Question about HP Compaq nx6310 Notebook
I have 2 x 2gb ram, and can't find 2nd slot for one of them
Hi all, i just inserted the first 2gb of ram, and laptop is running bit smoother, i have another 2gb ram, but i do not know where to insert it as there is not a spare spot in the ram installation slot thingo.. Does anyone know where the slot where the original ram is (500mb ram).
cheers
  • bill_peterso Jan 21, 2009
    ok and that means i'll have to open the whole laptop up i am assuming. I looked up my computer specs, and it's maximum ram is 4gb, and it says has more than 1 slot for memory. Anyone have a guide or anythign for me to insert this second lot of ram.
    Thankyou alot Mike, appreciated lots
    cheers
    Genius:
  • 1,019 Answers
if you only have 1 slot, on the underside of the laptop.
it,s most likely, if there are any more slots, they,ll be under the Keyboard.
This will possibly be, where the 512 mb is now, although some laptops do have on-board memory chips from 256-512mb. ( try under the Keyboard )
Mike @ compurepair.
Posted on Jan 21, 2009
How can i use the 4GB ddr ram? still on 2GB while it has 4GB.. it said that only 2GB usable.
The 2nd 2Gb RAM module may be faulty or not compatible with the other RAM module.
Try inserting one RAM module in the notebook at a time to determine which RAM module is faulty.
If both RAM modules work then make sure both RAM modules are the same make and speed.
Jun 30, 2011 | Toshiba Satellite L505ES5034 Notebook PC ...
I have a lap top Dell Precision M20 and replaced the old ram from the slot below the keyboard with 512 MB by a new with 1GB. It worked fine! Since I bought two times 1GB, I inserted also the second in the...
these different ram slots have different bus speed so they really don't work if you are using them both at once.
Please check your laptop's documentation about the speeds of these ram slots.
Dec 27, 2009 | Dell Precision M20 Notebook
Is it possible to install high desnsity memory RAM on a T42
The T42 can support up to 2 Gb of RAM.
The laptop comes with 512Mb of RAM under the keyboard and a spare memory slot on the bottom of the laptop.
To install 2Gb of RAM put 1Gb in the memory slot under the kerboard - need to remove the old RAM and put the other 1Gb in the memory on the bottom of the laptop
T42 Memory specs.
  • 64-bit Double Data Rate (DDR) non-parity SDRAM memory
  • PC2700 at 333MHz
  • Two 200 pin SO-DIMM memory slots, one slot is pre-populated with 256MB or 512MB, leaving one socket available
  • Supports up to two 1GB SDRAM SO DIMMs
  • Supports maximum memory up to 2GB
Sep 22, 2009 | IBM ThinkPad T42 Notebook
I want to change the 2 x 512DDR ram by 2x 2GB DDR ram memories in my A205-S4577/Toshiba. Will it work?
hi,
it will work as your notebook is supporting maximum 4 gb RAM but please check that you are using 32 bit operating system or 64 bit one.
If it is 32 bit then the system will be showing 3.2 gb RAM only as this is the 32 bit os limitation.
Jun 03, 2009 | Toshiba Satellite A205-S4587 Notebook
Just tried running restore and now have blue screen
Compaq are a bit fussy with RAM and usually don't like mixed RAM - brand, speed, & sometimes size.
You model may not support more than 2GB, check the specs..
Try inserting a single 2Gb RAM to see if it works.
If it dosen't work and the laptop won't support more than 2Gb, you may need to install two 1Gb RAM modules.
May 20, 2009 | HP Compaq Presario C500t Notebook
New ram installed, but computer screen doesnt work
if your laptop working fine before install ram so that there should be problem with your ram only
check both rams are in same fsb there is no mater of capacity of ram (ie:512mb or 1gb)
like pc-2100
pc2200
or 667
both rams are intall in same fsb on both slots.
Jan 21, 2009 | HP Compaq nx6310 Notebook
Installing 2GB of memory in my Fujitsu Siemens Amilo Pro V2020
Here is the problem, the laptop take 2GB RAM. 1GB in each slot, so get 2X1GB RAM. They are cheap now. You need 2, 1GB sticks of ram. For cheap prices go to Newegg.com
Have a nice day!
Dec 22, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Problem with DG31PR while loading windows 2003 server with 4gb ram
You MUST run a 64 BIT if you want to run anything more than 3 Gb of ram ( such as windows xp 64 BIT , Vista 64 BIT , or even winows 2008 server 64 BIT ) Windows 2003 does NOT support 64 BIT ....
Jul 29, 2008 | Intel DG31PR Motherboard
IBM ThinkPad T40 2GB Max RAM
The T40 has two ram slots, you can put a 1g chip in each totaling 2g. If the chip will remove, then it is changeable. Vista needs a minimum of 256 to run, so, when you change BOTH chips to equal 2g it will probably read 1.744g, or it may read the full 2g. If it only reads 1g, then the second slot under keyboard may have malfunctioned. It could also be that the 256 chip is bad and your really only running 512 now. With all that said, in order to achieve 2g, you will need to put a 1g chip in each slot.
Jul 08, 2008 | IBM ThinkPad T40 2373 Notebook
HP Compaq nx6310 Notebook Logo
191 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
