Question about Microwave Ovens
Microwave doesn't start
  • Microwave Ovens Master
  • 9,047 Answers
This is usually due to defective door switch or door switch mount.
With your model number, we probably could have told you whether it it is the top or bottom switch.
Our help file on door switches is here.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Posted on Jan 10, 2013
Timer works & oven works but microwave doesn't go on
Most often this is a bad door switch or door switch mount.
See my help file on door switches here.
Mar 19, 2013 | Microwave Ovens
WHEN I USED MICROWAVE HAD BURNING SMELL & BLACK SOOT APPEARED. STILL HAVE POWER BUT DOESN'T COOK
Just had the same problem. It was an electrical short and the repairman said that it could have burned the kitchen wall and been a catastrophy. Get rid of it immediately!
Mar 02, 2013 | Microwave Ovens
Sharp micro doesn't heat
see this causes and fix it. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 02, 2012 | Sharp Microwave Ovens
Ge JES0738 LED display is fine but turntable doesn't work, microwave doesn't start. Is it a fuse issue?
No! from the description it is one of the door switches that has become defective. The solution, all the door switches need to be tested to find the bad one.
Jun 13, 2012 | GE Microwave Ovens
Electrical short /pop sound & now it doesn't heat. Everything else works. Any idea what went out.
The signs are not always evident, but from the description the magnetron has failed.
Apr 13, 2012 | Sharp R-1491 Microwave Oven
Khhc2090s trouble
The sensor errors are probably just from opening the door and interrupting the sensor cook cycle.
By the way, you should always press "Stop" before opening the door of a running microwave. Otherwise, the door switches will prematurely fail.
I would first check the door switches and their mounts. See this help file.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can also download manuals, installations info, and parts lists here.
dee77f7.jpgWe're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Nov 25, 2011 | KitchenAid Microwave Ovens
We have a sunbeam microwave. it starts but the light doesn't work and it won't heat the food. what should we do?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;'
Sep 01, 2011 | Sunbeam SMW750 Microwave Oven
What is the wattage on the sharp microwave model r-2a48?
http://www.sharpusa.com doesn't have your manual. But you can find it yourself on the
back of the unit - the wattage should be listed.
If only the amperage is given (you know the voltage is 120 VAC RMS), so using Ohm's Law, you can calculate wattage:
Watts = 120 Volts X Amps
May 13, 2011 | Sharp R-2A48 Microwave Oven
How to fix an Emerson microwave 8992RD that carousel doesn't turn and doesn't heat your food..
heatman101
May 08, 2011 | Emerson Black Microwave Oven
Microwave Ovens Logo
15 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
