Question about Fisher and Paykel GWL11 Top Load Washer
Makes a squealing noise when the water is getting ready to come out
Fisherandpaykel top loader washer
4 Suggested Answers
  • 639 Answers
SOURCE: Smart Drive 703-strange noise during wash cycle
Sounds like the belt and or a pulley !
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
Posted on Sep 02, 2008
SOURCE: loud squealing sound
It is the pump going bad.  There is a tech sheet inside a ziploc bag beneath the control panel.  From the front of the machine, lean over it and look just behind the control panel and locate the two silver screws towards the outter sides.  Remove those two screws and lift the control panel off.  Next to where the water hoses are connected you'll see a ziploc bag with the tech sheet inside.  It has instructions on how to put the machine into diagnostics mode.  Do this if you want and it should tell you the pump is going bad.
Our GWL11 was making that same noise and I just let it go because the machine still worked and, quite frankly, I had no idea what the heck it could be.  Though I'm handy, I've never attempted to fix a washing machine.  Boy, I wish I would have researched the issue online sooner.
After spending more time online researching this issue than any person should, it turns out that squealing noise is the pump going bad.  A fairly inexpensive (about $75) and easy thing to replace.  Should only take 15 minutes or so to change out, even if you've never done it before, and that includes the time to disconnect the hoses and manually bail out the machine.  But if you let the problem go the pump will eventually short out and in turn take out the controller board with it, which is about $130+ just for the part, and you'll have to replace both.
We got about a month of use out of the machine with it squealing then one day it just up and quit.  It would not power on at all.  I did all the unplugging, waiting 30 seconds, plugging back in, etc... and nothing.  Sure enoung the pump shorted out and took the controller board with it.  I actually just received my new pump Saturday (5/16/09) and replaced it yesterday hoping that would solve the problem, but alas, it still won't turn on.  Now I have to buy a new controller board...sigh...
Change the pump now and save yourself some headache and money.  If you have a model GWL11 the pump part # is 420325P.  Should you need the controller board too, it is part # 420094USP.  Good luck!
Posted on May 18, 2009
SOURCE: Washing machine makes noisy squeal when pumping out water
i turn the dryer on it goes for a few minuts and then it fuses all the power points
Posted on Mar 30, 2010
My Roper top load washer is making a squealing sound.. Is it a belt?
Most are belt drive on front loaders and on some top loaders but not all. Other culprit can be a dry bearing. Get into it a take a look. A length of plastic hose makes a good stethoscope to pinpoint the noise.
Oct 02, 2016 | Roper Washing Machines
Kitchenaid top loading washer makes noise when filling
Did you check the hot and cold shut off valves if they have calcium build up it might make a noise. Try replacing them.
Jun 20, 2012 | KitchenAid KAWS750L Top Load Washer
My MAV8600AWW top load washer makes a loud steady squeal whining noise in spin cycle. Load size doesn't affect noise. Machine is 7 years old. Any guess as to problem?
Maytag had problems with the berrings on the transmission . water gets in and the berring goes bad rorring as it spins. Dump it and get a Whirlpool.
Nov 11, 2009 | Maytag MAV8600 Top Load Washer
MAYTAG top loader makes high pitched squeal when agitating/spinni
This is a classic symptom of pulley/motor shafts/bearings in need of lubrication. It's not the agitator. You'll need to take the back off (with power unplugged) to access.
May 12, 2009 | Maytag PAV2300 Top Load Washer
Have a roper ras7133kq1 top loader. It will fill with water and will do nothing else. when i manually set it to spin it makes a squealing nose and the water just drains out.
go to and enter your model number. the first part you see is what is wrong with your washer's spin. replace that and you'll be good. this is found underneath between the motor and the transmission.
Apr 03, 2009 | Roper RAS8445KQ Top Load Washer
Apr 03, 2009 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire LEQ332DSO Squealing Noise
sounds like rear bearing is dry you will need to remove drum to get to it pop clips in top and raise 2 phillips scews 1 in each side remove front remove belt from drum lift drum up in rear and remove ck to make sure plastic bearing is not worn down to metal bracket if it is it will need to be replaced
Jul 07, 2008 | Frigidaire GLER341A Electric Dryer
Very loud squealing noise in spinn.
If your Maytag is a top loader equipped with a vertical transmission under the tub, the squealing may be coming from, either the brake assembly, or the snubber which the entire pedestal rides on.  Could you please post back comments and let me know if this is the type of washer you have?
Oct 18, 2007 | Maytag Performa PAV2200
Fisher and Paykel GWL11 Top Load Washer Logo
48 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
