Question about ERP Microwave Capacitor - 13QBP21095
How to open up an over the range microwave to replace the hv capacitor
Model Numer is: FGBM185FKA
  • ERP Master
  • 9,047 Answers
I'm not finding that model number. Please check your tag in the cooking cavity or on the microwave somewhere.
I'll guess that you might mean FGMV185KFA. You can find helpful exploded views and order parts here.
There is a YouTube video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
On some models that will be enough to give you access to the capacitor.
If not, you'll need to remove the oven from the wall, then remove the cover to access the HV capacitor.
If so, it's best to have 2 people, since it can be heavy and awkward. The installation instructions are here.
Please see this safety file first.
Posted on Jan 10, 2013
  • Mike Cohen
    Mike Cohen Jan 10, 2013
    Mr. Miller, Thank you so much for the tips.My model number is FGBM185KFA.IT IS AN OVER THE RANGE. i INSTALLED IT ALONG WITH A FRIEND TO HELP LIFT IT INO PLACE.i HAD A POP SIMMERING FOR ABOUT 1/2 HOUR, THEN AT A RAPID BOIL.i THEN USED THE OVEN, pop LOUD ENOUGH to startle me.Then funny sound when working and no heat.I just need to know the location of the HV capacitor and how to access it.Michael
My one year old microwave just stopped working. The light is on, but nothing else.
Sorry to read about your problem, I hope this helps you out.
here are some issues, but you still maybe under warranty.
  1. Blown fuse in HV transformer primary circuit or HV fuse (if used).
  2. Bad connections (particularly to magnetron filament).
  3. Open thermal protector or thermal fuse.
  4. Open HV capacitor, HV diode, HV transformer, or magnetron filament.
  5. Shorted HV diode, HV capacitor (will blow a fuse), or magnetron.
  6. Damaged protective VDR from filament to chassis (not commonly used).
  7. Defective HV relay (not commonly used).
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 05, 2011 | Goldstar MV-1501 Microwave Oven
Micro wont heat. fix or replace? what could be the prob?
Here are some problems you can have
3 Thumbs - Helpful
Jan 05, 2011 | Kenmore 63792 Microwave Oven
Microwave activate but will not heat food all light and buttons work but will not heat up
You can many different issue's
3 Thumbs - Helpful
Jan 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1440 will not heat.
No heat but otherwise normal operation.
Possible causes:
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
3 Thumbs - Helpful
Jan 01, 2011 | GE JVM1440 Microwave Oven
Would the H.V. Capacitor cause my microwave to stop working
If the HV capacitor goes open circuit the voltage doubler circuit will fail and result in no power to the Magnetron.
If the HV capacitor goes short circuit that will result in an extra load on the power transformer eventually failing the mains fuse.
Either way the magnetron will not be able to produce power.
Dec 27, 2010 | Maytag Appliances Over-the-Range Microwave...
Hi, I have a SHARP Microwave Model R398F. Its less than a year old. The display and timer work fine but does not heat up. Can you please let me know what the problem could be. Thanks Js
If the operation is otherwise normal with the exception of heating food, common causes include; (to diagnose requires discharging of the HV capacitor) if you are inexperienced with working with HV I suggest seeking professional help.
Open thermal protectors or thermal fuses.
Open HV Diode.
Open HV capacitor
Open magnetron filament
Open winding in HV transformer
Defective HV relay
Shorted HV diode
Short or other fault in the magnetron
Short in certain portions of the HV wiring
Replacement Magnetrons (the most likely cause if not charring or defective components are found when troublshooting the small parts, can typically be had for around $45.00 just do a web search for your model number.
Good Luck
Sep 07, 2010 | Sharp Microwave Ovens
Generic problem for all Kenmore Microwave
Loud hum is usually due to faulty hv diod, resonance capacitor, or the magnatrone feed thru capacitor , chk it with a ohm meter , one by one n replace it .. zaheer Islamabad
Dec 31, 2009 | Kenmore Microwave Ovens
I have a Kenmore Elite over the range Microwave Model # 665.61682101 It just starting having this zapping/buzzing noise when it starts-what it it?
HI, This is a malfunctioning HV(High voltage Capacitor). It must be replaced asap. this will cause a fire in your home if not replaced soon.
Aug 06, 2009 | Microwave Ovens
I have a Kenmore model 66561689101 that doesn't heat properly anymore. What is wrong?
The most common problems of microwave oven are the HV capacitor, HV diode and lastly the magnetron which is the main part of M O. check the capacitor and diode first, if its okay, then you have a decision to make. replace the magnetron or the whole unit. magnetron are costly
Jun 28, 2009 | Kenmore 62622 Microwave Oven
Microwave makes a loud humming sound when turned on.
Microwave ovens have a diode stack, usually made up of HV Diodes sometimes only 1, if there is 2 one will sit between the 2 connections on the hIgh Voltage Capacitor which sits at the back usually right hand side to the right of the transformer, WARNING: before doing anything, the Oven must be unplugged and the capacitor shorted to earth, unplug one side of the diode and using a multimeter check for short, it should read virtually open circuit, if there is a problem with it it will show a low reading regardless of the polarity of the probes, there is another diode that sits between the HV Capacitor and the oven case (earth) do the same with that, if either read low, replace, then using the multimeter and test between the two connections of the HV capacitor, if reading id low, replace, then check the connections on the Magnatron to earth, not to each other, read should be open circuit any reading, it needs tro be replaced. Hope that helps...Phil
May 19, 2009 | KitchenAid Microwave Ovens
ERP Microwave Capacitor - 13QBP21095 Logo
Top ERP Microwave Ovens Experts
William Miller
William Miller
Are you an ERP Microwave Oven Expert? Answer questions, earn points and help others
