Question about Sansui Televison & Video
For21 ultra slim CTVSDS21SBB-CUB TV FALT
NO PICTURE ON RF SCREEN OK & AV OK
CrazyLarry
  • 173 Answers
SOURCE: inputs
learn lip reading..... but really 1080i inputs have to cut main circuit and be processed through your main amplifier .
shorted or too low a signal at input is a start.
Posted on Jan 19, 2008
jingjao
  • 252 Answers
SOURCE: SANYO TV MODEL CM20SP8S CHASSIS AC3-A20
try to fine tune your tv using the remote control, or, if you had knowleged in electronics adjust the sound IF transformer using a wood stick or plastic don't use a metal in adjusting the IF
Posted on Oct 10, 2008
  • 18 Answers
SOURCE: TV picture rolls on AV input, but picture fine at RF input
u change the colour system 2 pal
Posted on Dec 26, 2008
Mas Baz
  • 177 Answers
SOURCE: hi my tv is ultra
hello, I think that problems occur because the connection that has been cracked. If you have experience in electrical, resoldering on the pcb crt and vertical ic area.
good luck.
Posted on Mar 24, 2011
TODDAS
  • 431 Answers
SOURCE: My LG Super Slim 29"
You don't have a deflection yoke problem, you have a pin cushion problem. Check the pin cushion transistor.
Posted on Nov 14, 2011
Lg tv ultra slim picture size veri small and sound ok
show me the picture than i can tell you the exact problem and its solution
Feb 16, 2015 | LG Televison & Video
Rca picture
Very bad symptom indeed.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations.
Aug 12, 2014 | RCA 42" LED42C45RQ Class LED 1080p 60Hz...
Lg ultra slim 21 tv sound picture power
ok ur tv powersupply is ok but horizantal is not working chk ur fbt hot & micronass
Mar 21, 2014 | Televison & Video
I'm trying to hookup my Toshiba DR430KU to an older tv that require an RF Modulator. I get a skewded sideways picture. Does This DVDR compatable with a RF Modulator?
Probably not. Better picture results are achieved with either S-Video, standard RCA AV cable (yellow-white-red), or YUV component cable (red-green-blue) (component output does not have audio - this requires extra cable to be connected). The video via either one of these 'AV' connections is stunning (based on a standard 16:9 LCD TV using a Panasonic DVD recorder).
RF tends to be lower quality - as opposed to AV/digital input. AV input/YUV component handles digital better. No one connects their DVD devices to their TV via RF (either directly to the antenna socket or with a modulator/attenuator) anyway. Because a VCR is mostly analogue, it will work fine with an RF connection, but DVD is digital, and so won't work as well, if at all.
RF also goes through the tuner in a TV, creating cross-interference, whereas AV is a direct input and is separate to the tuner.
I would say an RF modulator would not be designed to handle the output frequency that your DVD device generates. Throw the modulator out, or perhaps get another TV, or use RCA cables instead if the TV has AV inputs. Whichever is cheaper and easier, but don't use RF accessories except a standard antenna if/as required.
Apr 27, 2011 | Toshiba DR-430 DVD Recorder
Sony KV- 20FV12 get no signal on screen. Same cable outlet works on other TV as a test. Cable ON in menu. Auto Set search produces search but still no signal.
Hello
If auto search is going on smoothly, and there is no stations on air is memorized, and display no signal, there are tow possibilities. The first one is antenna is not connected properly. Check the antenna connection for firm. The second one is tuner fault. If the tuner inside the tV is faulty, or it does not gets proper voltage to work, this type of fault land display will see on screen. Check if proper voltages are comming to the tuner section in circuit board. If voltages are ok, and still there is no signal display, just check it with external video input. That is, connect it to any dvd or cd with AV connector, and set the TV to AV mode and play a disc. If there is picture, the video side of your TV is OK. If not, Video-chroma-RF jungle IC is faulty, and not the tuner. OK.
Feb 03, 2011 | Sony KV-20FV12 20" TV
Receiver for my RF wireless deskset is flashing constantly
If the mouse and keyboard are working, and the receiver is still flashing constantly, then it's probably just indicating that the receiver is connected to the keyboard and mouse.
Jul 06, 2009 | Micro Innovations PD7250LSR Wireless RF...
#27PT543S37A philips tv model-the tv video channel is not working
In short your tv has a problem on the AV connection, RF using coaxial cable is working okay.
get the tv to the w/shop, let him check the AV panel and AV processing IC.
Apr 30, 2009 | Philips Televison & Video
No picture on VCR/DVD
Try to use AV cables they work better than RF cables in my opinion. AV out to TV in works everytime.
Nov 13, 2008 | Curtis DVD-7600 DVD Player/VCR
Televison & Video Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
