Question about Brother MFC Office Equipment & Supplies
Brother mfc-9120cn - print fades in a strip - new toner & drum
Papers print with a faded strip on the side of the paper. Replaced the toner and the drum - made no difference. What else can I try? Printer only 2 years old & only light use.
SOURCE: Brother MFC 7420 Paper Jam
After changing the drum, toner and running around town for days trying to find a reliable place to get this printer repaired, I realized I was spending a lot more money than what the printer actually costs. the drum was over $100, toner was $80, and the printer is $250. I bought a new one, and I can now use the old one for parts.
Posted on Jan 16, 2008
FrankR1974
  • 8 Answers
SOURCE: Faded print on left hand side of paper
This type of printing defect is normally caused by 1 of a few problems - the easier one first:
1. Toner cartridges sometimes do not have the toner evenly distributed - close the toner cartridge and inspect the hopper right below it for even distribution of toner.
The harder ones:
2. This type of defect can also be caused by dirty charging section - for the drum to pick up the toner it must be charged electrically prior to exposure - if the charge grid is not clean then it will not give the drum an even charge - not sure were this is in this printer yet - looks like it comes as part of the drum kit so this should not be causing this issue.
3. The last and most difficult to check is paper alignment with the drum - is the paper contacting the drum evenly - look for possible problems in the paper path with the drum unit removed - look for something uneven around the area were the paper contacts the drum
Posted on Apr 12, 2008
osiriscompu
  • 16 Answers
SOURCE: Problem with the printer drum?
Sounds like the toner isn't sticking to the paper.
Open the top cover of the printer. You will see two yellow felt stickers with a black triangle on them. On either side of those stickers you will see two gray or green tabs. If the tabs are sitting up pull them down towards you so you can see the picture of the envelope on top. Close the cover and try to print.
Posted on Jul 19, 2008
Corysf62
  • 188 Answers
SOURCE: No printing on right side, I replaced the imaging drum but that did not solve the problem.
There are two possible solutions to this common problem.
1) The Cyan cartridge may not be in 100% of the way. If the handle of the Cyan cartridge prutrudes even slightly, it can obstruct the printhead for the black developer. Remove and reinstall the Cyan cartridge and test.
2) The printhead is dirty, with some toner spillage on the printhead. All new imaging drums also include a new cleaning pad for the cleaning wand.
The cleaning wand is designed to clean toner off of the printhead. you can see this in your printer manual, but basically, just open the front cover, pull the the blue handle on the right side forward ( this opens the access cover for the cleaning wand on the right side of the printer ).
gently pull the cleaning wand out ALL THE WAY, then slide it back in ALL THE WAY. do this several times.
The cleaning wand is intended to travel across the print head in only one direction, which is why you should make sure that it is pulled all the way out.
One of these two solutions should fix your problem. If the problem is resolved, but then reappears after a short time, then you have a defective developer that is leaking toner on the print head. The color of the defective developer can be determined by the color of the cleaning pad after cleaning the printhead as discribed above.
Posted on Sep 28, 2008
Corysf62
  • 188 Answers
SOURCE: Dell 3100 CN fades on right side of page only
This is caused by one of two things.
1) One of the handles on the toner cartridges is not seated all the way down. 90% of the time, this is the problem, and of that, most of the time it is the cyan cartridge that is not seated properly.
2) there is toner covering part of the print head. Sometimes this is just a temporary problem that can be fixed by simply cleaning the printhead lens with the cleaning wand. ( i will explain that in a moment). If cleaning the printhead works, but then the problem reappears shortly afterwards, then you have a more serious problem in that the developer housing for one of the toners is defective and leaking onto the printhead. When cleaning the printhead, make note of the most prominent color on the cleaning wand pad, as this is probably the defective housing's color.
To clean the print head
a) Open the front cover.
b) on the right hand side, slide the lite blue handle forward. This will open the access hole for the cleaning wand on the right hand side of the printer.
c) pull the cleaning wand out ALL OF THE WAY until it comes to a stop. Then slide the wand back in ALL THE WAY until it can not go in any further.
Repeat step "c" several times.
DO NOT move the wand back and forth unless you pull it all the way out and all the way back in. This will only smear the toner back and forth across the print head. when it is pulled all the way out it hits a lift that will lift it up and over the print head on the way back so it does not move backwards across the printhead.
the fuser is fine, and one of the two solutions above will fix your problem.
as I said though, if the problem is quick to return, then one of the developer housings are leaking.
Posted on Nov 17, 2008
My printing is fine in the morning but as the day goes on it fades.
Sounds like your printer needs a thorough manual cleaning. Go to printerhacks.com to get step by step instructions
Jul 03, 2015 | Brother MFC-9120CN - 17 PPM Multifunction...
Just replaced toner, drums and belt and still printing light
Clean the 4 LED Lines on top. you can see them when you half open the top cover
Sep 29, 2014 | Brother MFC-9120CN - 17 PPM Multifunction...
Black ink leftside of paper
Black toner leaking, either the toner is low/finished, or drum is end of life.
Sep 04, 2014 | Brother MFC-9120CN Multifunction LED...
Faded print on right side of page. When I copy/print in black, why is the black print faded on the right side of the paper?
Your toner cartridge may be the culprit.
Take the cartridge out and shake sideways and up/down. Reinstall it and try again.
If it's still printing faded side, replace the cartridge.
Jul 30, 2014 | Brother MFC-9840CDW Laser Printer
Dell 1110 faded print left side
If you have trid a different toner cartridge, then I would first try a new drum (not sure if toner & drum are in same cartridge, some are so you will have to check that) If not that, then I would suggest the transfer roller bar would be my next suspect if the printer has a lot of copies done on it.
Jan 13, 2013 | Dell 1110 Laser Printer
I replaced the drum and toner recently, yet half of my pages are faded when they print. It seems to be on the left side of the pages that are faded. Any suggestions
The toner section may not be seated properly in the drum unit. Try removing the toner section and putting it back in the drum section being very careful to keep the cartridge in alignment with the drum.
Sep 28, 2010 | Brother MFC 7840W Printer
Faded strip down length of paper
CLEAN DRUM UNIT AS PER MANUAL . IF THAT DOSN''T WORK TRY REPLACING DRUM AND/OR TONER
Aug 26, 2009 | Brother Office Equipment & Supplies
Toshiba e 650 Copier was working and copies were fading so we
When you changed the toner did you remove the strip on the new toner to release the toner
Jun 12, 2009 | Toshiba E-STUDIO 650 Copier
Faded Image coming from Brother 9420cn
You probably have the new roller by now.  But just incase the problem continues, clean the high voltage contact on the right side for the roller and on the drum unit itself.  If it is dirty you'll get light printing.
Nov 19, 2008 | Brother MFC-9420CN All-In-One Laser...
98 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
