Question about Protron PLTV-32 Television
Codes for virgin remote for a Polaroid TV - Protron PLTV-32 Television
How to change volume on vm202 virgin media alcatel
Virgin Media Remote Control Codes
www.virginmedia.com/.../vplus-remote-control-codes.php
Virgin MediaYou can set-up your Virgin Remote Control to operate the Volume and Mute functions on your TV so you only need one remote to watch TV. Firstly, please select ...Missing: vm202 ‎alcatel
Customise your TiVo remote to control your TV - Virgin Media
www.virginmedia.com/tivoremotesetup/
Virgin MediaTo clear your changes and reset your remote to its original settings: Press and hold down and on the remote at the same time until the light on the top of the remote flashes green twice. Press three times, then press. The LED will flash green four times and exit programming mode.Missing: vm202 ‎alcatel
Virgin Media VM202 review by 3G.co.uk
Dec 27, 2015 | Alcatel Cell Phones
Tip
Polaroid TV DVD Combo Remote Codes Can't find a code to program your universal...
Can't find a code to program your universal remote to control your Polaroid HDTV / DVD combo? Can't find a listing for Polaroid DVD in your remote control code list?
Many manufacturers recycle remote control codes, so often the best solution is to use the code search function of your universal remote.
Here are some remote control codes that have worked to control Polaroid HDTVs:
  1. My 19" w/DVD uses the following Mitsubishi code: 10178
  2. Dish Network remotes: 627, 659, or 688
  3. DirecTV RC64 remote control revealed a code of 10835. This means that 10835, 0835, 835 or some variant many work with many programmable remote controls. On my DirecTV DVR system, this was indicated as a Moxell and/or Motorola TV code.
  4. Use the mitsubshi tv codes they worked for me.
  5. Try Element codes if they are listed in your remote code list.
I hope that helps.
_____________________________________________
Polaroid HDTV Manual Download
Polaroid HDTV Service Manual Download
on May 02, 2010 | Televison & Video
Tip
Polaroid HDTV Remote Control Codes
Polaroid HDTV Remote Codes
Can't find a code to program your universal remote to control your Polaroid HDTV? Can't find a listing for Polaroid in your remote control code list?
I hope that helps.
Virgin media remote control TV Control Codes Samsung LE37A558
just tried 0079 from another forum and it's worked for me!
Mar 11, 2009 | Televison & Video
Universal remote code for a Polaroid LCD TV
I may be able to help with your Universal remote and your Polaroid LCD HDTV.
You can find some Polaroid HDTV Remote Codes here.
I hope that helps.
Polaroid FLM-3232 Manual Download
Polaroid FLM-3232 Service Manual Download
Feb 26, 2009 | Polaroid FLM-3232 Television
I need a universal remote code for a Polaroid LCD TV FLA-3232B
I may be able to help with your Tevion Universal remote and your Polaroid LCD HDTV.
I hope that helps.
Feb 26, 2009 | Philips 32PFL7332D 32 in. LCD HDTV
03223 tlu-Polaroid remote control codes for virgin TV
I just found it its 0008 I had to do it twice but it worked!!!!
Dec 27, 2008 | Polaroid 1720-7 Remote Control
Code
Polaroid TV code for remote: 0765
Apr 05, 2008 | Polaroid FLM-4201 42 in. LCD Television
One for all remote urc 7940
i entered the codes from the book but none of them worked for my AWA tv. the remote works on other tvs
Feb 26, 2008 | Televison & Video
Directv remote code for polaroid tv
Slide top button on remote to tv. Press and hold mute and select button until the green light on the remote blinks twice. Then press 991. Then press 1. Then press the tv power button once. If the tv doesn't respond hit the channel up button on the remote. If that works press select to store the code and slide the switch back to the left. If it doesn't work keep hitting channel up until it does. It can take up to 30 minutes but it works.
Jan 16, 2008 | Directv RC23 Remote Control
Protron PLTV-32 Television Logo
60 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
