Question about 2wire (1000-400108-001) Router
Noisy phone line with 2wire rpoter
Hi I have been using a 2wire 1800 home portal router for 6 months with no probs, over the past few days my telephone line has started to be noisy but once I disconnect the router the noise disappears, I have filters on every piece of equipment. I have contacted my telephone line provider and they say the line is clear. Canyou help please
    President:
  • 2,961 Answers
If the line is clear, just use a line filter only where you have a phone fitted and nowhere else, that way you can try the different filters if you are using more than you need as it sounds as if one may be faulty. Also check any extension leads you may have or remove and check you phone line again for noise. If there is noise it would normally stop you from connecting to the internet also.
Posted on Jul 01, 2007
SOURCE:
I have a 2 wire home portal 1000HW. We recently had a power failure and the unit stopped working. I have checked the power supply with a vom and it is putting out the rated 6V. I have tried multiple...
Check your current rating on the OEM power supply.. I think your power supply needs 2 amps at 6 Volts. The cheap ones at radio shack are usually only 2 ma.
Jul 05, 2010 | 2wire HomePortal 1000HW DSL Modem and...
2Wire Home Portal 1100 for AT&T DSL connection problem
HI! read your posting regarding the situation that your experiencing.. If before you dont have any problem regrding your connection with out the cisco network magic. I suggest that before you install the cisco network magic. you should get the full version not the trial version, there is a limitation of setting up the trial version.. Cisco network magic is a plug and play and easy to setup if you get the full version. I dont see any problem regarding your connection with the 2wire and the linksys router, becoz you mention earlier that hime network is working and you can connect to the network and the internet..
Jul 24, 2009 | 2wire Computers & Internet
Using 2wire 1800hg Home Portal. Have successfully connected with PC Port Adaptors using the existing telephone line. No problems. Then purchased a laptop w/ Vista installed. 2wire setup CD causes error...
Listen, you do not need that CD! This is already configured. That cd is for other types of troublesome operating systems that just cannot seem to get is DNS settings right such as windows XP. The cd is for XP only you do not need this with vista.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 18, 2009 | 2wire 1800HG Router (RG1800HG00)
I recently upgraded from my 2wire DSL to Uverse. My older laptop with the 2wire card and the home portal fins the new network but only runs at 11 mbps. Where my other laptop with the newer 2wire software...
That means the older 2wire card was a B model adapter, which can only run at 11mbps. The other laptop most likely has built in wireless or some other adapter in it that runs on the G model, which is 54 mbps. There is no way to fix this issue, other then aquiring a new wireless adapter for your older laptop.
Jun 29, 2009 | 2wire HomePortal® 1800HW Router...
2wire Home Portal 1800HW
This 2-Wire Home Portal is a DSL modem. It can be used by itself as a wireless modem. It cannot be hooked up to an existing modem.
Go to this link and download the user manual:
http://www.dsldepot.com/download.asp?fileid=96
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 05, 2009 | 2wire HomePortal® 1800HW Router...
I AM RUNNING VISTA CAN I GET UPDATED SOFTWARE FOR MY 2WIRE PORTAL
I UPGRADED TO VISTA AND NOW I CANT GET MY 2WIRE PORTAL SOFTWARE TO INSTALL. IS THERE AN UPGRADE OR NEW SOFTWARE AVAILABLE ? ► there is no need to install the CD if ur trying to connect using an ethernet cable to the 2wire. If ur attempting a wireless connexn, u shud configure the wireless set up.
1000 SW (Model) for 2wire,Connects fine, intermittently the Broadband Link goes ORANGE and keeps me off Internet ► this is a possible line problem. Try plugging ur 2wire's phone cable directly to the phone/wall jack removing the filter or splitter in the process. Then see if the problem reoccurs. If it DOES NOT, replace ur filter with a new one. If it DOES reoccur or if it is already connected to the phone/wall jack directly, contact ur Internet service provider.
keep me posted on these...
Dec 15, 2008 | 2wire (1000-400108-001) Router
I need to retrieve my password for a 2 wire home portal
you cannot, you need to find the reset button to set it back to the default password
Aug 21, 2008 | 2wire Computers & Internet
Connect panasonic bl-ca10 cam to a 2wire home portal 1800g
Try using WEP instead of The WAP protocol.
It worked for me.............
Jul 06, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Home portal not yet activated
XP is an very good OS which will connect with 2wire without any problem.
If your computer is not able to detect modem, pls follow these steps.
* Check for damage of ethernet cable
* Try to reset the modem by using a paper clip punching into the reset button
* Even if your modem is not detected, force the IP and Default gateway
Take care
Feb 26, 2008 | 2wire HomePortal 100W (1000-400026-000)...
Unable to access homeportal, but internet is ok?! (2wire 1800hw)
I had the same problem. I reset the home portal to factory setting and uninstalled the 2wire software from my main computer. I then reinstalled the system using installation cd that came with 2wire.
Jan 21, 2008 | 2wire HomePortal® 1800HW Router...
2wire (1000-400108-001) Router Logo
137 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ekse
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
