Question about Radio Communications
How to programme for us mode Skanti vhf 3000
To change vhf channels from int to us mode
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
Skanti is not a make I am familiar with, so could you find out where this radio was made, as this is important in deciding where we look for a solution to your query.
Please reply with the made in ??? info, so I can help you.
Regards,
Peter
Posted on Mar 05, 2013
Realistic uhf/vhf model 20-400 pro 58 ten channel. Where can I get an owner's manual?
Products associated to Radio Scanners - RadioShack.com
support.radioshack.com/productinfo/ProductResults.asp?...Scanners...
Get Acrobat Reader. Previous Page. Products associated to Radio Scanners. SKU/Catalog #, Model, Description ... 20-139 · Realistic PRO-38 10-Channel Direct Entry Programmable Scanner ... 20-313, Pro-76, Pro-76 200-Channel VHF/AIR/UHFHandheld Scanner ... 20-400 · Realistic PRO-58 Programmable Scanner.
Dec 18, 2015 | Radio Shack Radio Communications
How do I program channels
The GP88 is a dealer programmable handheld radio. It requires Motorola proprietary software, programming cable and R.I.B. (radio interface box). You will need to inquire of your nearest radio dealer if they have the appropriate software.
Oct 22, 2014 | Radio Communications
Cannot get international channels
From the owners manual (Page 4, link below) Press both HI/LO/SCAN/UIC and WX/ALERT/UIC at the same time to change channel modes from USA to INTERNATIONAL to CANADIAN.
-Steve
http://www.uniden.com/pdf/SOLARA%20DSC-BKom.pdf
Oct 12, 2013 | Uniden Solara DSC VHF Marine Radio
In motorola gm338 vhf radio, if programme rx.160.500 mhz exceeds there is a message display on radio monitor 'SYNTH UNLOCK' and there is a sound generates nonstop beep. what is the problem? how it rectify?
GENERAL SPECIFICATION Low Band (GM338 only) = 29.7-36MHz / 36-42MHz / 42-50MHz
UHF
403-470MHz
450-527MHz (1-25W)
450-520MHz (25-40W)
VHF
136-174MHz
So if you do 160-500 it will not generates the LOW BAND capacity because the Channel Spacing = 12.5/20/30kHz 12.5/20/25 kHz.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 24, 2010 | Motorola Computers & Internet
Is the CP185 narrowband capable?
Yes. It is programmable to either wideband or narrowband on each channel. All current model VHF and UHF Motorola radios are narrowband capable.
Best regards.
Nov 09, 2010 | Motorola CP185 (16 Channels) Two Way Radio
I can't program my tv to regular antenna channels
You can program to regular (analog) antenna channels. To do so you must use the original remote which has a TV/DTV switch in the top right corner of the remote. Choose the appropriate mode for the type of channel you want to see or scan for. Here is a link to the owners manual and a picture of the remote swithc. The info on the signal switching is on pg.13.
http://tv.manualsonline.com/manuals/mfg/funai/cr130dr8.html?idRes=707655
Oct 27, 2010 | Durabrand DWT1304 13" TV
How do i change my vhs from US to INT AS I CANT FIND MANUAL. IT THE SOLAR MODEL?
From page 4 of your owner's manual:
WX/ALERT/UIC - Press this key to listen to active NOAAWeather channels.
Press and hold this key for 2 seconds to place the radio into the Weather
Alert mode. Press both HI/LO/SCAN/UIC and WX/ALERT/UIC at the same
CANADIAN.
Aug 14, 2010 | Uniden Solara Vhf Dsc Fixed Mount Radio
HOW DO YOU GET THE WEATHER CHANNEL ON WALKIE TALKIE?
Your radio must have VHF capability, as weather channels are VHF. Then your radio must be programmable to the weather channel for your desired area. If you repost a question including your Motorola radio name/model, we could be more specific.
Jul 20, 2009 | Motorola Walkie Talkie 2-Way Radio
Reception of vhf/uhf channels
You did not mention which set you have, so look for a small switch (usually on the back of the set) or go into the menu and set the TV to the "broadcast" or "tv" mode. If the set is in the "cable" mode, you will not get any UHF channels above 13.
Sep 01, 2007 | Televison & Video
Channel set
Apparently your TV is set to the "standard TV" position. Before you auto program your set, set it to the cable mode and then do the autoprogramming. In the standard TV setting, you just get off the air channels 2-13 vhf and 14-83 uhf.where as in the cable mode you get vhf channels 2-13 plus your cable channels. Stargazer
Mar 17, 2007 | Daewoo DTQ-13P2FC 13" TV
Radio Communications Logo
149 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
