Question about Canon i860 InkJet Photo Printer
Won't print on normal paper
My printer won't print using Plain Paper and Standard or Draft selection. When I try to print a typical paper document the pages emerge with few or no characters printed. I first attempted to address the problem by changing all my ink cartidges and running all the maintenance processes. Seems that if I select special media options (e.g., Photo Paper Pro) and select print quality "High", then I get a nicely printed document. Any suggestions of how to fix my Canon i860 so I can print "plain old" documents again with regular media and print quality selections? Thanks!
  • Bishop Dave Dec 19, 2007
    Cannon i850 wont print draft black - ok with colours. Black ink is not going down despite multiple deep cleans whereas colours are used proportionate to cleaning cycles. This is with a NEW PRINTHEAD! (all inks are brand new too).
  • jdcarino Dec 28, 2008
    My Canon i860 won't print on Plain Paper but works fine on higher resolution paper settings. I have done head cleaning several times but the problem persists.
  • Canon Master
  • 705 Answers
Refer to my previous post about manual under head cleaning and follow the routine through. This will most likely get you going as sounds like classic blocked nozzles. http://www.fixya.com/support/t137335-problem_print_outs_from_printer
Posted on Jul 13, 2007
SOURCE:
Hi . i have a ep1054 and print veri light , i want change to dark
Are you printing in "draft" mode? That is always light. Try "normal" or "quality". Also make sure you have selected the correct paper type. "Plain paper" is what most paper is. Photo paper is quite different, and photo paper setting will not work correctly on plain paper.
May 09, 2015 | Office Equipment & Supplies
Do I have to have a color cartridge in order to print? Can I just use a black ink cartridge?
The HP DeskJet 6122 can print with both or only one ink cartridge installed. The printer driver includes an option to print in gray scale as a substitution for color. If you choose to print a document that has a color other than black and white with only a black cartridge installed, I recommend you select the gray scale print option. To select gray scale, select the printer properties and check the box for gray scale rather than color printing. This selection can be made either at the time a document is ready to print (ie., a one time selection, using the "Properties" box in the print options window), OR as a permenant setting using the Control Panel, Printers, HP DeskJet 6122, "Properties" window. Once changed in the general printer properties, these settings remain active anytime the HP DeskJet 6122 printer is selected to print a document.
Sep 03, 2013 | HP DeskJet 6122 InkJet Printer
Printer does not print color photo greyscale
You will need to get that color cartridge. When printing a photo the printer will pull from both color and black to make a grey scale picture
Sorry
Feb 19, 2013 | Office Equipment & Supplies
How to make the HP Deskjet 3054 Print in only black
Select 'Print' from your software package and then 'Preferences'. Select the 'Color' tab, click on the 'Print in Greyscale' box and select the 'Black Cartridge' box..
Jul 13, 2011 | HP Officejet 5610 All-In-One InkJet...
If the black ink runs out does the printer automatically use color ink to print black?
Hi. When you are printing in black but "black and white" is not selected in the printer "properties", the printer will use some of your colored ink to print grays. If the black ink goes out, it will give you an error and will not print using colored ink even if you are printing black only. Hope this helps.
Feb 03, 2011 | Canon PIXMA MP210 InkJet Printer
I have an Canon Pixma Mp 496 can i know how much documents can i print with it in fast mode. and also the capacity of those two cartridges
Well, here's what Canon says. In my experience, you can expect to go through a black cartridge in about 500 sheets of paper, less for the color. Our Canon uses ink quickly. The printing speed is pretty fast for a printerthat is for black-and-white documents around 8.4 ipm and a color document printspeed of about 4.8 ipm. While for 4R size photo print takes about 43 seconds.Canon PIXMA MP496 resolution of 4800 x 1200 dpi for (max). It is said the all-in-one, because already integrated between print, scan and copy. For copies, this printer has a speed of around 7.6 cpm for black and white documents, while for the color is obtained at about 2.6 cpm.
Oct 22, 2010 | Office Equipment & Supplies
My printer will not print in black. It will use the other colors, but not black. When I try to print a black and white document, it prints in blue.
if u want to print selected document in black than open the document select print go to printer properties select grayscale printing
always print in black
go to printer properties than go to maintenance than go to ink cartridge setting select ink cartridge black only for balck and white printing only.
OR
CHANGE CARTRIDGE
Jun 18, 2010 | Brother MFC 240C All-In-One InkJet Printer
Canon mx310 how to print color document in black
When you go to save it or just before that you select file then go to print properties under that there should be a selection to print it in black and white.
Let us know ether way but its done under printer properties.
Thanks and please do be considerate that we are trying to help when you leave your positive ratings and feedback, thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 26, 2010 | Canon PIXMA MX310 All-In-One Printer
I have it set to print in black only but it uses up the color ink anyway. What gives?
On the printer driver, (after click "print" and the menu for selecting the printer appears and you can select the number of copies etc...go to"properties") . Here go to the "Color" tab.. if you truly only want to use black ink, then select "Print in greyscale" and select "Black only". After that just Click "OK" at the bottom and "Ok" to print your job in truly just black ink. :)
Cheers, Ed
Nov 22, 2009 | HP Photosmart C6180 All-In-One InkJet...
Wrong colors when printing on photo paper
yha way not
if you worry about wrong colors
it is possible you 3 colors cartage has mis a color it is maybe red,green,are yellow, refill your cartage and print again
Dec 16, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon i860 InkJet Photo Printer Logo
157 people viewed this question
Clive
Clive
old marine
old marine
Ekse
