Question about Dell Studio Xps 9100 Desktop Computer
Error code 00f0:1332 dsk - block 99270696 interrupt request IRQ didnt set in time
Started out with the blue screen of death.. now keep getting this error along with a few others
  • Dell Master
  • 27,725 Answers
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem
BSOD Bluescreen of death can be caused by a number of things If the PSU power supply units fan is not working the PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards A bad or faulty motherboard data lead or its connection if its a flat 40 pin ide it will be the first to fail
make sure all leads have a dust free secure connections
A bad driver loose or faulty lead or not having enough ram or the RAM modules might be dirty. Might be getting hot Check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Then reseat the modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. You might not have enough RAM random access memory not having enough will cause your computer to run over its maximum limits and can cause the blue screen of death and hang and cause memory dumps
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask the seller if they guarantee the compatability of the ram before making any purchase
if you dont want to install more ram uninstall some unnecessary programs
make sure your ram modules have a dust free secure seating and the CPU central processing unit has thermal paste
If eventually you can get a screen Click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver. If you computer came with a motherboard disk the drivers could be on it or you might have to download one. or it might be a virus right click in bottom toolbar select task manager applications to see what is running and processes to see what is ticking over. http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information malware protection http://100-downloads.com/download.php?p=615 windows xp microsoft security essentials http://100-downloads.com/download.php?p=614 windows 7 microsoft security essentials
Hope this helps.
Posted on Jan 10, 2013
5 Suggested Answers
  • 3 Answers
SOURCE: Blue error screen when starting up computer
looks like a OS software problem on reboot try pressing F8 and choose last good known configuration
if that fails to do the trick
This option will put your comp back to how it was when you bought is so all you saved stuff will be lost
press contrl and F12 together on boot up this will restart pc as it was when bought new
Posted on Dec 10, 2008
  • 36 Answers
SOURCE: blue screen of death
Try booting in safe mode (F8 when windows begins loading) and see if everything is ok. If it is, then try safe mode with networking, if that works, but then the problem persists, back up your data and reinstall windows. You likely have a corrupt DLL file somewhere.
Posted on Jan 08, 2009
gods_sonnz
  • 4 Answers
SOURCE: error code 0f00-1332 even with new hard drive
ok if you can scan and check for viruses sometimes virus can play havoc on your computor if that doesnt solve it and if it is under warranty take it back where you got it from and tell them the problem.
Posted on Jun 03, 2012
bronk50
  • 27725 Answers
SOURCE: You emailed me about the GX270- Thank you very much, I'd all but given up. Also, I keep getting the blue screen of death / says-
bluescreen can be caused by a number of things
you might not have enough RAM random access memory not having enough will cause your computer to run over its maximum limits and can cause the blue screen of death and hang and cause memory dumps
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
a bad or faulty motherboard data lead or its connection if its a flat 40 pin ide it will be the first to fail
a bad driver loose or faulty lead or not having enough ram
if you can get a screen
click start control panel administration tools computer management device manager scroll through all of your devices
if you computer came with a motherboard disk the drivers could be on it
hope it helps
Posted on Jul 29, 2012
Dell Studio Xps 9100 Desktop Computer Logo
Alun Cox
