My hd-ila jvc tv has green vertical lines throughout the picture is repairable
It started tha i could still see a picture behind the lines but now just see shadows. screen is totally green close up it is actually lines that are vertical.
tat4u
  • 520 Answers
SOURCE: Dark Blotch on rear projection TV screen
usually these are caused by cleaning the screen with a damp cloth or fkuid rear projection tv's usually have two plastic screens separated by about quarter inch with bulbs between,one being a magnified screen.problem is,condensation can occur causing various blotches,letting the screens naturly dry out usually solves this but failing this you have to strip down and wipe them with clean dry cloth.be careful though the inside screen is very delicate.
Posted on Feb 21, 2008
SOURCE: Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Posted on Apr 30, 2008
  • 1039 Answers
SOURCE: HD-56G787 JVC HD-ILA Help me clean the mirror!
pop the front strip under frnt of screen off. remove screws around back edge off screen and under the frnt of th screen. Usa a micro fiber cloth to clen screen.
Posted on Apr 25, 2009
SOURCE: green line running vertically along the edge of picture
If its a LCD projection TV (such as Sony Wega, Hitachi, Epson, Philips, and some Panasonic, some Mitsubishi), and the green image is in the whole screen or just one part as a blob or a line. Is most probably that one of your LCD Color Filters is damaged (burned out or starting to get busted), I don’t know if you can just replace the color filter, I believe you need to change the whole light engine system or the optical block. There are some places around, I found some on ebay but you should definitely try on discountdashmerchantdotcom their price range $260.00 - $330.00
Posted on Jun 25, 2009
SOURCE: Lamp and Power lights blinking fast and no picture...
hi mach500..We just had the same problem. Did you find out if it could be the fan?
Thanks
Posted on Aug 28, 2009
JVC HD-52Z575 tv shows only a grey picture screen. I was watching a channel and tried to change channels and new channel won't come up, only grey screen.
JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV
www.amazon.com/JVC-HD-52Z575-HD...HDTV.../B...
Amazon.com, Inc.JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV ... The picture was artifacted and the color was good, but not great. ... From 5' some minor issues could be seen and the MPEG2 format did show its limitations, but at 10', it was a truly great experience! ... There is no true gray temperature, only high and low.
HOW TO FIX A JVC HD BIG SCREEN TV - YouTube
? 6:38
https://www.youtube.com/watch?v=r4v-xzUpQDM
Apr 11, 2012 - Uploaded by kyle dubb
Did your HD D.L.P. t.v. stop working? This movie clip will showyou step by step how to easily fix your big ...Missing: grey
JVC HD-52Z575 HD-ready rear-projection D-ILA monitor ...
Jan 10, 2016 | JVC Televison & Video
JVC HD-56G786 Green Vertical Lines
am thank if you see it in your menu..and on ever channel..you have a bad dmd bord or dmd chip
Dec 24, 2013 | Televison & Video
Vertical jitters on picture - JVC AV48P776
What you are experiancing is loss of High voltage. The line is called a retrace line. It is usally caused by failure of the flyback circuit or aging of the TV tube. This is the single most common failure with CRT based display systems. The high voltage can be tweaked up, to accomidate for the age of the tube. Its a short term solution. Because of the high voltage nature of this circuit, suggest a professional repair.
Jun 29, 2009 | JVC AV48P777 Television
I have a 56" JVC rear projections HD ILA tv.
Turn tv off and unplug it. Take the access door off either side of the tv. Use a dust cleaning tool like a swiffer with an extension (or make one). Clean off lens (most likely the problem). I have the same thing that happens to my JVC 61". You can use a vacuum with extension if your VERY careful.
May 07, 2009 | JVC Televison & Video
I am unable to get the optical out on my tv to work i tried plugging it into my receiver and nothing when i hook it strait to the hd dvr it works but i want the surround from the tv so i can run all of my...
I belive the JVC hd-ila will only output digital audio when you are on a digital source. If you tune a digital channel on antenna or cable, it should work. If this doesn't work check all the settings, you may have a hardware failure. I personally would run the line directly from the hd dvr to the stereo and take out the middle man to keep your signal as true as possible.
Dec 06, 2008 | Televison & Video
TV does not show picture
have you checked the bulb? they do break down. if the bulb is good condition, have it send to a repair man.
Oct 13, 2008 | JVC HD-61FN97 61" Television
JVC 56
thrse television are ila? which i a projection lamp type tv. burn in is internal to optics and will rigure replacment of light engine
Jan 29, 2008 | JVC HD-56G886 56" Rear Projection HDTV
Televison & Video Logo
Top Televison & Video Experts
