Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
External drive not showing up at all
Ok, My family has a eMac, right? well we have a SATA external Lacie hard drive. well it works fine on this computer. The other day I built my own PC with Vista with SP 1. When I plug the LaCie into my computer to move my stuff from the other computer (music, videos, etc) it doesn't show up. please help
-Screwed
  • Anonymous Jan 23, 2009
    I use windows, and it suddenly stopped working. I opened it and found nothing unusual, but it is not a power problem, it just isn't connecting with the computer. I am not too crazy about fixing it, i just want to get the content off of it.
I was working with (easy hard lock) and than i lock my external hard drive
now i cant get access to my external hard drive
(the program said dont lock external hard drive but i did i didnt know that )
can someone help me please
thanks
Posted on Jan 21, 2009
My lacie external hd designed by porche endured a mains electricity failure.. All I get now is the small flashing light no clicking and the computer does not see the drive.. Prior to this we had two or...
the power circuit is most likely blown. You can buy an external hard drive case and put the hard drive in it. Be sure to buy correct size hard drive enclosure. The other way is to remove hard drive from external case and put into computer with a spare sata connection.
Feb 03, 2018 | LaCie (300740) 160 GB Hard Drive
Hi ,my name is sameer i have 120gb lacie external hard disk,but is not suporting usb cable how can i change case pls help.............
just open your external HDD case, look for the connector (SATA or IDE), so buy new external harddisk case according the connector type.
Dec 20, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
LaCie d2 200GB on my Pc (windows xp) via USB 2.0 doesn't show
the situation here is ahppening to all external sata or Esata drives what happens is the external closure has a usb controller when this dies the drive doesn ot spin up or does not reconise simple solution buy a external drive encloser and transfer the drive to it and that will work. thanks and please rate.
Nov 24, 2009 | LaCie d2 (300769) 200 GB Hard Drive
I'm running Windows XP professional. Have plugged in my Lacie d2 Quadra (500 GB). Device manager shows that it is working properly, but it is not initialized and it doesn't show up on my windows...
1.
log onto d computer as administrator
2.
start->my computer->manag
3.under storage->disk management
4.ef intialize ndcovert disk wizard appers click next ef not skip to step 8
5.on d selct to disk intialize page click next
6.on d select to disk covert page click next
7.on completing dhese two click finish
8.right click u r external drive nd click format
9.in d format dialog box type d name for u r external hard drive nd then click ok
10.click ok again
Sep 14, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Lacie 320gb external harddrive which was connected to an eMac and is now connected to an Acer laptop. I've reformatted it as NTFS and it shows up in disk management as healthy but does not appear in...
The drive letter and USB port are not inherently tied together. you can give it a drive letter as long as nothing else is going to use that letter inherently, and be fine. Did giving it "F" work?
Aug 28, 2009 | LaCie Hard Disk 320GB with Hi-Speed USB2.0...
Having a similar problem with the La Cie 500gb. Powerbook G4.
The problem that has been inherent with all LaCie external harddrives, is the interface in the case itself.
Interface:
All external harddrives have a Style of harddrive that is used in a laptop, or one that is used in a desktop computer.
Laptop harddrives are 2-1/2 inches across in width.
Desktops are 3-1/2 inches across.
Your LaCie will have a 3.5, (3-1/2) inch desktop style harddrive, inside the case.
There are two main Types of harddrives.
IDE and SATA. (There is also a newcomer. SSD. SSD isn't being used in LaCie external harddrives at the moment, to my knowledge)
Your LaCie will use a SATA harddrive inside it.
This is an example of an average SATA harddrive,
http://en.wikipedia.org/wiki/File:Hdd.jpg
The photo of this harddrive is tilted at an angle, that doesn't readily show the interface connection, but it helps to explain.
At the bottom of this harddrive in the photo, and to the left, is the interface area.
Viewing the harddrive, look at the four metal pins on the extreme right of the harddrive. To the left of these pins is the Jumper pin area. (Has a white jumper on two of those pins)
To the left of the Jumper area is an opening, and to the left of that, is a long slot. The first small slot area is for the 7-pin Interface cable.
(Data cable) The next slot to the left, is for the 15-pin power cable.
This 7-pin Interface mates up to socket holes in a connector, of the case of the LaCie external harddrive.
It is this interface connector, inside the LaCie external harddrive case, that is the problem.
Solution?
Buy a quality, in-expensive External Enclosure, take the harddrive out of the LaCie, and install it in this enclosure.
Examples of 3.5 Sata External Enclosures,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(From $15 to $35, is a good range for a decent external enclosure)
Jul 22, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Sometimes the hard drive will connect and sometimes it won't.
There have been problems plaguing the LaCie external harddrives, for quite some time now.
The issue directly relates to the interface, inside the external enclosure. I don't know if you are acquainted with harddrive designs, or the interface that they plug into. If you are, disregard the following.
This is an average example of an IDE harddrive, http://en.wikipedia.org/wiki/File:Hard_drive-en.svg
Looking at this illustration, note where it points to -> IDE Connector. The illustration isn't very good, but those dots are metal pins.
The connection inside your external harddrive,
that connects to the harddrive itself, is called an Interface. This is a plug that has socket holes, to match those metal pins.
Now we go a little deeper. There are two types of harddrives. One is an IDE harddrive, the other type is a SATA harddrive. Your LaCie
will have a SATA harddrive inside.
Instead of the 40 pins that an IDE harddrive has, the interface for a SATA harddrive has 7.
(It has 15 pins for the power connection)
Now my solution:
Should you wish to save data that is on your LaCie external harddrive right now, I suggest you buy an external enclosure, (SATA), take out the hardrdive thats in your LaCie, and install it in the enclosure.
Since, the dimensions of the, LaCie design by Porsche 160GB external harddrive are:
Height -> 1.4 inches, (About 1-1/2 inches)
Width -> 4.4 inches, (About 4-1/2 inches)
Length -> 7.4 inches, (About 7-1/2 inches),
I'm willing to bet the harddrive inside is a desktop harddrive size. (3.5 inches across in width)
http://www.lacie.com/download/datasheet/porsche_hd_en.pdf
These are examples of 3.5 inch SATA external enclosures,
(A $25 or $35 unit will work just fine)
Jul 18, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie 1tb external hard drive into ps3 is not regconised
I have the same issue, however with my verbatim 500g its ok. i believe it is because the lacie is a desktop external and therefore is compatable with windows xp and 7 alone.
Verbatim is a "portable" external hard drive which makes it compatible with several different systems. I would suggest returning it, I just formatted my old verbatim harddrive and set up mediaasharing. Through my router. You can actually route the lacie harddrive by going to my computer and right click the icon. Next go to share with; advanced settings and allow all. Then when you turn your ps3 on search for media servers... I would suggest to google media server for ps3 to get it all seet up. GOOD LUCK
Jun 07, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Is my LaCie External USB 2.0 500GB fried/dead???
You're not missing any step at all, because with SATA hard drive if its really working your computer should
automatically detect it and since this hard drive suddenly stop working there's a possibility that its already
fried but if you want you can try this hard drive again to a different computer and if still not detected by
second computer its already dead.........
Nov 07, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie Mobile 500gb not working
Just buy new external ( HDD ini is fine) just change the external for both off you
Dec 28, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
265 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
