Question about Keurig Elite B40 Coffee Maker
When the cup button is pushed, the maker tries to make coffee (five or six grinding type sounds) but nothing happens. The screen reads "brewing" but no coffee comes out.
  • 139 Answers
Run the keurig with vinegar instead of water. Then run it 5 times with only water just to remove the vinegar taste. Do this once a month. Also there are pins that pokes holes on top and bottom of coffee kcups, find the pins and clean it by unclogging with paperclips or some thinner wire. Buy a K-cup holder from amazon.com. Its the black cone shaped holder.
Posted on Jan 20, 2013
Junoon007
  • 1011 Answers
SOURCE: Coffee maker not working
Dear Sir/madam,
Please contact our Customer Service department at 1-866-901-BREW (2739) to make service arrangements.
and Try also
PREPARE
Step 1: Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug (do not use a paper cup.)
Step 2: Empty the water in the Water Reservoir b. FILL AND CLEAN
Step 1: Pour the vinegar into the Water Reservoir and fill it to the top edge of the clear viewing area.
Step 2: Place a ceramic cup in the Drip Tray and run a brew cycle. DO NOT USE A K-CUP…just press the Large Cup Button. Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the Water Reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4: Now fill reservoir with fresh water and let the Brewer stand for 4 hours while still on.
Step 5: Rinse the Water Reservoir thoroughly and fill with fresh water. c. RINSE Step 1: Ensure the Water Reservoir is filled with fresh water.
Step 2: Place a ceramic cup on the Drip Tray and run a regular brew cycle. Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the Water Reservoir is empty. Step 4: You may need to perform additional brew cycles if you notice any residual taste.
Regular cleaning (de-scaling) will prolong the life of the appliance. Scale is harmless, but left unattended, it can hinder optimal Brewer performance. De-scaling your Brewer regularly helps maintain the heating element, water reservoir and other parts of the Brewer that come in contact with water. Better water quality and water heating means a better cup of coffee. We recommend de-scaling your Brewer at least every 6 months (every three months if you are using hard water). The descaling process involves using 48 ounces of undiluted white vinegar.
Regular cleaning of the Brewer’s external components is recommended for proper operation. We recommend cleaning with a soapy, damp non-abrasive cloth. The K-Cup holder and funnel, drip plate, drip tray and removable water reservoir (on the Elite B40, Special Edition B60, and Platinum B70) are dishwasher safe. NOTE: the removable lid of the water reservoir is NOT dishwasher safe. The brewer should be descaled every 3-6 months.
Check out the Link for more information:
http://www.keurig.com/
faq.asp?mscsid=J5HAXXHH0GNG9LXP576CPCG47B500439#brewer9
Don't forget to rate the solution
Thanks
Posted on Apr 01, 2008
SOURCE: I purchased keurig coffee maker yesterday...made
Lift up the handle and put it down again...the lights will flash & then you can push one of the cup sizes.
Posted on Feb 20, 2010
SOURCE: keurig B50
This didn't work for me, but I saw that it worked for someone on another forum, so here goes...
If you feel up to taking the bottom plate off your B50, take it off and look at the two connectors (blue & red wires) going to the green part in the center. The vibration of the B50 may have shaken them loose. Reseating the connectors may fix the problem.
Like I said, though, it didn't work for me. Still no love from the B50. It's just over 2 years old, though, so it's out of warranty. Maybe I'll see if I can weasel a B70 for Valentine's Day.
Posted on Feb 01, 2008
I've got a B50 as well, and none of these solutions are quite accurate. The problem is with the ball valve directly above the top needle. You first need to remove the handle by taking out the screw on either side. Mine is some size of torks. Then open the hood and remove the two screws from under it. The hood then lifts right off the body. There is a rubber hose that goes into the top part of the ball valve; this must be removed. You can then use a slightly bent paper clip to reach in carefully and push the ball down to unstick it. It is being pushed up by a spring from underneath, so coming from the bottom with a paper clip just pushed it up tighter in the seat. Once it is clear again, put the hood and handle back on.
I think Keurig should send free replacement valves, maybe better designed as well so they don't stick anymore. If not, I am going to see if I can purchase a replacement.
Posted on Jan 06, 2011
tgmusicgirl
  • 91 Answers
SOURCE: I just descaled my coffee maker and now it
After the pump fills the keurig and a sensor detects the proper fill level, a valve closes and a 12Volt air pump turns on and pushed the water out of the internal resevoir to the head of the unit.
My B70 air pump siezed up.. (actually formed rust in the friction bearing). I had to take the back off and the pump is located behind the water resevoir. had to remove the pump and test it with a 12Volt power supply.. it didnt spin... so I disassembled the air pump and found the shaft stuck with rust .
Used "Kroil" or you can also use WD-40 on the shaft to free it up... re assemble the pump and re-solder the wires back tp the pump...
worked for me.
good luck.
Posted on Apr 17, 2011
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
Just bought a cuisinart grind & brew dgb-550 and can't get the program setting to work. Tried putting in a time and leaving it and tried pushing the program button after entering the time.
Push the program button one more time - the first push allows you to set the time, the second push stores the time you have just entered, and then you have to press it one more time to make the light next to the program button light up tell it to brew at the set time.
Aug 23, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
Aug 26, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
Jul 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind & Brew not using all the water in the reservoir
I was having problems like this and then I read on a different string on this website that people have had success by flushing the system numerous times (sometimes up to six times) with vinegar. I took out the charcoal filter and flushed once with vinegar but only saw a small amount of improvement. I was out of vinegar so I used Lemishine mixed with water and it went from making one cup to making a full pot with one flush.
Jan 10, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Keurig Elite B40 Coffee Maker Logo
168 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
