Question about Kitchen Ranges
My amana range agr5715qdw will not stay light.
The oven takes forever to light.I tapped on the regulator and it would come on.I replaced the gas oven regulator and valve assembly but that did not solve the problem. The ignitor does turn on but i'm not getting gas
duby1990
  • 367 Answers
SOURCE: Replacing oven ignitor in Amana AGDS901WW
The ignitor can be replaced through the oven. When you take it loose, If you cant find the plug just cut the wires and wire nut the wires together with the porcelin wire nuts provided with the ignitor.
Posted on Nov 21, 2008
  • 4 Answers
SOURCE: Oven won't light unles you tap on bottom parts.
This might be grit or ash that might have found it's into the burner. When the gas flows into the burner has enough velocity to pick up and carry small debris to the inside of the openings in the burner. When you tap it the debris falls from the holes and gas can flow again. If you are on propane, it is common to have grit in the lines. Natural is less likely to have grit unless you have had construction nearby. Finally, does this system use a flame sense probe? If yes the sense probe might also be dirty and need to be wiped with steel wool (soap free)
Posted on Sep 19, 2009
  • 2597 Answers
SOURCE: oven wont light unless you turn on a stove eye and
did you slove the noise from the oven
Posted on Jan 13, 2010
  • 2597 Answers
SOURCE: Amana AGDS902SS Gas Range Oven. Replaced ignitor.
Hi not that i can think of try google the range see if they have problem with this range
Posted on Feb 09, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite gas range the oven burner doesnt light right
It appears your gas valve solenoid has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Testimonial: "thank you"
I have a Tappan gas stove that takes forever to heat up (oven) and I smell gas before it starts to heat. Help?
Thanks for answering my questions. It sounds to me like your oven's safety valve is going bad. There have been many times when I am at a customer's house and it has been a while since they used the oven, and it seems to take forever to light the oven. Just tapping the oven safety valve with a wrench or handle of a screw driver is all that's needed to open the valve and light the burner. As long as your oven's igniter glow bar is lighting, (glowing orange or sparking), then the oven safety valve is your problem. It is a silver rectangular valve in the far back bottom of the oven with the orifice on top of it and the burner tube coming down over the orifice. Try tapping it and see if that works. Otherwise, just have it replaced. Douglas
Jul 03, 2010 | Tappan TGF657 Gas Kitchen Range
Feb 08, 2010 | Amana AGDS902SS Gas Kitchen Range
Gas oven doesn't light ACS3350
While the ignitor is glowing, tap on the valve with the plastic handle of a large screwdriver. If the burner lights the ignitor is weak and needs replaced. If it does not the valve is bad and it is advisable to change the ignitor also although not required.
Eric
Aug 28, 2009 | Amana ACS3350 Gas Kitchen Range
My Amana gas range's oven door will not stay shut. It is not snug against the oven. Repair says I need new hinges. Are they easy to replace?
they're not too bad, you may need to take apart part of the door to remove the hinges, just remember where everything goes as you take it apart. bring the door to the first stop, then bring the hinge pin locks into place to secure the door hinge lock, then remove door, or just slide the door up. then replace the hinges as needed.
Jul 09, 2009 | Amana ACF3355AS Gas Kitchen Range
Oven not working properly
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Nov 29, 2008 | GE JGRP20 Gas Single Oven
Oven wont light
My Amana oven will not light, the electric ignitor comes on, but it will not ignite the burner for it to come on. What do you think the problem may be?
Jul 22, 2008 | Ovens
Problem with oven preheating
Hi, I'm Neil
It is a fire hazard! Be Careful!
It's a gas regulator or thermostat
This time you will have to call the the manufacturer for service!
If it's under a year old ,your under warranty and it will not cost you anything!
Please give me a solution rating here!
Thank You
Neil
Jul 14, 2008 | Maytag MGR5750 Gas Kitchen Range
Oven temperature
Replace the bake igniter in the bottom of the oven. It corrodes over time and as the resistance increases it finally reaches a point where the voltage is two low to open the gas valve. It's a ten minute job and the part cost $45-65.
Jan 22, 2008 | Amana ARGS7650SS Gas Kitchen Range
GEXL44 RANGE FLAME PULSES
sounds like the regulator.look at it and see if it has a nut on it.if it does remove the nut and turn the unit on.if the problem cleared up clean out the nut (its called the vent and theres a little ball inside) if it doesnt work replace the regulator.if the units propane make sure all the burner orfices are cleaned.propane burns dirty.
Sep 25, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
23 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
