Question about Verona FSGE536SS Dual Fuel (Electric and Gas) Kitchen Range
Oven door will not close at top
With door closed there is approx 3/8" gap at the top of the door, so it does not even contact the rubber gasket. The bottom of the door is tight against the unit housing. The door also appears to be bent in the same spot on each side closer to the bottom but the bend is away from the oven at the top, as opposed to back towards the oven which would make sense since we are pushing the top of the door in towards the oven to try to get the gap at the top to seal. I also cannot see the hinging mechanism in the door itself. It does not appear to be any type of bar or rod which the hook part of the hinge would pivot on. Are there any better manuals out there than just the owners manual?
How do I fix an oven door
sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
Sep 22, 2016 | Ovens
My samsung freezer door does not close all the way causing frost buildup. I have replaced the gasket and leveled the fridge.
The hinges usually have some adjustment on them. Two person job, or put something under the bottom of the door to support it. Loosen the hinges a bit, pull the door forward at the hinge which should close the gap on the other side. Tighten down the hinges and check again.
Jun 16, 2016 | Samsung Refrigerators
Refrig door does not seal
First off, make sure nothing is stopping the door from closing completely. If the door is closing properly, then using a hair dryer, heat the gasket until soft and pliable. You can carefully stretch it towards the cabinet. There is a magnet in the gasket all the way around on the mating portion. While the gasket is soft, the magnet will pull the gasket until contact is made with the cabinet. Once a good seal has been accomplished, allow to door to remain closed for 30 minutes. The seal will cool down, and the new shape will be maintained. After that, close the door on a dollar bill. Gently tug the portion of the bill on the outside of the door from one corner to the other. There should be some resistance to your pulling. If the bill feels loose, apply more heat to the gasket in that area to improve the seal. DO NOT HOLD THE HAIR DRYER IN ONE PLACE TOO LONG AS IT WILL DAMAGE THE GASKET, AS WELL AS THE PLASTIC LINER.
May 08, 2014 | Refrigerators
Kebs208dss11 model double oven. When upper oven is on with door closed, steam can be seen escaping from top of door. Door is closed all the way. Even when putting pressure on door to make sure it is...
The first thing I'd suspect is a poorly fitting door seal / gasket. This will permit the heat inside the oven to escape. Check to be sure the the one installed is defective (cut, split, frayed, dislodged, etc.) Replacement parts:
http://www.appliancepartspros.com/whirlpool-gasket-door-w10074200-ap3892420.html
Make sure this is the part you need before ordering.
Feb 25, 2014 | KitchenAid Ovens
The top right corner of my panasonic nn-h275 otr microwave door leaves a approx. 3cm gap when closed. Fixable? Dangerous?
If the door is warped cheaper to replace the whole oven, the 3cm gap is a hazard because you have dangerous radiation leakage, the levels are exceeding safety standards and should be removed from service immediately.
Mar 27, 2011 | Panasonic NN-H275 Microwave Oven
Euro maid sc1531 oven door dose not close at the top
Did you solve your problem???? Cause I am having the same problem :( I would really appreciate it if you could let me know Thanks
Jul 04, 2010 | Ovens
I think the freezer door is letting air in. What is the rubber around the door called? And do I need to replace it?
That is called the door gasket, and if it isn't cracked it shouldn't be replaced. Sometimes we close the fridge door and an object is in the way, which may cause the door to flex, then close crookedly with a gap in the seal. These doors are very flexible and can be pushed in the opposite direction of the gap to resume their shape. Test for any gaps by placing a piece of notebook paper at various points around your fridge between the gasket and the body. If the paper grabs against the gasket, you are fine and can try another area etc.
Mar 10, 2010 | Refrigerators
Freezer and refrigerator doors are mis aligned after move. gaps where you can see into both compartments. are doors adjustable to fix this problem?
can you see the rubber gasket which will be fixed all the four sides of the door,it should be uniform when you close the door.
Jul 31, 2009 | Kenmore 64802 Top Freezer Refrigerator
Refridge door does not close evenly on my side by
Top hinges can swing right to left slightly when all 3 screws are loosened under removable cover. Use a 5/16 nut driver. Hinge cover may be phillips, 1/4" or 5/16".However, fridge case must be level left and right first. Level fridge with adjusters behind toe kick cover. Once level, you can adjust gap between doors with top hinge movement. Keep in mind that this is a man-made product and you may not get the doors exactly straight due to lose manufacturing tolerances.
Jul 24, 2009 | Refrigerators
Oven door does not close fully
You need to replace the oven door hinges.
Please rate my solutrion.
Thanks.
May 15, 2009 | Neff B1421 Electric Single Oven
Verona FSGE536SS Dual Fuel (Electric and Gas) Kitchen Range Logo
27 people viewed this question
Top Verona Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Verona Kitchen Range Expert? Answer questions, earn points and help others
