | Ryobi Garden
Lawn mover starter rope replacement
most starters can be taken off the engine and replace the rope without completely tearing the whole unit apart. by that I mean you should not have to mess with the recoil spring unless it is broken. remove old rope from pulley, wind up the pulley and hold it so it wont unwind, replace new rope onto pulley and tie a good knot and melt the ends of the rope so it wont unravel, then slowly let the pulley retract the correct amount of rope. if the recoil spring has unsprung on you, it will take a little time and probably several tries to wind it back up and position it back in the starter. they like to unspring while doing this so take some time and an extra person to hold and assist might go a long ways. good luck. R
Aug 25, 2012 | Ariens 21 In Classic Walk Behind Push Lawn...
How to put a new pull rope on it How do I put a new pull rope on
It realy depends on what model we are talking about, so i will give a general disciption, remove the four screws retaining the starter to the saw, remove the starter, if the cord is still under tention, pull the starter handle out approx 8", whilst held out hold the pulley to stop it retracting, let go the starter handle and unwind the now lose cord from around the pulley, once enough cord has been unwound let the pulley slowly turn until all the spring tention has gone, remove the center fixing screw, and remove the pulley, pull the old cord away, refit a new suitable diameter cord, knot the end and pull the cord into the pulley so as the knot sits flush into the hole in the pulley, wind the cord fully around the pulley,now refit the pulley to the cover, refit the centre screw ,push the other end of the cord through the cover eyelet and refit the starter handle with a suitable knot, now wind the cord around the pulley a further two times by turning the pulley and winding up the spring, allow the spring to pull the cord in, if required wind the pulley a further turn until the cord is suitably tentioned in the cover, replace the cover on the machine, pull the cord out to make sure it has engaged fully into the pawls before fully tightening the fixing screws.
Aug 18, 2011 | Husqvarna Chain Saw 20" Bar
Music Box Record Player.....have taken it apart without any problem....sprayed metal parts with WD 40...this loosened the parts and now they can be turned with my fingers...winder button now makes a...
WD40 leaves a residue behind to help prevent moisture. Unfortunately, the residue can gum up the internal workings of some items and prevent them from functioning properly. I'm afraid that you are right and that the spring may be damaged. Weather this is from the WD40 or not, I don't know.
Good news though, is there is a group that repairs old toys. Their web site is http://www.thisoldtoy.com/l_fp_set/toy-pages/900-999/995-musicboxrecordplayer.html
Toward the bottom, you can reach them by email and arrange to have this repaired through them.
As a rule of thumb, don't use WD40 if you want it to work next week too. The chemicals in it end up gumming up the inner workings. I've used WD40 as a cleaner when I need to remove rusting. When something requires light oil, a good 3-in1 oil is best.
A bit of trivia for you - WD-40 stands for Water Displacement, 40th attempt. Makes you wonder, if they would have gotten it right on the 39th attempt, they would have called it WD-39???
Good luck,
Mark
Apr 02, 2011 | Fisher Price Toys
How fit new cord/cable into machine. Unable to remove mechanism at present. No instruction manual available. Tried pushing, pulling twisting etc etc. Can you help?
is it the pull rope? if so you will need to remove the four to six bolts around the shroud. once shroud is off turn up side down, remove old rope. you will need to wind it up and if you feel tension then the spring is still good, if not then it is broken. if the spring is good wind it a few times, do not let go, and feed cord back through, tie a knot and burn the end, let go of rope and it will self wind, pull a few times to ensure the knot is going to hold. then reassemble, hope this helped Tim
Mar 19, 2011 | Garden
I have a craftsman blower 358.797130 and the pull core broke .i have taken everything apart but can not get the pully off the seal o ring seems to be stoping it help the manual is no help
Yes, owner operator manuals cover very little in the way of repairs. If you have the unit taken apart down to the starter/recoil unit and you want to replace or rewind the rope on the pulley...it shouldn't have to be removed, unless the starter spring has broken. These units have a cheap starter system that wears easily and causes the problem you have. If you can, preload the spring (before installing the rope ) by turning it several times in the tension direction and then hold it in place and install the rope, Observe how the old rope is looped around the inner core of the starter if you install new rope.
Aug 06, 2010 | Craftsman Garden
Old Penn 209 level wind not turning but spool works is there a part missing ??
There are many small parts within the reel itself and something may have gotten dislodged or someone may have taken it apart and not put it back together properly. There are exploded parts diagrams available at www.pennreels.com to assist you, but they can be very difficult to read. If you take your reel apart, be VERY VERY careful not to lose anything, especially a very small spring that holds the ratchet lock (dog) in place.
Aug 02, 2010 | Sport & Outdoor - Others
How do I repair a broken pull cord on a yardman push mower?
Easier than you might think. You need a screwdriver along with the sockets to remove the housing over the rewind assembly. Once you have the housing off and access to the assembly, remove the old cord by using it to wind the spring all the way out. Before you take the cord out slip a screwdriver in the slots to keep it from winding back up. If it does, it's not a concern. Just wind the spring back out by turning the rewind until it stops, then turn it back one turn until the holes line up for the cord. Stick the new cord through and tie it off, and let the spring pull the new cord in. If you need any help with it, hit me up.
May 12, 2009 | Garden
Toys Logo
679 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
