Question about Dell E153FP 15" LCD Monitor
E153fp high pitched sound when on
This monitor has troubles turning on (especially when cold) the green light will turn on for a fraction of a second, then the unit will turn off, wait about 10 seconds and try again. This will happen over and over again, until eventually (I guess when it is warm enough) it will display images and not reboot. However when it is on it produces like a high pitched scratching noise coming from the top of the rear of the monitor. This area also gets very warm. Do you think it is the bulb on the top of the monitor, or is it another issue?
  • 3,940 Answers
Sounds like the LCD or the inverter are failing. Generally cheaper to replace than to fix
Posted on Jan 21, 2009
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
BLINKING GREEN LIGHT
You have shorted out transistors in the backlight inverter circuits.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd: www.lcdrepair.us
http://www.electronicrepairguide.com/dell-E153Fpc-lcd-monitor-repair.html
May 30, 2010 | Dell E153FP 15" LCD Monitor
Monitor light flickers on orange never goes to green.
Sir,
You are suggested to check if you serial cable is in fine condition and it properly pluged into the Monitor and VGA. and do also try changing the serial cable .
Aug 30, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Aug 29, 2009 | ViewSonic OptiQuest Monitor
VSX 7000 doesn't come on
If you still have an issue and the unit is out of warranty , give us a call at 415.637.9989 and we will see what we can do. DAVID
Feb 14, 2009 | Polycom VSX 7000 Video Conference
Dell e770 Monitor
It sounds like the picture tube in the monitor has burned out. Time to replace.
Feb 03, 2009 | Dell E770 Monitor
E153fp goes dark into power save mode after Windows start up
may be your power saving option have small time .
check in control panel power option check power shemes.set it to 20 minutes.
Nov 27, 2008 | Dell E153FP 15" LCD Monitor
Trouble turning on tv. High pitched noise/click.
The mainboard might have some loose components, or cold solder , or may be the filter capacitors are becoming faulty. Yes it is worth repairing, bring it to the repair shop. Cheers.
Nov 25, 2008 | RCA Televison & Video
High pitch pulsing & picture now
I would check the set for bad connections. The high pitched sound you are hearing is the high voltage section. If the convergence IC has completely failed, that can cause this as well. Try using STK392-150 or STK392-180. Either one will sub since they are pin compatible and they both can handle more power, thus should last longer. Also, make sure that you use plenty of the heatsink compound when mounting these.
Dan
Jun 26, 2008 | Philips 43PP9202 43" Rear Projection...
Screaming acer!
sometimes if the inverter board (the part that drives the backlight) has a cold solder joint on it, it can actually generate a high pitched resonating sound (aka a screaming squeal sound)
if it's under warranty, have the manufacturer correct the problem.
if not under warranty, retouch the solder points on the inverter board, or have a repair tech fix it for you.
Jun 03, 2008 | Acer AL1916W 19" LCD Monitor
Dell E153FP 15" LCD Monitor Logo
95 people viewed this question
Alun Cox
