Question about Air Tools & Compressors
My Ingersoll Rand SS5 pump overheats and locks up
Checked oil slingers and they are intact. Noted cylinders seem to be very dry. Cylinders and pistons are a golden color but not burnt. Checked reed valves and all look good and function as they should. Checked check valve going into tank and it functions. Was sticking but freed up with a little cleaner. Tightened belt. Compressor will run one cycle but starts slow down around 100 psi but will make it to 130psi and shut off. Cylinder temps are aound 380-400 degrees. Head temps are well over 400 degrees. Next cycle the compressor will slow down and come to a complete stop before reaching 100 psi. Smoke coming from air intake. Let cool and pulled thru by hand. Hard to turn at top of the stroke. Started compressor and sprayed PB Blaster into intake and compressor sped up for a few seconds but then slowed back down to a full stop. Suspect incorrect clearance between pistons and cylinders not allowing for expansion? Damaged piston rings not allowing oil to get to pistons and cylinders? Looking for suggestions. Anyone have specs on cylinder wall to piston clearance?
  • 5 more comments
  • Anthony Royal Jan 09, 2013
    Belt was tensioned prior to running. OO cord no more than 6 ft running into circuit breaker box.
    Ran until 50 lbs air in tank. Loosened nut to copper line from compressor to check valve. No air escaped from tank. Worould seem to indicate check valve is working.
    Will try running with discharge line disconnected.
    When pump stops, electric motor is still trying to turn pump. Trying to turn pump by hand is almost impossible fora t least 5 minutes. Then very difficult
  • Anthony Royal Jan 11, 2013
    Problem found. Completely disassembled pump and found front piston has a one inch wear band just below the oil rings. Pistons are aluminum and cylinders are steel. When heated aluminum expands faster than iron. The band indicates either the piston skirt is out of tolerance and/or the cylinder is out of spec. The heat generated during compression is causing the piston to expand and lock in the cylinder. The out of tolerance is small as once the cylinder cools for a minute or so, the piston/cylinder interference lessens. All oil rings, passages, and slingers are clear and intact. Contacting IR for specs on the cylinder walls and piston skirt to see what needs to be repaired or replaced.
  • chada303
    chada303 Apr 03, 2013
    What did IR say? I am having the same issue, any help appreciated
  • Denny Morrow Aug 26, 2013
    I have the exact same issue. Did you find the solution?
3 Suggested Answers
  • 89 Answers
SOURCE: My Sears 1 HP compressor motor starts to slow down
IF IT HAS BELTS THE BELTS COULD HAVE BEEN LOOSE AND SLIPPING.. MOTOR COULD BE GETTING HOT DUE TO TOO SMALL OF CORD OR SMALL GAUGE DROPCORD. INTANK CHECK VALVE COULD BE GETTING CLOGGED NOT ALLOWING AIR TO PASS THRU IT. UNHOOK DISCHARGE LINE FROM HEAD TO THE TANK, THIS WILL ALLOW PUMP TO RUN UNDER NO STRESS AND SEE WHAT HAPPENS.
Posted on Apr 03, 2009
I need a 4 piston A/C compressor or a 4 piston hydraulic pump for a project. do you know which models have this
http://www.boge.com/in/artikel/download/Brochure304_EN_Piston.pdf
Devair/DeVilbiss Piston Air Compressors
www.centrair.ca/piston_compressors.html 5hp piston air compressor, 7.5hp piston air compressor, 10hp piston air compressor, 15hp piston air compressor, 25hp ... PUMP: 2 x 447 (2 stage 4 cylinder)
10HP 4 Cylinder 2 Stage Air Compressor Pump
https://www.eatoncompressor.com/10hp-4-cylinder-2-stage-air-compress... Solid cast iron 2-stage V-4 piston series pump, oil lubricated design to extend pump ... This is our 10 HP, 4 Cylinder, 2-Stage, air compressor pump with 43 CFM ... Compressor Stages‎: ‎Two Stage CFM @ 100 PSI‎: ‎43 CFM Compressor Type‎: ‎Bare Piston Pump Horse Power‎: ‎43 CFM
Petstar 4 - Ingersoll Rand
www.ingersollrandproducts.com > ... > PET Compressed Air Solutions Ingersoll Rand PETStar® 4 reciprocating air compressors offer durability and ... pistons with heavy-duty Class 40 cast iron cylinder construction; Piston rings and ...
Jan 31, 2016 | Air Tools & Compressors
NEED DIAGRAM FOR LOCATIONS OF CRANKSHAFT PULLY,OIL SLINGER AND SPRING.FOR 1983 MAZDA 2.2L DIESEL
Here is the procedure:-
  1. Remove setscrew from side of cylinder block.
  2. Remove oil pipe attaching bolts.
  3. Remove oil pump and strainer.
TIMING GEAR COVER
  1. Remove timing gear cover to case attaching bolts.
  2. Remove timing gear cover and gasket.
CAMSHAFT, CRANKSHAFT, IDLER & INJECTION PUMP GEARS
  1. Remove oil slinger and washers from crankshaft snout.
Using puller set 49 0839 425C or equivalent, remove crankshaft timing gear, Fig. 3.
  1. Position a clean rag between camshaft and idler gears, then remove cam gear lock bolt and washers.
  2. Using puller set 49 0839 425C or equivalent, remove cam gear from camshaft, Fig. 3.
  3. Remove idler gear to spindle retaining nuts and washers, then remove idler gear and spindle assemblies.
  4. Remove injection pump drive gear.
  5. Remove timing gear case to cylinder block attaching bolts, then the timing case.
CAMSHAFT
  1. Remove tappets from cylinder block.
  2. Remove camshaft thrust plate to cylinder block retaining bolts and washers, then pull camshaft from block.
PISTON & CONNECTING ROD
  1. Remove connecting rod bearing cap retaining nuts and bolts, then separate bearing cap from connecting rod.
  2. Using the wooden handle end of a hammer, push the piston and connecting rod assembly outward until piston rings clear cylinder bore. Remove piston and connecting rod assembly through top of cylinder block.
  3. To separate piston from connecting rod, remove piston pin retaining clips, then press pin from piston using a suitable driver.
CRANKSHAFT
  1. Remove rear oil seal cap retaining bolts, then the cap and seal.
  2. Remove main bearing cap to cylinder block retaining bolts, then the main bearing caps and thrust washers.
  3. Lift crankshaft from cylinder block.
Mar 26, 2015 | Mazda Cars & Trucks
Knocking noise
2545 is a piston compessor if so you've got a busted rod on one of your cylinders , this will fail catastrofic and break out side of compessor but if caught early can still be rebuilt with a few new parts
Mar 18, 2014 | Ingersoll Rand 2545 pump,air compressor
INGERSOLL RAND SS3P OVERHEATING OF CYLINDERS
Heat in that location noted is to be expected, but to the degree that it is should be of some concern.
When was the oil changed in the compressor last?
If you are running with a multiviscosity oil, use it only if the manual indicates it. Running straight weight oils, especially in extreme conditions is prudent insurance against failure. If you are running 10W20 for example- run 20 weight instead until regular air temps are below freezing- then the switching to 10 weightshould be a consideration..
The oil sump serves 2 purposes- 1- Coolant. 2-lubrication.
However I think the bearings in in the compressor are needing attention.
More because it sounds like there is an oiling problem in the compressor itself. At an absolute minimum it sounds like the head should be pulled to inspect for galling in the cylinder walls and to look for trace oil on the cylinder wall.
Feb 14, 2012 | Ingersoll Air Tools & Compressors
Oil in my air line
Oil in the air lines indicates you have air pump problems; either worn or broken piston rings or badly scored cylinder wall(s), usually both. You'll have to disassemble the air pump or take it to a service center to find out what's wrong inside pump.
Feb 01, 2011 | Ingersoll Rand TS4N5 Ir Electric...
What is the spec on a ingersoll rand type 30 model 15
Hope this is sufficient information:-
Two-stage Type-30 replacement compressor pump for Ingersoll Rand Type 30 Reciprocating Air Compressors. U.S.A. Max. PSI: 175, HP: 15, Flywheel Diameter (in.): 18, Total Cylinders: 2, Bore Diameter (in.): 5 1/2 and 3, Stroke Length (in.): 4
Jan 25, 2011 | Garden
Model 2545 compressor getting toomuch carbon deposit in side the cylinder
You can try switching to a full synthetic compressor oil to alleviate the problem.
Carbon is caused by the over heating of oil. Your problem is most likely an undersized compressor, or worn valves and piston rings.
Regardless of the problem synthetic compressor oil will help.
Hope that helps,
under_psi
May 16, 2010 | Ingersoll Rand - Rand Type - 30...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
My air compressor a, 2 stage is over heating on the one cylinder that is the 2nd in line to the tank change the oil checked the filters and has good ventilation. One of the cylinder`s hotter than the other...
Sounds like the cooler cylinder has reed problems and is not working correctly. The heat is typical in a reciprocating compressor. Both heads or cylinders should produce the same amout of heat. Pull the head on the cooler cylinder and check the reed valves in the head.
Nov 15, 2009 | Ingersoll Rand 231C-KS - 1/2" Super Duty...
Air Tools & Compressors Logo
340 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
