Question about Microsoft Windows XP Professional
Error No. 32
Internet Error No. 32
  • Microsoft Master
  • 27,725 Answers
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem if you need more help with this post a reply with the error message details Hope it helps.
Posted on Jan 10, 2013
How to Resolve System 32 Error in Windows Operating System?
System 32 error is the most common error which can halt the smooth work flow and make you feel dejected. Most of the people are still searching about "What is System 32 error?" why it happens? How does it affect? And what you can do to eliminate it? If you are also one of them then your search ends here, in this article I will let you know about the answers of all your questions regarding the System 32 error. I have looked up several forums, tech blogs and well renowned websites to collect the information.
System 32 is the one of the most important file hidden inside your computer which contains vital information required to function your computer properly. System 32 files generally located in the system drive C:\Windows\System32 in my PC (location on your computer can be different).
Causes of System 32 error:
Check for a corrupted Windows registry. The most common reason of System 32 error is the corrupted registry which can lead to computer freeze. The most common affected files are Config.nt, autorun.inf and svchost.exe etc.
Check for malware and other "nasties" on your computer. It can also be caused due to malwares which causes your computer to respond in undesired ways. Most of the malware enters your computer through spam mails and adware's.
Check for bad system files downloaded via the Internet. System 32 error can be triggered when you update your system files via internet. Some of the sites which promise to provide full version of software contain corrupted files or even are the Trojans which causes lethal damage by uploading virus on your computer.
Check for hardware issues. When you replace or add any hardware then it may be possible that it's not compatible to your existing computer setup which can create problem in the operating system. This can result in the System 32 error or you may hear different types of sounds during booting period of computer. 26319222-bxzhjmonsmllydp0qa2riq2g-2-14.jpg Check for faulty software update issues. Any software update of your computer can also lead to unwanted changes in the registry which inhibits your computer to function properly.
Oct 20, 2016 | Microsoft Computers & Internet
Why does error come on cannon adding machine
please give information about your computer and model of printer ()
1. PC operation system : choice my computer -> right click -> properties, you can see name of software (for ex. windows xp 32 bit, windows 7, 64 bit )
2.have you disc of device or downloaded from internet
if its from internet may be its connected with compatibility versions of softwares (32 or 64 bit) choice compatible version of driver
3. describe the your all acts during the installation and what written on error message it helps to solve the problem
Dec 31, 2014 | Cannon Office Equipment & Supplies
What is error 0x80029c4a and how i fix it
0x80029c4a is often related to a MS library error.. it can't load the correct library. There are various ways to try to fix this error depending on the software/application your using.. (most commonly this issue occurs with outlook) If your running the 32 bit version on top of a 64-bit platform you can try running the 64-bit application instead of the 32-bit. You can also try re-installing the application to see if that fixes the error. Without knowing the exact application version & any other problems you might be having thats all I can advise at the moment.
Nov 06, 2013 | Computers & Internet
System error of comodo internet
Comodo Internet Security - System Requirements
To ensure optimal performance of Comodo Internet Security, please ensure that your PC complies with the minimum system requirements as stated below:
  • Windows 7 (Both 32-bit and 64-bit versions), Windows Vista (Both 32-bit and 64-bit versions) or Windows XP (Both 32-bit and 64-bit versions)
  • Internet Explorer Version 5.1 or above
  • 128 MB available RAM
  • 210 MB hard disk space for both 32-bit and 64-bit versions
Jul 31, 2012 | Video Game Consoles & Games
When trying to install FIx It Utilities 10 Pro I get a 'Fatal Error'message that says 'Installation ended prematurely becasue of an error. I have tried diabaling all Firewalls and virus checkers and even...
Do you had all
System Requirements
  • Windows® XP, Vista® (32-bit or 64-bit) or Windows 7 (32-bit or 64-bit)
  • Internet connection required for product updates and registration
  • Internet Explorer 5 or later.
Dec 05, 2010 | Avanquest Fix-It Utilities 10...
Hi I am Farah, and as I wanted to download java , it came thet" " is not valid win 32 application'. What shoudl I do? Thx
It is possible that you are attempting to install a 64-bit version of Java when you have a 32-bit operating system. Check your operating and confirm this. In Vista you can find this using Start > Control Panel > System. This is similar if you have Windows 7. Here is what it looks like:
If after that you, you follow these instructions from Sun (Java) to locate and install the 32-bit version.
Error: x64.exe not a valid Win32 application This article applies to:
  • Platform(s): Windows 7, Vista, Windows XP, Windows 2000, Windows 2003
  • Browser(s): Internet Explorer, Firefox, Mozilla 1.4+
  • Java version(s): 6.0
SYMPTOMS
While trying to install Java a user gets an error message similar to:
' ... x64.exe not a valid Win32 application'
CAUSE
The error message is a result of trying to install a 64-bit version of Java on a 32-bit operating system.
SOLUTION
User needs to install a 32-bit version of Java software, since a 64-bit version is not compatible with their 32-bit operating system.
Follow these steps to download 32-bit Java
  1. Go to Manual download
  2. Click Windows XP/Vista/2000/2003/2008 Online.
  3. The File Download dialog box appears.
  4. Choose the folder location.
  5. (Save the file to a known location on your computer, for example, to your desktop).
  6. Click Save.
  7. Close all applications including the browser.
  8. Double-click on the saved file icon to start the installation process.
Nov 07, 2010 | Computers & Internet
Trying to configure my phone for internet, but it says, only 32 sets allowed, settings discarded
Check my blog. I have found and written the real solution for this error. http://inxis.blogspot.com/2009/11/gprs-mms-settings-error-nokia-solved.html
Aug 24, 2010 | Nokia 6085 Cellular Phone
Slow internet connection.
There is a fix from microsoft for this. You can find it here.
Dec 29, 2008 | Dell Inspiron 6000 Notebook
Microsoft Windows XP Professional Logo
50 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
