Question about GE Ovens
Electric oven not heating to temp
I have a sears model 9114042990 that heats, but not to the proper temp. it is usually about 150 degrees lower than set
  • 61 Answers
The oven temp. sensor is bad here is the part #WB21X5301 this should take care of your problem
Posted on Jan 21, 2009
Oven turns on, but w2ill only heat up to about 120 degrees, you can reset and increase temp, but will only go to 150 degrees. Broiler works, but oven anf d oven clean do not work
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 18, 2011 | Amana Ovens
My oven is not heating properly and when I check it with an oven thermometer it is about 25-50 degrees lowere than set
this is usually a problem with the temp probe,other ocassions the main control board if equipped is bad or the temp control switch is bad
Mar 08, 2010 | Ovens
Model GBS307PDQ5: Oven preheated to 425 degrees.
F3 usually means, that the oven temp. sensor is bad and one need to replace it.
The fact, that it's not heating tells me, the fuse in the back also needs to be replaced (requires pulling out).
Whirlpool oven repair orange county, ca
Feb 06, 2010 | Ovens
My oven won't heat above 150 degrees. Is this is
this can be problem with the temp probe.and or the control board if your unit is equipped.
Jan 23, 2010 | Ovens
Oven will not heat until you turn the heat up to 400 degrees
Your "Bake" element may not be working properly. It's the one in the bottom of the oven. Place a couple drops of vegetable oil on the bottom pan, and turn the oven on. During pre-heat, you should start to see those oil drops generate some smoke, IF the lower element is working properly. If it isn't - voila'.!! Problem is with the lower element / associated circuit.
Oct 02, 2009 | Amana AOCS3040SS Electric Single Oven
Ovens wont heat to temp
The reason to this problem can be due to the faulty
thermostat.
Sep 02, 2009 | Lincoln Conveyor Oven - 1133-000-A
Oven doesn't heat up to the right temp--lower oven Viking Pro
Adjust the knob to the actual temperature. There are usually screws inside toe back of the knob for this purpose.
Mar 23, 2009 | Viking DEDO205 Stainless Steel Electric...
Oven cuts out
Most of the time it is a temp sensor in the oven. We bought a service manual at houseneeds.com and fixed ours.
Nov 30, 2008 | Ovens
Dacor Double Oven
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months).  Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
Nov 08, 2008 | Dacor ECD230 Epicure Electric Double Oven
Heating
i would first check the lower units bake element , usually a visually inspection is enough to determine if its good or nor, usually a burn mark can be seen on the element itself, and if you can even see the element the bottom f the oven cavity will lift off for better inspection
Mar 25, 2008 | Maytag CWE5800A Electric Double Oven
Ovens Logo
194 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
