Question about Dell PowerEdge T300 Server
Configure Dell Poweredge T300 to boot from optical drive
I cannot have the BIOS menu to change the boot's configuration
  • amir_layes Jan 09, 2013
    I have the bios menu but i have not Optical drive on my Boot Sequences .. it may not be a problem of SAS/Bios Integration ? my bios version is 1.4.6
  • Dell Master
  • 2,878 Answers
BIOS must see the optical drive. Re-seat / attach drive if it does not. The other option is to use another drive.
Posted on Jan 10, 2013
  • amir_layes Jan 10, 2013
    Thx a lot for your comment .. but it seems be well attached to the motherboard ! But , are you sure that with the 1.4.6 version of Bios manager we can boot on CD even if the computer is old ?
  • amir_layes Jan 14, 2013
How can i istall windows server 2000 on Dell Poweredge T300
Windows 2000 is not supported on this machine. The closest you could get is using a hypervisor XenServer or VMWare ESXi and then installing Windows 2000 on a virtual machine.
Jan 26, 2015 | Dell PowerEdge T300 Server
My dell poweredge 2600 wont load up
  1. Can you access the Bios configuration on boot by pressing F2? Check the setting
  2. By load up do you mean your server software does not boot? use F10 on post from the utility partition main menu under Run System Utilities.
  3. Is the server working with RAID? Press CTRL + R and check the RAID
I am not going to say check all the cables because I am sure you will have already?!?
Aug 21, 2013 | Dell PowerEdge 2600 Server
Dell T300 memory config error
Verify size and type off memory. Also the slots used are a variable. There should be DIMM configuration table on the removable panel or better yet look for the manual.
Mar 15, 2013 | Dell PowerEdge T300 Server
Nic teaming on poweredge t300
NIC teaming is useless unless you have a switch that support teaming.
However, Dell servers have free lifetime phone support ((800) 945-3355).
They should be able to help.
Jul 26, 2010 | Dell PowerEdge T300 Server
Dell Poweredge 4300 will not boot up after cmos battery replaceme
Configure your System bios and reboot. Your Hard disk drive was not configured. Pl configure. it will work properly
Aug 22, 2009 | Computers & Internet
Dell Poweredge 4300 Bootup problem after cmos battery replacement
Check the version for the Raid Controller. This may need to have the firmware to be upgraded. If the controller is removable, take the controller out and then see if the computer will continue past the bios. If the controller is built-in, then disable it in the bios, and try to see if it will get past the controller setup.
On most system I have worked with, if you are booting from a scsi hard drive, then the bios cannot be set to let any IDE to boot, or the bios must be set to no hard drive to boot. There may be two places in the bios which must be set to no hard drive. Another setting which may make a difference, is the scsi boot setting, if it has it. Another chance is that something is wrong with either the cabling or the controller itself.
As far as the jumper, that may be the erase bios jumper. Usually though, you have to move the jumper to one of two, sometimes three or four jumper. You would simply move the jumper to the erase setting, and then move it back. However, by doing that, you will lose all setting which had been set. Also, if the computer will go past the bios when the controller is removed, that could also mean some thing is wrong with a drive, or the boot drive is not set right in the controller bios. If a scsi drive is a boot drive, that boot drive number must be set right in the bios of the controller.
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
The aid hard disk in the containers cannot be found by the system
MAYBE YOU LOST YOUR CONFIGURATION BUT DO YOU SEE THEM UNDER PHYSICAL VIEW IN THE CONTROLLER BIOS?AS IT BOOTS DID IT REPORT THE CONTAINERS OR NOT POWER DOWN UNPLUG POWER CHECK THE CABLE ATTACHES TO THE BACKPLAIN, POWER UP,,,,,,GO INTO THE [PERC BIOS UNDER MANAGED CONTAINER VIEW .(A EASY WAY TO CHECK THE CABLE IS ... IF YOU HAVE A SPARE DRIVE YOU CAN PLUG IT TO THE CONTROLLER MAKE SURE TO PUT POWER TO THE DRIVE IF YOU SEE THE DRIVE WELL THAT ELIMINATED THE CABLE)
GOOD LUCK
Apr 01, 2009 | Dell PowerEdge 4400 Server
Install windows xp pro
Hi
My is working , i have same dell server 1600 , i download the driver from LSI website here is the link
http://lsi.com/storage_home/products_home/host_bus_adapters/scsi_hbas/lsiu320/index.html?remote=1&locale=EN
you just need u320 scsi driver for server 1600sc
download XP driver 32 bit it will work
victor
Jul 04, 2008 | Dell PowerEdge 1600SC Server
Dell PowerEdge T300 Server   Logo
120 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
