Question about Exercise & Fitness
Mi fan won't work on my nordictrack 4400R treadmill
    Top Expert:
  • 12,223 Answers
Test the input voltage motor fan, If there are replace the fan motor.
However you must tight all connector, test the fuse+c.breaker.
See the diagrams attached for troubleshooting guide.
God bless you
mi fan won't work on my nordictrack 4400R trea - 1_9_2013_4_55_10_pm.png1_9_2013mi fan won't work on my nordictrack 4400R trea - 1_9_2013_4_55_59_pm.gif1_9_2013_4_55_59_pm.gif
Posted on Jan 09, 2013
  • 64 Answers
SOURCE: nordictrack treadmill will not close
Check elevation position.
Posted on Jun 08, 2009
  • 9 Answers
SOURCE: Nordictrack treadmill C2100 belk is not slipping
Several issues, drive belt that drives the walking belt could be loose but you should smell rubber if its slipping.
Something could be caught in the track causing extra drag, its easy to do if you have kids or pets
Check for when you last lubed the track and walking surface, with no silicone it will drag and bog at low speeds
Posted on Oct 22, 2009
  • 40 Answers
SOURCE: I have the Nordictrack Apex 4100I treadmill. It
try caibrating it.
Posted on Nov 01, 2009
  • 103 Answers
SOURCE: I NEED THE NORDICTRACK 9600 INCLINE TRAINER TREADMILL SCHEMATIC
contact me @ swflafitnessrepair@yahoo.com I will send this to you.
Posted on Nov 13, 2009
  • 103 Answers
SOURCE: can you get power to a treadmill without the
Hello there. Yes you actually can use a magnet. (thats all the safety key is) It will need to be strong enough to make the switch inside the console activate. I use one from a telescoping magnet used for picking up small screws (available at the big box stores) when I dont have one on service calls.
Just to let you know a refrigerator magnet will not be strong enough!
Good Luck! Tim
Posted on Feb 21, 2010
I have a NordicTrack commercial 1750 treadmill. My console contols do not work and the ifit screen does not complete startup. What can I do to troubleshoot the problem?
The Controls Are Not Working on a NordicTrack Treadmill ...
www.livestrong.com > Sports and Fitness
Jun 1, 2015 - The Controls Are Not Working on a NordicTrack Treadmill ... Many glitches involving the controls on the console can be solved relatively quickly with some simple .... How to Use the iFit Videos with My NordicTrack Treadmil...
Nordictrack commercial 1750 that Icon can NOT fix - YouTube
? 3:52
https://www.youtube.com/watch?v=ILBbzyUXn2Q
Dec 16, 2011 - Uploaded by gerg6060
Nordictrack commercial 1750 that Icon can NOT fix ... I'll NEVER buy another Nordictrack again, Smooth or ...
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...1...
NordicTracktreadmill is not working properly. (See. TROUBLESHOOTING on ... COMMERCIAL 1750 treadmill. ... Console. Book Holder. Key/Clip. Power Switch. Walking Belt. Foot Rail. Power Cord ... Set the treadmill in a cleared area and remove all packing materials. Do not dispose of .... Each workout automatically controls the speed.
Dec 28, 2015 | Nordic Track NordicTrack COMMERCIAL 1750...
My NordicTrack T5zi Walking Belt Treadmill won't
Very likely your console went out. I usually check for voltage running to the console (the wires in the back) and if it has juice but will not come on, I replace the console. As far as "why", usually it is power fluctuations, it can be as simple as turning on a high-amperage piece of equipment, or running too many electronics on the same circuit. I see consoles go out from low voltage more often than high voltage.
Nordictrack is an Icon product, you can download the product manual and parts diagrams at iconservice.com.
Feb 02, 2013 | Exercise & Fitness
My fan won't work on my nordictrack 4400R treadmill. What should I do to get it working.
please test the voltage in the motor fan with DVOM. IF There are voltage , and the motor is NOT running , replace it.
However you must tight very well all the connectors. Test the fuse in the treadmill see the block diagrams attached for troubleshooting.
God bless you
Jan 09, 2013 | Exercise & Fitness
Nordictrack 5.7 buttons don't work
Call the 800 number on the front of your owner's manual (downloadable at iconservice.com) for service. Most likely your console is shot. It is easy to swap out, but costs a little bit. Also, make sure your safety key is on. Consoles do not operate without that little red key in the front.
Dec 01, 2012 | Nordic Track Nordictrack T 5.7 Treadmill...
Nordictrack Commerical 1500 - Display Failure/Won't Turn On
There can be a few reasons,
Lume
LCB
Console
Is it under warranty ?
Jan 25, 2012 | Nordic Track NordicTrack Commercial 1500...
Treadmill buttons don't work right. TV won't turn off. Treadbelt won't run.
1) Try to reconnect the plug between console and pcboard very well.
2)Clean the contacts with special contact cleanear( radio schack or computer store) with carefully only the buttons, if you can open the cover better.
3) adjust the Sensor SWITHC.
4) Look for any wire loose, or making bad contact, or break wiring( continuity) test the fuse and breaker.
If after you did those steps, and the problem persist, the console board is faulty.but first change the sensor switch, you must be shure after adjustment.11_18_2011_12_23_17_am.gif
Nov 17, 2011 | Exercise & Fitness
My nordictrack is stuck on a program &wont let u do anything else..cant change the speed or incline &the fans wont turn on..its like the consol is frozen or stuck on a program..how can i reset it...
How to Troubleshoot a Nordic Track C2500 X15616db0-ef56-4f0a-afbd-b1ae3379f47f.small.jpg Jolie Johnson
Based in Austin, Texas, Jolie Johnson has been in the fitness industry for over 12 years and has been writing fitness-related articles since 2008 for various websites. She received her Bachelor of Arts in English and philosophy from the University of Illinois.
By Jolie Johnson, eHow Contributor
updated April 15, 2011
Related Searches:
The NordicTrack is a treadmill designed for in-home use. It offers a speed range of 0 to 10 mph and an incline range of 0 to 10 percent. It folds up vertically to save space when you aren't working out and can be rolled to a different room. The console has 16 preset workout programs and features iFit interactive technology. If you have problems with the console or walking belt, you can often fix them yourself with some basic troubleshooting steps
Instructions
  1. Power Turns Off When You're Using the Treadmill
    • 1 Check the reset switch on the bottom of the treadmill near the power cord. If it has tripped, the top of the switch will protrude. Wait 5 minutes then press the switch.
    • 2 Check that the power cord is plugged in completely. If it is plugged in, unplug it, wait 5 minutes then plug it back in.
    • 3 Remove the magnetic key from the console then reinsert it.
    The Console Won't Turn Off
    • 1 Insert the magnetic key into the console. Your C2500 is stuck in demo mode if the console won't turn off after you remove the magnetic key from the console.
    • 2 Hold the "Stop" button down for a few seconds.
    • 3 Press the "Speed" down (-) button. Remove the magnetic key.
    The Incline Does Not Change Correctly
    • 1 Press and hold the "Stop" and the "Speed" up (+) button. While holding the buttons, insert the key into the console, then release the buttons.
    • 2 Press either the "Incline" up or down arrow button. Wait while the incline raises and lowers. This recalibrates the incline system.
    • 3 Remove the key from the console.
    Walking Belt Slows
    • 1 Unplug your C2500 and remove the key from the console.
    • 2 Turn both rear adjustment bolts, located on the back of the walking deck, to the left, a 1/4 turn.
    • 3 Lift the edge of the walking belt in the middle of the deck. You should be able to lift it 2 to 3 inches off the walking platform. If the belt is still too tight, loosen the bolts another 1/4 turn each.
    • 4 Plug the treadmill in and reinsert the console key. Walk on the belt at a slow speed to see if it still slows. Repeat Step 2 if necessary.
Sep 27, 2011 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
155 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
