Question about Infinity RS-8 Speaker
Rs-8 overheat I have an old pair of these that I just pulled out of storage. One of them does not work in that the 8" sub is not working and the little green light on the front never turns green, but stays red when plugged in. I have read that there is a faulty part in the amp or crossover that overheats, and sure enough, when I open up the speaker back panel, it smells hot. Also, the other speaker that does work, the sub will shut down after being driven hard after being on for a while. Anyone have info on what part to replace and how to do it?
  • 417 Answers
Http://www.ebay.com/itm/Infinity-RS-8a-Speaker-Subwoofer-Amplifier-Plate-Repair-Service-/261031840606
Posted on Jan 11, 2013
  • rc Jan 11, 2013
    hope this helps, and it is the right direction to go in. Read his ad carefully.
SOURCE: bypassing the 150 watt blown amp with passive crossover
3/4 update: i bypassed the 300w amp on my first ovtr3 with a cs3006 crossover i purchased on ebay. the input wires at the base of the speaker were connected to the input of the crossover, the bass output of the new crossover was connected to the yellow/yellow-black lf+/lf- wires that used to leave the old 300w amp. the high freq output of the new crossover was directly connected to the leads coming from the speaker's tweeter (running the midfreq outputs from the new crossover to the input of the speaker's old crossover is no good, since the midfreq output of the new crossover would rolloff and provide little high freq to the tweeter). The mid-freq output from the crossover was connected to the input of the old crossover that came with the speaker (alternatively, i could have wired the mid freq output from the new crossover directly to the midrange speakers, but i figured the old crossover might have had some characteristics that would have been helpful. the result is better than i hoped for! true, the bass is not quite as floor shaking as before (and you need an amp that can boost +5-+10db below 350Hz and rolloff the boost above 350Hz), but the end result is more than satisfying and gives these speakers new life. I am using a Sony receiver that puts out around 200W for the front speakers.
Posted on Mar 04, 2008
SOURCE: Infinity Entra Sub 150 no sound or power
I had the same problem. When I opened it up, the fuse was blown, and it was a pain to find the fuse it needs (3 Amp, 250 V slow-blow fuse, 5x20 mm). Also, the 2 large electrolytics (big purple things near the amp) and one small capacitor were all blown. For 4 fuses, bought seperately from, and the 2 electrolytics and 1 capacitor, it cost about $20, plus almost 20 more in shipping, which still isnt bad considering the original price of the sub. However, the tricky part is that you have to know how to use a soldering iron to take out the old components and put in the new ones.
Posted on Mar 23, 2009
SOURCE: PS-212 Suddenly stopped working
I HAVE 4 PS212 AND FROM WHAT YOU ARE DISCRIBING SOUNDS SIMILIAR TO WHAT HAPPENED TO ME. PLAYING THE SUB AT FULL VOLUME AND CLIPPING OCCURED NOT KNOWING THAT THE FAINT SMELL WAS THE VOICE COIL BURNING AND CONTINUING TO PLAY UNTIL KNOW SOUND LESSON LEARNED BUY A BIGGER SUB SYSTEM OR REPLACE YOUR SUB WOOFER.
IN MY OPPINION THIS IS A VERY GOOD PRODUCT WHICH I HAVE BEEN ABUSEING FOR MONTHS . SO QUIT WHINEING AND PAY YOUR DUES.
Posted on Nov 09, 2009
SOURCE: Replacement parts for Infinity TSS-1100 subwoofer.
Same issue here. 3 years without problems then the burning smell and finally it died. I've removed all of the screws from the back but haven't had success opening the unit. Anyone figure out a solution to fix the circuit board?
Posted on Mar 30, 2010
SOURCE: My infinity overture 3 crossover
This is a 3-way speaker; specifically which speakers do you hear something from and which speakers do you hear nothing from? If the woofer amplifer is blown, for example, you will hear nothing from the woofers, but will hear sound from the midrange speakers and the tweeter.
Posted on Apr 08, 2011
Please how do i connect a pair of F1 Bose 812 speakers and Subs to a Behringer PMP6000 mixer?
Watch your impedance, when you add speakers the impedance will change. example 8 ohm speaker placed in parallel with another 8 ohm speaker the impedance is 4 ohms, placed in series the it is 16 ohm Me I would place in parallel this mixer should handle 3 ohms
kqaaaabjru5erkjggga=
Jun 05, 2018 | Behringer Music
I have Boss ar2400 4 channel amplifire.. I had connect two 15" kicker subs in bridge circuit. When i run the system it gets overheat in half an hour and goes into the protection mode. How can i solve this...
Problem is one of four things:
  • Impedance (ohm resistance) of the speakers you are using is below the amplifier's rating for operating in bridge mode;
  • You are driving the speakers at a volume exceeding the maximum power output of the amplifier;
  • The gauge of the wires you are using to connect the amplifier to the speakers is too small;
  • The gauge of the power supply wires is too small, and/or you are not using a large enough reserve capacitor at the power input
Possible solutions:
  1. If your Kicker subs are rated at 4 Ohms, and you are using them in monoblock configuration with the speakers wired in parallel (all + terminals to the + bridge output and all - terminals to the - bridge output), try either configuring your bridge circuit in a paired bridge, where a pair of amplifier outputs are bridged, each bridged pair driving a single speaker; or if your Kicker subs are rated at 2 Ohms, use a monoblock bridge driving the speakers in series (+ bridge output to + of one speaker, - of that speaker connected to the + of the other speaker, and = of that speaker connected to - of the bridge output);
  2. Turn the amplifier output down (but this is likely NOT the issue)
  3. Use speaker wire that is no smaller than 8 gauge for your application. 4 or 2 gauge wire would be slightly better but not worth the additional expense;
  4. Your power supply wire should be equal in size or larger than your speaker connector wire. Use no smaller than 8 gauge for your application. Also, use a capacitor no smaller than 2 Farads wired across the power supply input to the amplifier to compensate for pulse surges and car power dips. For your application a large capacitor will work better than an auxiliary battery or gel cell.
May 26, 2014 | Car Audio & Video
Got a pair of Infinity RS-8b. They are missing the middle speaker. What should I replace it with?
I got a couple of answers:
http://www.speakerrepair.com/page/product/home-audio-tweeters/10-236.html
http://speakers-parts-tools.info/tag/infinity-speaker
Jan 12, 2013 | Infinity RS-8 Speaker
Hello there! I have an 8-10 yr old Bose Accoustimass 10 speaker system connected to an Onkyo TX-DS595 receiver. After moving and setting up my system the Bass Module has almost no base coming out although...
What is your crossover setting set at?
If it is set at 40 HZ, this would explain weak bass; as that Bose system sends ~120HZ down to the sub.
I reccomend checking the crossover setting to 120 or 100; with all speakers to small.
You may need to increase the db setting on your sub as well......
Good Luck.
Mar 24, 2011 | Audio Players & Recorders
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
The subs dont work amp makes a humming noise when i plug ut in
Hi
It's either connected wrong and there is an open ground or an IC has gone bad in the power supply. Check your connections first, then a reputable repair person can help.
Aug 12, 2010 | Infinity RS-8 Speaker
Good price
Hello smoot_dog,
Well, you did not specify whether you have the 2 ohm or the 4 ohm versions of the L7 and that will impact your choice of amps. But with 8 voice coils and 4 subs to work with, you certainly have lots or potential configurations.
If your subs are the 4-ohm version, I would recommend the Alpine MRP-M1000. Currently it is on sale at www.crutchfield.com for $347.00. With this amp you'd wire the voice coils in parallel (2 ohms), wire each of the 2 pair of subs in series (4 ohms), and the resulting pairs parallel to the amp for a final load of 2 ohms.
If your subs are the 2-ohm version, I would recommend the Rockford-Fosgate Punch P1000-1bd which is stable at 1 ohm. Crutchfield sells it for $349.99. With the Punch and 2-ohm voice coils, you'd series the voice coils (4 ohms), parallel each pair of subs (2 ohms), and then parallel the resulting pairs to the amp for a final load of 1 ohm.
Either of these amps will provide an honest 250 watts RMS to each L7. They'll not only rock your vehicle, they'll rock the pavement.
Apr 14, 2009 | Car Audio & Video
Vb variable error
Change the code:
strdbname = "d:\vivek\company.mdb"
Set DB = DBEngine.OpenDatabase("D:\VIVEK\COMPANY.MDB")
strrsname = "company"
Set RS = DB.OpenRecordset("COMPANY")
comp.Text = RS!COM_CODE
compnm.Text = RS!COMPANY
isinno.Text = RS!ISIN
AD1.Text = RS!ADD1
'AD2.Text = RS!ADD2
'AD3.Text = RS!ADD3
AD4.Text = RS!ADD4
BK.Text = RS!BOOK
'PG.Text = RS!Page
to become:
Set DB = DBEngine.OpenDatabase(strdbname )
Set RS = DB.OpenRecordset(strrsname )
AD1.Text = RS!ADD1
AD2.Text = RS!ADD2
AD3.Text = RS!ADD3
AD4.Text = RS!ADD4
BK.Text = RS!BOOK
PG.Text = RS!Page
mostly to eliminate the extra "quote" (') characters,
and to use the values you set.
Dec 10, 2008 | Computers & Internet
Infinity RS-8 Speaker Logo
254 people viewed this question
Top Infinity Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Craig Butler
Craig Butler
Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
