Question about AutoCommand Remote Car Starter Add-On
Manuel part no 20721 auto command
Need a manuel for part no 20721 auto command for installation
I need to find the accesory wire coming from my ignition on a 2006 f350, to install a navigation add on for a kenwood deck
you can get an add on wire that plugs into the fuse box at an auto parts store or walmart. youl just need to find a fuse that has ignition switched power. looks like this ac1f834.jpg
Nov 18, 2009 | 2006 Ford F 350 Super Duty
What kind of tune up I need for my 03 corolla at 62000 miles
1)New fuel filter
2)New air filter
3)New spark plugs, properly gapped.
4)One bottle (the red one)of STP fuel treatment. 4 times a year.
At 80000 miles I would also renew the spark plug wires.
At this time you also need to service the transmission. You dont say if its automatic or a manuel shift model. The auto will need the transmission pan remove and a new filter installed,then new fluid to fill.
The manuel needs the oil drained and renewed.
Nov 01, 2009 | 2003 Toyota Corolla
Need a wiring Diagram for a 1999 Dodge Durango so i can install a remote start system. Or what colors I need to look for.
Most auto parts stores such and advance auto parts and autozone sell repair manuals. I prefer the Haynes manuel wich has the wireing diagrams printed in the back of the book and acuratley tell each color code
Aug 03, 2009 | 1999 Dodge Durango
Toshiba dp80f-Drum unit warning
menu, 5, 2, 0, 4, 1, enter
This will reset the counter for the drum unit.
Feb 12, 2009 | Toshiba DP80F Printer
Voice mail does not respond to commands from auto dialer screen
when on your phone vertically press the track ball and your keypads will show up thus allowing you to use you voicemail commands
Oct 28, 2008 | HTC G1
Can't get Student version to auto-set up
There are a number of bugs with Vista and the later versions of Office (like 2007). Try running "setup.exe" from the Office disk and use great caution before installing SP1 for Office 2007 since the SP1 auto-install can cause problems with Vista.
Oct 09, 2008 | Microsoft Office Standard for PC
Configuring Belkin Wireless Router
You choose a wireless router so you need to install in some freequency. You can choose the freequency by the list like 2.4 G.Hz ect. then just select the link & fix threre working ares / type. Avoid the command prompt. use bessic settings your user manuel help you further.
Feb 13, 2008 | Computers & Internet
AutoCommand Remote Car Starter Add-On Logo
122 people viewed this question
Top Design Tech Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Design Tech Vehicle Part and Accessory Expert? Answer questions, earn points and help others
