-   My problem is similar. I have a La San Marco 2 group head manual. My water flows at about 250ml in 7 seconds. Far too fast meaning that I am compensating to get my 60ml in 25 second shot by grinding very fine. The water pressure is set at 9 bars. How to I lower the water flow rate?
-   Guest
Back-flush the machine regularly and check your water hookup and make sure you to not have a small diameter water line. Other than that it is controlled by the water pump I believe. If the solenoid (the silver thing attached to the pump) used to start the pump is old it could slow down the pump start cycle.
Was this helpful?
Yes
No
Popular Solutions for Rancilio S24 Espresso Machine
We have a Rancilio model system De2 fm 279373 at my place of employment at it seems to be fusing out...
(More)
We have a Rancilio model system De2 fm 279373 at my place of employment at it seems to be fusing out help please.
The pressure on my machine is not going up, The water is still being sucked in constantly but the...
(More)
The pressure on my machine is not going up, The water is still being sucked in constantly but the water laevel is not going down. The orange light is on. The water is not warming. Thanks
Hello- I have a Rancilio S24 that I have owned for the past 5 years. When I turn the power switch to...
(More)
Hello- I have a Rancilio S24 that I have owned for the past 5 years. When I turn the power switch to the ON position, the light in the switch comes on. However, the pump does not activate,and the boiler tank does not heat up. Do I have a heating element problem? Is there a reset switch to try before I have it serviced?
