Question about Hardware & Accessories
How do I set my partner 385 chainsaw carb?
Need info on screw settings on carb following service
SOURCE: STIHL CHAINSAW MIXTURE SETTINGS
one turn high and low 66 has compesator carby willrun rich up high but will lean under load
Posted on Sep 03, 2008
  • 3567 Answers
SOURCE: settings needed for mixture screws
Turn both screws inward and seat them GENTLY. Now turn both screws one and one half turns outward. This is the factory setting.
Please rate this solution as a "FixYa" Thanks!
Posted on Mar 19, 2009
  • 597 Answers
SOURCE: Can't set carb. on Husqvarna chainsaw.
Most chainsaws and small engines are 1.5 turns out.
You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. At idle turn the screw in or clockwise until the rps starts to decrease. Then start turning it out till you hit max idle rpms. Turn screw back in a quarter to half turn and it should be idling smoothly. Be careful here and get someone to hold saw if necessary but hold in throttle to full speed and do the same with high adjustment screw. turn it in till rpm starts to drop then back it out until you get to max rpm and it won't go any higher then turn it back in a half a turn.
Posted on Jun 28, 2009
  • 12 Answers
SOURCE: husqvarna 272 xp, setting for setting screw for oiler
20" Husky saws are set from the factory at an un-healthy low rate of oil flow. Find the adjustment screw mentioned above, and turn it CLOCKWISE until just barely snug. Then turn it COUNTER-CLOCKWISE 2.5 turns and check to see if its throwing oil as mentioned above.
Posted on Jun 13, 2010
  • 3567 Answers
SOURCE: needle adjustments for 1999 Suzuki RM80 Need carb
Lightly seat the screws then open up each of them one and one half turns. This is the factory setting.
Posted on Aug 11, 2010
Setting carburetor
David, may vary by make, model and engine size. I turn the L(low) and H (high) speed screws in till just seated(bottomed out) lightly, then I turn each screw out 1 complete revolution, start saw and tweek adjustments from there on the L and H. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Tune Chainsaw Carburetor
https://store.chainsawr.com/blogs/tuning-and-repairs/1126042-adjustment-and-tuning-of-a-chainsaw-carburetor
Adjusting chainsaw carb
Jul 03, 2016 | Garden
Working on a husqvarna 385 saw we start it cuts good soon as get hot it not want to cut it dogs out
This is a common problem. Your carburetor is set too lean causing it to starve for oxygen, richen the carb setting a bit...
Oct 02, 2015 | Husqvarna Garden
How to set carb screws so chainsaw don't idle so
Turn out slow screw until it idles properly when warmed up. If it is more than 5 years old just started doing this it may have an air leak around crank. continue to run it and you will seize it up.
May 23, 2013 | Garden
Homelike chainsaw carb settings high/low
Hi, most chainsaws start with carb settings at 1&1/4 turns out( hi+lo) usually once the chainsaw has been run in, the 'hi' screw can be turned in an eighth, tickover set low enough not to cut out but high enough not to engage the clutch, cheers Billy
Feb 15, 2013 | Homelite Garden
Carb settings for a mac3500 chainsaw
1 1/4 turns on both screws is a good starting point, you will have to fine tune from there, always start fine tuning with the L screw as this will also slighty effect the H setting.
Feb 02, 2013 | McCulloch Chainsaw Shop Repair Manuals 121...
Looking for the intial setting for the 2 screws on side of carb on k750
Hi, most, if not all chainsaws start with both hi and low screws set at 1 and 1/4 turns out, but when you turn the screws in, don't turn them tight-soft metal! Mark the screwdriver and turn them out , once chainsaw started the high speed screw can be turned in one eighth. The tickover is turned in just enough that sounds right and the clutch isn't engaged!
Aug 03, 2012 | Husqvarna Partner K650, K700, K750, K950,...
Carburettor letting to much fuel through.may be gaskets replace in wrong position
If you have dissmantled the carb and fitted new diaphrams, it is very important to re assemble in the correct order, starting with the pump side ( the diaphram without the disc in the middle ) the diaphram goes against the pump body, followed by the gasket, followed by the cover and securing screws, the metering side is the opposite, so the gasket goes against the carb body followed by the diaphram, followed by the cover and securing screws, the metering lever should be set level with either the sides of the carb body or the base of the carb body dependent on what brand of carb we are talking about, to service the carb correctly yoy should do a final pressure test with a bulb tester, the carb needle should hold a continual 2 psi pressure.
Mar 01, 2011 | Garden
Jun 20, 2009 | Husqvarna Forest & Garden 125l 18" Gas...
Screw mixture settings
1 1/2 turns open. Start unit then fine tune from there.
Apr 11, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Hardware & Accessories Logo
64 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
