Question about Syntax S746FX Motherboard
No video start up and no video
  • string1059
    string1059 Jan 13, 2013
    no led light on motherboard do not come on and no video
    Guru:
  • 433 Answers
Hi string1059:
I make this video for help ...wish you solve your problem
Posted on Jan 11, 2013
Can you please tell me how to delete individual frames without deleting everything. I have had a bad experience and don't want to repeat it. I can't find my manual....Thanks
Video clip cutting (extracting)
Display the video clip from which you wish to extract a segment.
Display the NORMAL Mode
Playback Menu (page 37), select
"EDIT VIDEO, and press the
button.
Select CUT!! and press the SET
button.
The Cutting Screen appears.
Specify the start point of the extract.
Use the procedure below to specify the frame from which the video clip extract will start.
• Play the video clip until approximately the desired point, pause the video clip, then play the video clip one frame at a time, stopping at
start point of the extract. This will be the first frame of the extract.
• If the start point of the video clip is also the start point of the extract, proceed to step 5.
Play:
After pausing playback, press and hold the SET button to the right
about 2 seconds for forward playback, or to the left for reverse playback.
Pause:
During playback, press the SET button.
Accelerated playback:
During playback, toggle the SET button to the left or right to change the playback speed.
Single frame:
After pausing playback, toggle the SET button to the right to move forward one frame, or to the left to move back one frame.
5
Toggle the SET button up.
• The start point of the video clip
extract is set, and the screen
•Specify the end point of the
extract by following the same
procedure as in step 5.
a. Toggle the SET button down.
Each time the SET button
toggled down, the sections
delete and the sections to
save are reversed.
b. Specify the end point of the extract. The frame following
end point of the extract will
the start point of the latter portion to be joined.
6
Press the VIDEO CAMERA button.
A screen appears for you to select either to save the edited video clip as a new (separate) file, or to delete the original video clip and replace it with the edited video clip.
SAVE AS NEW:
The edited video clip will be saved as a new file. The original video clip remains unchanged.
OVERWRITE:
The original video clip will be deleted. Only the edited video clip will be saved.
REVIEW CLIP:
Play back the edited video clip before saving it.
7
Select the desired option, and press the SET button.
• Editing starts.
• When editing ends, you are returned to the NORMAL Mode Playback
Menu.
I think this is what you are after if this isn't what you need you can find the manual at
http://www.retrevo.com/support/Sanyo-VPC-CG9-Camcorders-manual/id/18378dj397/t/2/
Jun 17, 2011 | Sanyo Xacti VPC-CG9 Digital Camera
Tip
How to Remove DRM From iTunes rental or purchased videos on Mac OS X
As we all know, iTunes videos are all DRM protected by Apple's Fairplay, which prevent us reusing the content freely, like sharing the iTunes videos on network, editing the iTunes videos with FCP or iMovie, converting iTunes videos to other common formats and watching iTunes videos on many Non-apple devices and so on.
There are so many limitations on the iTunes rented or purchased videos. Why not find a DRM removal software to crack the iTunes DRM and then watch the iTunes videos free?
Here I want to share my experiences for using a DRM Media Converter and removing the drm from all my iTunes videos on my Mac.
Step 1. Download and Install the recommended DRM media converter tool.
iTunes DRM Media Converter for Mac
This DRM Media Converter for Mac tool requires you to install the lastest iTunes and Mac OS 10.8 or later.
Step 2. Add iTunes DRM videos
Click Add button, then you can add the iTunes drm videos from iTunes library directly.
Step 3. Click Start to start removing iTunes DRM
Click Start button, then the DRM media converter for Mac will start to work. It will soon convert the iTunes drm m4v videos to unprotected MP4 format.
MP4 format is the most popular video format currently. It's compatible with almost all mobile devices and can be uploaded to any video sharing websites.
on Apr 15, 2014 | Apple iTunes
Tip
How to Convert 2D Video to 3D Video Ever imagined that a normal 2D video can be...
How to Convert 2D Video to 3D Video <br /><br />Ever imagined that a normal 2D video can be magically turned into a 3D video which can be played by compatible software player on your computer or 3D TV? Using DVDFab 2D to 3D Converter, you can achieve this smoothly with success. 2D to 3D Converter is robust, quick, and easy to use. <br /><br />Required Tools: <a href="http://convert2dto3d.net/">2D to 3D Converter</a> <br /><br /><br /><b>2D Video to 3D Video&gt;Step 1: Run 2D to 3D Converter in Video Converter</b> <br /><br />2D to 3D Converter is embedded in Video Converter as the option of "2D to 3D", which is convenient for users to use both of the two products to finish this 2D to 3D conversion task. So we need to run Video Converter at first. Then choose a compatible mode from multiple supported ones ("to AVI", "to MKV", "to MP4", "to FLV") and import in the source video we want to convert. After the source video is loaded in, the "2D to 3D" option is ready to be selected with a check box in front of it, just check it. <br /><br /><img src="03e799ef87630e7db329a3d6b4ad32ac.png" /> <br /><br /><b>2D Video to 3D Video&gt;Step 2: Click Video Effect Settings button, and Edit button</b> <br /><br />Click Video Effect Settings button to customize the 3D format, video frame size, source aspect ratio, frame resolution, play region, etc. for the output 3D video. <br /><br /><img src="f54b135b729b8958eb35b3e0b857f22e.png" /> <br /><br /><img src="e870296a85008d2cadfe2edc5c7eaee8.png" /> <br /><br /><img src="3625486fded3ed529ef277b478691616.png" /> <br /><br />All right, now click Edit button on the main interface to set up a lot of video/audio parameters for the conversion. <br /><br /><img src="d06d9614161e664378c89f760d88b84c.png" /> <br /><br /><b>2D Video to 3D Video&gt;Step 3: Click Start button to <a href="http://convert2dto3d.net/">convert 2D to 3D</a></b> <br /><br />Now we've finished all the settings, just head over to click Start button on the main UI to start converting. Just sit back and relax, and no long time later you'll get your terrific 3D videos <br />Now we've finished all the settings, just head over to click Start button on the main UI to start converting. Just sit back and relax, and no long time later you'll get your terrific 3D videos
on Jul 05, 2011 | Computers & Internet
No video on start up
If you get no video ever, not even when the initial BIOS screen is supposed to appear, then you may have a failed video card or monitor. Your motherboard uses a PCIe-16 video card but has no on-board video. Check the motherboard manual for instructions on resetting the BIOS to factory defaults; perhaps the setting for the video card was corrupted.
If you get the BIOS splash screen and initial system start video, then it goes black, you have an OS problem. Try starting in safe mode to figure out what's going on.
Dec 30, 2010 | ASUS P7P55M Motherboard
My Video doesn't properly work.When I'm on line wirh CNN,to watch the news,the video starts but then it stops and starts and stops and starts,The video goes in spurts.
this is actually a connection issue and not a video issue this is a connection issue most likley as video playback probably works when your not watching videos online you just have to either let the video buffer up by pausing for a little while before you watch or see if you can lower the quality of the video so it can keep up with your connection speed
Sep 24, 2010 | HP Pavilion dv6000z Notebook
Tip
Wondershare Video Converter for Mac Guide
This is the step by step guide for Wondershare Video Converter for Mac.
Free download Wondershare Video Converter for Mac
Step 1: Add video files
Launch Video Converter for Mac, click 'Add Files' to browse your computer hard drive and select the videos you want to convert.
video-converter-for-mac-guide-1.jpg Step 2: Select the optimized output format for videos on Mac
After loading videos to the Mac Video Converter, choose the chapters or titles you want to rip, then click 'Format' to select the output format from the drop-down list.
video-converter-for-mac-guide-2.jpg Step 3: Start conversion
After all the settings, click the 'Start' button to start ripping DVD to destination format.
video-converter-for-mac-guide-3.jpgresource:mac video converter
on Mar 02, 2010 | Computers & Internet
FREQUENT START AND STOP DURING THE PLAY OF VIDEO
usually this happen when you have slow broadband connection and video is need more speed then your broadband connection speed if you have 512kbps internet speed you do not have to wait this long to watch video on you tube. check your internet connection speed for you tube video.
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 24, 2010 | YouTube Videos
Error when starting to export video to itunes
oh, why don't you try another soaftware?
Ultimate Video Download Studio helps you put any video format onto your iPad, iPod, iPod touch, iPod
video nano, iPhone, Zune, PSP, video capable MP3 players, video capable mobile
phones, and Pocket PC, etc.
Nov 02, 2009 | JVC Everio GZ-MG630 Hard Drive Camcorder
I cant see video from ipod
No in the ipod settings have u turned on the NSTF signal for the TV?
May 25, 2008 | Audiovox VM9512 Car DVD Player
Videos start and stop
Yes the videos you are referring to are probably streaming videos, so once they begin to stream stop the video until the stream reads ahead (the amount will depend on your bandwidth), then once the streaming is well ahead you can start the video again and watch it glitch free unless the video progress starts to catch up to the streaming status at which time you just need to pause again and so forth. You could just wait until the stream is complete and enjoy your video.
Good luck.
Feb 15, 2008 | Microsoft Windows XP Home Edition
Syntax S746FX Motherboard Logo
19 people viewed this question
Top Syntax Computers & Internet Experts
Roy May
Gbenga
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
