Mp3 player with external usb keyboard
I want to buy a small touchscreen mp3 player and control its Play/Pause, Volume up, and Volume down functions with an external USB keyboard (not a wireless keyboard.) Does such a device exist? If so, where can it buy it?
Why don't you want to use a Bluetooth keyboard? I don't know of any USB keyboards but Bluetooth ones work just as well.
Posted on Jan 09, 2013
  • Scott Myatt Jan 09, 2013
    Hi, and thanks for such a quick response. My question has to do with equipment I can use during live music performance. I have tried this with an AirTurn Bluetooth footswitch. Latency prevents me from accurately starting and pausing the music right on the beat. I have a USB footswitch and it works great on my laptop. Just wanted to get the smallest device possible to replace the laptop.
SOURCE: device unrecognizable on computer
if you are using windows 98se you need to load driver from disc.if you are using xp it should load up stright away i had no problems with xp and mp3 player
Posted on Jan 18, 2008
SOURCE: computer does not recognize usb device
Go into the settings menu, from there, go into usb mode...there are two settings: mtp & msc... my player was using mtp and wasn't being recognized, so I switched it to msc, and the computer recognized it.
Posted on Oct 24, 2008
SOURCE: Samsung YP-U3 MP3 Player Problem connection
Found the solution on another site (http://www.everythingusb.com/forums/showthread.php?threadid=11238). To quote user AFHavemann :
"* Plug in the player so the USB bus can see it.
* Once it’s recognized (i.e., the device screen reads "Charging" and "USB Disconnected"), go to the Control Panel and click "System"
* Choose "Hardware" then "Device Manager" tab.
* Look for the name of your device under “Portable Devices” in the list
* If the name of your player is under “MTP Device” then the correct drivers are probably loaded
* Right-click on the name of your device and click "Properties"
* Click “Update Driver”"
Then follow the prompts from there. The computer searches for the driver software, etc., and reinstalls/resets information related to the device, which fixed things such that the computer will now recognize the device. I'm not sure what causes the problem, but this solution seems to reset whatever's gone wrong.
Posted on Nov 17, 2008
SOURCE: Barbie girl mp3 player isn't recognized in Windows
After some time of messing with my daughter's--I desolderd the battery to clear the player--but doing that ,the player now show's up in windows everytime I plug it in. So I would say faulty battery.(Inside player)
Posted on Jan 28, 2009
SmartAviator
  • 449 Answers
SOURCE: When USB is connect MP3 player does not display all songs
Try running scandisk, chkdsk or simila program or format it using FAT option.
Posted on Jul 20, 2009
Santai TD-V26 user manual
The device has an on/off toggle switch and four control pushbutton switches (left ro right) are:
1. Menu (FM Radio or MP3 Player) select
2. Play/Hold
3. Back/Previous
4. Forward/Next
Inputs and output are:
1. 1/8" External Source Input Jack
2. Micro SD Slot
3. Mini USB 5v External Power Input
4. 1/8" Headset/Output Jack
5. USB Memory Card/USB Cable Input/ (Right Side)
The Menu switch has two functions, MP3 Player and FM Radio as indicated by the display. If the Play/Hold switch is pushed in and held for a few seconds the radio will automatically sweep and put the available local stations in memory. The back and forward switches are used to select the desired station. The display indicates station channel number and broadcast frequency (MHz).
In the MP3 Player function Menu function the Play/Hold Switch starts and stops the player. Back and Forward switches select the previous or next track. Simple as that. The player automatically plays the next file if left alone unless the Play/Hold switch is pressed. The display indicates file number and play time. No other functions, like folder selection, were found. If a 5v dc supply is connected to the Mini USB connector the battery will remain charged and it can be used as a small table radio/player. No tests were made to see how long it would operate on its internal battery.
The sound is good and better than expected for a device its size. Enough sound output to hear it in any part of an small house (With some distortion of course). The volume is controlled by holding the forward or back switches in for a couple of seconds and it will switch to volume level control. The display is LED rather than LCD and easier to view. It is on continuously when the player is working with the charger attached.
Aug 23, 2012 | Santai TD-V26 Portable Mini Digital...
I am trying to find out what the blue symbols on the function keys of my sk 9020 keyboard stand for
The blue keys serve as a secondary function for your volume control, monitor controls and pause play fast forward rewind (in media mode). In order to use the blue keys that are numbered from F1 to F12, you must depress and hold the Fn key that is located at the bottom left side of the keyboard. Here is a way to test it: Open up any file that plays sound for longer than 1 minute (60 seconds). While this file is playing, hold down the Fn key and simultaneously press F8 and listen to the volume get louder or Fn and F7 together and listen to the sound get lower. The picture of the crescent moon F1 will adjust the brightness of your screen. F2 will magnify your screen. F3 will take you to your email. F4 will take you to your internet home page. F6 will mute the volume. F7 will lower the volume. F8 will raise the volume. F9 will rewind your video playing. F10 will stop the video. F11 will pause or play the video. F12 will fast forward the video.
Mar 06, 2012 | Gateway (7001434) Keyboard
How do i take the teknika mp229 2gb black mp3 off shuffle?
1. Pause the player
2. Press the play button for 2 seconds ( not long enough to turn it off )
3a. To turn on consecutive play press volume up once.
3b. To turn shuffle play on press volume down once.
4. Press play and check it has worked.
Aug 11, 2010 | Beond Creative Technology Zen Mozaic MP3...
What are the functions of the keys on the dell 1745. F1, F2, keys with the symbols above them?
Fn + F1 Change Display Device. Fn + F2 Wireless Control Fn + F3 Battery information Fn + F4 Decreases brightness on the integrated display only (not on an external monitor). Fn + F5 Increases brightness on the integrated display only (not on an external monitor). Fn + F6 Keyboard backlit(available only if a backlit keyboard is installed) Fn + F7 Mute Fn + F8 Decrease audio Volume. Fn + F9 Increase audio Volume. Fn + F10 CD Previous - Play previous media file. Fn + F11 CD Play/Pause - If there is Audio CD in system, Media player will play music. Fn + F12 CD Next - Play next media file.
Jan 08, 2010 | Dell Studio 17 Notebook
My volume goes up and down without me touching it
try upgrading the firmware of ur player
if ur player is touchscreen try turning off the device for some days
Feb 02, 2009 | Philips GoGear HDD6330 MP3 Player
Car dvd players
sory I did not see that this system will play external vieod, it looks like soumd only not video.
her is a list of specs you ca see for your self.
hope this helps you.
DESCRIPTION
N-CITY DVD-393 In-Dash Car
DVD/VCD/CD/CDRW/MP3/WMA/MP4 Player with Digital
Slot for USB/MMC/SD Memory playback
The New DVD 300 series from N-CITY comes with
everything you expect
Fully featured with Digital Media Slot for
USB/MMC/SD Memory
DIVX Playback, Sub-Woofer output & smart resume function
��. Support USB & MMC/SD Memory Card for direct playback
��.Big size Dot matrix Display
��.DVD/DVD-R+/DIVX/VCD/MP3/ WMA/MP4/CD-RW Compatible
��.Fold Down Detacheble Front Panel
��.MP3 Selection by Sequence Number & Track Name, ID Display
��.Encoder Volume Control
��.Super Electronic Anti-Shock
��.Preset EQ (Flat/Pop/Rock/Classic)
��.AM/FM/MPX PLL Tuning Stereo Receiver
��.30 Memories System (FM18/AM12)
��.Auto Memory Store
��.Repeat/Program/Random/Intro Play
��.Electronic Audio Control
��.8-Times Oversampling
��.Mute / Loud Control / Clock
��.Auto Loading and Ejecting
��. 1- Bit D/A Converter
��. RCA Preamp Output
��. Subwoofer Output
��.ISO Mouting Chasis
��. 4 Channels Output (2V Preout)
��.60W X 4 Power Output
��.Full Function Remote Control
Jan 13, 2009 | Soundstream VDVD-300 DVD/CD/MP3 Player +...
My Creative Zen has a white screen but syill plays music
http://www.youtube.com/watch?v=a8g0sh7pc54
1. Fully charge the unit
2. Get a song to play
3. Lock the device
4. Wait for black screen and leave it like that for 20 seconds
5. Hold the play/pause button down and move the side switch out of lock mode, then push all the way down (like you're turning it off) and release (back to middle position)
6. Release the play/pause button
Sep 19, 2008 | Creative Labs Zen Digital Media Player
RCA MP3 M202E
ok... when your looking at it from the front (screen forward) on the right there are 4 buttons.. the top button is play/pause push that the turn on the mp3 player. underneath the play/pause button is the stop button this stops the song and when you hold the stop button down it turns off the mp3 player. the next buttons are the skip forward and skip backward buttons.. on the left side, the very top button the longer shaped one is the +/- volume button. underneath the +/- button is the equalizer button push this to changed the sound of the device.. and the last button i have yet to figure out.. i hope this helps you..
Jun 19, 2007 | RCA Lyra M2030 MP3 Player
Problems changing volume & sound horrible
Your player is flipped. It thinks that it's connected to an external device, and acts as if it in line out output. When outputing to line out, you really don't have volume control, and you hear it right with the headphones, you would be missing some amplification. Try to reverse the actions that choose line output: Press and hold BACK. The Home menu appears. Press the arrows to select the settings icon(looks like a suitcase), and then press play/pause. Press the up/down buttons to select Audio Output and press play/pause. Now you should see "line out" selected. move the arrows to another setting - headphones if available, and press play/pause. Now unless something is really wrong with your player it should work. If it doesn't, use your warranty if valid, send for repair. Good luck
Jun 23, 2006 | Sony Network Walkman NW-A3000 MP3 Player
99 people viewed this question
 Grubhead
Grubhead
