Question about Sylvania Heating & Cooling
Sylvania 2000w convection heater makes lots of noise. supposed to be quiet. is there anything I can do?
MicrowaveSvc
  • 9098 Answers
SOURCE: wont heat items in the micro or convection
MODEL NUMBER NEEDED
Apparently this is not actually an R-510HK since that model does not have convection mode. Can you reply back with the correct model number? We may have the service manual for you.
A PRELIMINARY OPINION
It sounds like you have loose door switch mounts or possibly loose door hinges.
If the door won't open via the door open button, then the outer cover will have to be removed.
BEFORE YOU RATE THIS
This is a preliminary post, asking for further information (model). Please withhold your rating until we actually offer the solution.
Posted on Dec 07, 2007
sparktgo
  • 68 Answers
SOURCE: CAN I CONNECT A CREDA 2000W PLINTH HEATER USEING A
Yes ,you can and fuse at 13amp.
Although the correct way would be to terminate the plinth heater in a switched fused spur or an unswitched fused spur fused at 13 amp
This can either replace a single or double socket or it can be taken of the socket by using 2.5mm2 twin and earth cable.
All parts availiable from hardware store or electrical retailer
Posted on Oct 06, 2009
Testimonial: "THANK YOU SO MUCH IT WAS VERY HELPFULL"
hunter19_46m
  • 7482 Answers
SOURCE: It is supposed to whisper quiet but it is making a
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Posted on Oct 14, 2009
  • 289 Answers
SOURCE: My frigidaire dishwasher makes lots of noise, then quiet and
check the drain pump and filter
Posted on Nov 26, 2009
  • 48 Answers
SOURCE: my quiet bathroom fan makes a roaring noise
The roaring noise is probably the fan blades (looks like a hamster wheel) are worn out as it rotates on the spindle/shaft.
It may be a problem with the 4" exhaust ducting, that connects to the exit part of the fan, has come loose. Theres a damper (kinda like a flapper) at the fan/ducting joint may have broken off and may be sitting sideways in the ducting flapping around inside the duct.
At any rate I highly doubt its wiring. Sounds like its time to pull the fan cover off (turn the power off first via the wall switch or the service panel breaker would be even better) and look at the fan blades. Clean off any dust bunnies, lint, etc. and turn the fan back on. Did the noise stop?
If nothing looks out of place and it still makes noise you'll have to get in the attic and remove the ducting from the fan and see if theres a problem at the connection there. Maybe a squirrel put its bedding in the ducting? It happens.
Could be lots of reasons for the noise but wiring it wrong wouldn't cause roaring. The fan wouldn't work, or worst burn up, if wiring was the issue. The problem is the more than likely the fan blade assy is worn out or something is restricting the air flow in the ducting going to the outside of the house.
Posted on Nov 22, 2012
Flame effect electric fire loud clicking noise
You need a new synchronous motor. This is the small motor which turns the flame effect rod. They are notorious for becoming noisy.
Nov 06, 2012 | ACE Dimplex (r) Compact Electric Fireplace...
How to install a wall dimplex thermostat to a dimplex fan wall heater /RDH2010tcw/1000/2000W/240
disconnect wire A from the thermostat, and connect it directly to one of the supply wires. Connect B and C to the other for 2000W.
Mar 03, 2010 | Heating & Cooling
My motor on my ...well what i think is my heater is extremely loud! how can i quiet it down..... it sounds like a really loud fan
Hello there:
Normally on these heater motors they can get really loud when the fan gets a lot of buildup on them which causes the fan to make a lot of noise and also it will make the bearings in the heater motor to wear out What i recommend you do is to first try to remove the heater blower cover it inside of the vehical and see if the fan has a lot of dirt anddebris around it if it does clean it out next if the fan is clean go to the heater motor and try to feel and listen to the motor and see if it is very hot if it is chances are that the bearings are getting worn which would lead to you replacing the heater motor ok
I hope that this has been very helpful for you
Best regards Michael
Nov 22, 2009 | Lexus ES 300 Cars & Trucks
Kenmore elite slide in range model 790-4101
how do you take the top off this LG LRG30357ST i cant get a tool small enough to fit the back right burrned orifes to convert it to lpg
Jan 20, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
A buzzing noise
Why do you say put in line to stop the buzzing? What is it that tells you the wire is creating the buzz?
It could be anything from a loose sheet metal part, rivet, fan, transformer, loose connection, or just the way it was built, although a loud buzz sounds like a problem waiting to happen to me.
No there is nothing to put in line to make it quit buzzing, I need to know all the information about the device, voltage, amps, brand, and then tell me how it is wired including number of wires, size of wires, voltage, how it is wired to what colors, how far from breaker, what breaker and size, and anything else that seemed unusual to you during install if anything.
Write me back here or allexperts.com or wbwill@sbcglobal.net.
Oct 24, 2008 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
166 people viewed this question
Top Sylvania Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Sylvania Heating and Cooling Expert? Answer questions, earn points and help others
