Question about Baby Gear
Why is the britony combi SE 80 beeping?
The pressure bar is also slightly in the red.
3 Suggested Answers
  • 13 Answers
SOURCE: I have a britony combi se 80. It keeps cutting out, error 60.
hi mate if you are happy to open the appliance and not disturb any gas connections clean the rectification probe, cause if its a intermittent fault it could be carbon deposits on the probe also make shaw the lead from probe to pcb is connected and not damaged if all ok its the pcb, let me know
Posted on Sep 12, 2009
  • 36 Answers
SOURCE: I have Britony combi SE.It keeps cutting out error
tour gas valve or solinoid is faulty,check you have 240dc across the solinoid,if you have then its the gas valve,if not its your solinoid,but check you have spark at the ignition electrode first,if not check the continuity of the harness,the harness are the two yellow or orange wires from spark generator on pcb to ignition.
getting confused,mail me i will go through it for you
Posted on Jan 24, 2010
Flame Pulsing
A pulsing flame is a gas pressure problem. It shutting down is probably because the boiler thinks there is no flame when it goes low on the pulse and shuts the gas valve off. Listen to your pressure regulator and gas valve. If either is causing your problem, you will hear it. If so, smell the end of the vent line from it. If your diaphragm is leaking, you will smell it. I have specific questions but will throw a few general things out here for you. If you don't have a regulator outside of the gas valve, it is inside the gas valve. Try turning the supply pressure up or down a little. Remember where the screw is so you can put it back. Both under and over firing a furnace both have their own bad consequences, so don't adjust it too much either way. If it reacts to adjustment but still pulses, it is probably bad. Check the vent line for a gas smell. And of course, check all the electrical connections. Watch the pilot assembly when it shuts down to confirm why it is shutting down. Are you using natural gas from a city supply or propane? I'll check back here later to see if your still here. Hope it is already fixed though. Roger
Mar 16, 2014 | Heating & Cooling
Chaffoteaux britony combi 80 I've just replace both pcbs and still have a pulsing flame after ignition. It burns for a few seconds then cuts out. Ideas?
this sounds like a central heating boiler rather than a computer. can you please post in the correct section where you'll get a meaningful response.
Mar 14, 2014 | Computers & Internet
Britony 80 combi boiler G31 propane, gas flow rate =0.124877 cubic meters per hour, inlet pressure 37mbar, room sealed flu Manufactures recommended Co2 & NFGT unknown, cold water from hot tap when...
You gave a good description of the boiler--
now we need to hear the clues you have observed, as it fires (or fails to fire-- or what?)
Or as the water flow-- or doesn't flow?
As the cold water enters-- what does the flame do?
And does the flow rate reduce as the flow gets to the divert er valve?
How old is the boiler?-- and have we been using HARD water?
(Any water softener in the circuit to remove calcium and magnesium, etc.?)
Do you suspect a scaling problem in the interior parts?
If so-- can you circuit an acid thru the innards, to clean up the scale?
Please comment on what happens when water and gas flow-- so we can help you get to the next step.
Mack B
Jan 17, 2011 | Heating & Cooling
I have Britony combi SE.It keeps cutting out error 70 and 80 . Ichance the pcb three months ago if that helps
Jan 24, 2010 | Combi Centre DX - Mango
Britony Combi se 80 boiler
Steel wool is the way to clean. Hope this helps
Oct 18, 2009 | Water Heaters
Sep 09, 2009 | Combi Centre DX - Mango
I have a chaffaeux combi 80/100 no hot water
sounds like diaphagm valve or micro switch best of luck
May 06, 2009 | Water Heaters
Gushing Water
sounds like youve topped the pressure up too much, the boiler needs to be on 1 bar pressure from a cold state, thats the max really you want to increase it too, in operation the boiler pressure increases due to heat expansion but sounds like you may have more of a problem, if your renting the property then its the landlords duty to ensure your boiler works and its safe- consult the landlord asap and they sohould help you out
Apr 21, 2008 | Combi Centre DX - Mango
Baby Gear Logo
23 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
