Question about Dyson DC04 HEPA Bagless Upright Cyclonic Vacuum
Dc04 belt replacement - Dyson DC04 HEPA Bagless Upright Cyclonic Vacuum
  • Dyson Master
  • 18,407 Answers
This video will show you
Posted on Jan 09, 2013
How to replace belts on dc04
Hi, it's Jeremy from Crucial Vacuum.
Attached in the link below you will find a how-to video on how to replace your Dyson DC 04's belt. The video will say DC 14, but be assured that they are compatible and the same method will work for your vacuum.
https://www.youtube.com/watch?v=7QpHz26KR5o
You can purchase direct your replacement Dyson DC04 belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dyson-dc07-clutch-belt-set.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 05, 2014 | Dyson Vacuums
Dyson dc04 new belt snapping and I think the brushroll is broken as only part of it rotates when i manually turn it
I'm sorry to hear you're having difficulties with your DC04. From your description of the issue, it sounds as if it's probably best if you get in touch with us directly so we can determine if a replacement part is necessary. You can call us free on 08002980298 - our Helpline is available from 7am until 10pm, 7 days a week. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 23, 2011 | Dyson DC04 HEPA Bagless Upright Cyclonic...
How do I replace the belts on a Dyson DC04 purple
That model has a clutch unit from which the two drive belts are located. It is a technical job to strip that unit down to change the belts, so the easier solution if you have a snapped belt, is to replace the clutch unit (that comes with belts on it). A recycled one represents better value for money, and you can get one here: Dyson DC04 clutch unit.
Nov 07, 2010 | Dyson DC04 HEPA Bagless Upright Cyclonic...
I have a Dyson DC04 which is making a strong burning smell within a few seconds of switching on. Is this likely to be the motor and if so can it be replaced?
More likely it is the beater brush which is jammed and not turning. Turn the machine over and remove the bottom plate. Unhook the drive belt, then try to turn the beater brush--it is likely bound up with string, thread, and hair. Try turning the machine on once--if the motor spins and makes vacuum, it is probably ok. Remove the brush assembly and clean it of debris. Clean the end bearings with a Q tip and WD40 oil, then wipe clean with another Q tip. Oil the bearings with 3-1 or other light oil. Check the belt for a badly burned area--replace if necessary. Slide the new belt over the brush and motor shaft, then drop the brush with bearings into the case, and check rotation. If ok, replace the plate and test on your floor. Hope this helps!
May 16, 2010 | Dyson DC04 HEPA Bagless Upright Cyclonic...
Was hoovering when my DC04 made a funny high pitched noise then a whirring noise, this was accompanied by a smell of burning and a puff of smoke! Almost sounds like it might be a clutch slipping, is this...
OK... the DC04 doesn't have a clutch. My best guess is that the belt that drives the brush roll has broken. The smell of burning and smoke puff were probably caused by the motor suddenly speeding up when freed of its burden of driving the brush roll. For illustrated guidance on checking (and if necessary changing) the belt, go to www.dysonmedic.com then scroll to the bottom of the page and click on "DC04 Belt Change Guide".
I hope this helps. If so, please remember to rate this response. If not, please post a reply and I'll try again. Good luck!
Feb 05, 2010 | Vacuums
My belt has snaped on my dyson dc04 that has a clutch how do i change it
Remove the roller brush cover plate that is on the bottom and you will be able to access the belts. Here are the belts you need:
Dyson DC04 Belts
Nov 18, 2009 | Vacuums
Roller does not turn
It sounds as though you need to replace the drive belt. The necessary part is available from http://www.espares.co.uk/dyson/dc04/p/1086/716/4. Fitting it is tricky, but guidance is available from http://www.dysonmedic.com/DC04%20Folder/DC04%20belt%20change.html
Aug 02, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
Dyson DC04 HEPA Bagless Upright Cyclonic Vacuum Logo
24 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
