Question about Dryers
I have polaris frontier has power to all 3 prongs on headlights dont work
  • Dryers Master
  • 8,220 Answers
My dodge van was doing the same thing and it turned out to be the dimmer switch
Posted on Jan 09, 2013
Why did lights go dim and battery died?
Search Results
    Battery Dead, runs but headlights dim - Polaris ATV Forum
    www.polarisatvforums.com > ... > Polaris Phoenix
    Jul 23, 2011 - Go Back · Polaris ATV Forum > Polaris Model Specific Discussions > Polaris Phoenix ... Two days later the battery was dead. ... run ok, but the lights weredim and they did not brighten with I rev'ed it up. ... Polaris ATV Legend. Polaris 2500 winch draining battery
    Jan 9, 2014
    No Electrical Power when Key is turned. New Battery
    Dec 18, 2013
    elctrical nightmare!!!
    Feb 19, 2011
    Slowly Losing Power Only when hot...
    Oct 13, 2010
    More results from www.polarisatvforums.com
    Headlights dimming - ATVConnection.com ATV Enthusiast Community
    atvconnection.com/forums/polaris/326484-headlights-dimming.html
    Apr 25, 2010 - The lights on my 99 Sportsman 500 go from bright to dim all the time and I ... did you check the voltage yet when they do thid to make sure it's still putting out ... The Rectifier is my guess, I rode my ATV with a dead battery for a ... Battery Help
    Sep 6, 2014
    dim lights at idle - Page 3
    Dec 6, 2012
    2001 400 4x4 (manual) electrical problem(voltage)
    Aug 17, 2005
    Rancher Ignition Problems
    Dec 10, 2003
    More results from atvconnection.com
    charging issues - Honda ATV Forum
    www.hondaatvforums.net > ... > Honda TRX
Feb 03, 2016 | ATVs
My Frontier headlights taillights and blower motor, also engine has been pulsating. Any ideas?
Loose Electrical connection somewhere. Have an Auto parts store check your battery and charging system as a first step.
Mar 30, 2015 | 2000 Nissan Frontier
Polaris snowmobile troubleshooting
Well Cindy let me ask you was it doing it since you got it ? or it just start doing this ? just so you keep in mind that since you dont have battery in idle can be less power into the bulb filament now when accelerate creating more power meaning more light on bulb...
Jan 03, 2014 | ATVs
Cluster works then dont polaris 500ho atp only 275 hrs
I would guess there is a broken wire in the headlight pod behind the cluster. It may not be very visible if it works intermittently. Polaris doesn't allow for a lot of slack in the wiring harness and the wires pull apart inside the insulator when the handlebars are turned. You can either disassemble the headlight pod and check wires or install a new wiring harness. Best of luck, Daniel.
Oct 20, 2013 | Polaris ATV
I've got a 96 Polaris trailboss 2x4. The headlight
How is the ground and powers to those lights ?
Sep 01, 2017 | Cars & Trucks
97 xc headlight dims then comes on also when it dims hand warmers dont work
Trace the wiring from the earth side of the headlamp, you have a high resistance earth wire maybe corroded where it fixes to the frame.
Feb 01, 2011 | Polaris New Genuine Polaris Snowmobile...
Headlights dont work on atv polaris sportsman
Check the headlite switch, the ignition switch and the chassis power fuse and associated wires.
Oct 24, 2009 | Polaris ATV
How to change the headlight bulb on a 2004 chevy aveo?
Behind the headlight under the hood there is a small rubber disc that keeps water out of the head lamp. Disconnect the 3 prong plastic connector, then pull off the rubber disc. There is a small clip that you can compress with your fingers and swing out. Pull the old bulb out. Be careful you dont touch the new bulb with your fingers as the oils from your skin can cause the bulb to burn out prematurely. Also, be careful not to scratch the bulb. Be sure the bulb spring is holding the bulb securely, Reattach the rubber disc and then reconnect the 3 prong connector. Test it and it should be good.
Apr 06, 2009 | 2004 Chevrolet Aveo
89 Thunderbird, no tail lights
Having the same issue somewhat. Tail lights and dash lights quit. Checked the headlight switch wiring harness by looping all other prong holes back to the main power and they all work, so mine must be the switch. Having a real hard time finding a switch that matches the old one, even though they say it is a replacement. I paid the $25 at www.alldatadiy.com and they have quite a few wiring diagrams for the car.
Mar 24, 2009 | 1989 Ford Thunderbird
Headlight willnot come on in 1994 isuzu P/U, however brights work
one of those three prongs sould be ground, one should only come on with the high beams, and the other only with the head lights. if all three have 12v power you have a short somewhere.
Mar 20, 2009 | 1991 Isuzu Pickup
Dryers Logo
29 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
