Question about E-Machines Computers & Internet
Hardrive don't start
Barracuda hardive 160 gig. Has ben running fine. I did though just reently watched a movie on potluucker which is new to me. Comp makes no beeps
  • E-Machines Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 10, 2013
2 Suggested Answers
My dell laptop is very slow, I can't watch a full movies on it cos it keeps breaking out. Could anybody help me solve this problem
I would start by downloading free CCLEANER at :http://www.filehippo.com/download_ccleaner/ Install and run. The scan will clean the junk from your system. Also there is a section TOOLS , STARTUP, to disable programs from starting at windows boot. ANOTHER program MALWAREBYTES FREE at :http://www.filehippo.com/download_malwarebytes_anti_malware/ Run A FULL SCAN delete ALL results. I don't no the model of you DELL so I don't know the specs. But you want to disable ALL programs not needed . In Services you can disable Windows Search, a memory Hog. Only you can choose the programs that are not needed, I have no clue what is on you machine. Take a look at this for tips: http://www.pcmag.com/article2/0,2817,2364937,00.asp
Nov 19, 2012 | Computers & Internet
What's2012 nissan quest sl code to bypass parking brake your problem?
That is completely DANGEROUS and ILLEGAL...sorry, no code here....I don't want to be your victim when you decide to run sombody over while you are watching your movie! And I sure do not want to be the one that makes it possible for you to run over somebody else...TURN THE TV OFF AND DRIVE!!!
May 04, 2012 | 2012 Nissan Quest S Passenger Minivan 3.5L...
How can i get my toshiba satellite not to go into standby while watching movies
To keep your laptop from going into standby mode you want to change the power settings. To do that, click on the start button/windows logo to open the start menu. Then click on control panel, or if you do not see it start typing control panel. Then go to power settings. You then need to change the advanced power settings for your battery options. Change the power settings so that it does not standby at all. Another thing you can do is plug the power cable in and that way it also will not enter standby mode.
Thanks for using FixYa!
Jul 11, 2011 | Computers & Internet
Segate portable hard drive 500 gb not able access
is the computer see ing it if not ,unplug run computer then turn off re plug in and computer should see it with its plug and play system
Jul 06, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Problem hardrive barracuda 7200.7 160G: the led
I am thinking external HDD?? Bad power supply or check the connection.
Jul 19, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
HDD upgrade for compaq evo n610c
i have a compaq evo n610c with a 160 gig hardrive and a gig of ram a bluetooth top adapter and installed a wireless card with antennas it works fine and reads the hardrive fine and i get the 158 sumthin sumthin gigs that it alwase turns out to be the fans a going harder thoe thats bout it and the batt dies sooner
Nov 27, 2008 | Compaq Evo N610C Notebook
How to install seagate ata IV hardrive
The easiest way to upgrade from your old HD to the new 40Gb HD is to clone the old to the new. Do a google for "hard disk clone" freewares. Personally I use Partition Magic and have had very good results.
Hardware wise, you need to install the 40Gb as a slave to the old HD by connecting the same IDE cable as that of the old HD (you may have to remove your CD/DVD temporarily). You also have to temporarily remove the single jumper of the 40Gb to allocate it as a slave to the primary master (old HD). Plug in likewise the 4 wire power connector. On power up go to your CMOS/BIOS setup to verify that your PC autodetect the 40GB (you may have to do a manual detection). Boot your PC and go through the normal boot sequence. Thereafter download your clone software choice, install and run. Follow on screen instructions. You may need to reboot. After completion, use Windows Explorer to verify that everything has been copied. Power down, remove the old HD, relocate IDE cable connector of the old HD to the 40Gb, reconnect your CD/DVD, and place back the jumper of the 40Gb. On popwer up go again to your CMOS/BIOS to verify that the 40Gb & the CD are detected. Save & exit, reboot.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 18, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
No power on psu when Hardrive connected
Yes, I actually experienced it too about 2 months ago. I believe there is short in the board. I have a 200gb barracuda that failed (too soon) and I swapped the boards...just to see what would happen. I was able to recreate the other drives problem and vice-versa. I think if I could get my hands on a working barracuda(if there are any) I could recover my info. curse of the 7200.7's Good Luck, Tim
Feb 13, 2007 | Seagate Barracuda 7200.7 40 GB Hard Drive
Computers & Internet Logo
21 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
