Question about Acer Aspire Computers & Internet
Computer syuck in safe mode.
Trying to find out how to get it off safe mode.
  • Acer Master
  • 1,824 Answers
1) If you have made the computer run in the Safe mode, it should automatically shut it down when you restart your computer.
2) If the Restart does not help, then there's a problem with your Windows installation.
I sure hope it's not like in 2 second step! Good Luck!
Posted on Jan 09, 2013
Can't get out of safe. the moment I try I get no picture. Have to go back to safe mode to get to computer. How can I stop safe mode and get back into computer without safe mode
If the computer boots normally, but has no visible picture, but then does have one (a picture, that is) in safe mode, chances are that what has happened is that the resolution or refresh rate of the normal mode exceeds the capability of the monitor, seluting in no picture. In safe mode, the resolution is set at a lower rate. Once in safe mode, check the display settings of the monitor and ensure that they are within specifications for it, then try again.
May 31, 2016 | Lenovo Computers & Internet
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
My notebook will not powerup
Try tapping F8 from a cold start and see if you can start windows in safe-mode. If it is a Windows machine. Please advise if your machine does not use Windows or what happens, as to whether the system starts in safe-mode.
Here is a guide on how to start a Windows computer in safe-mode:
http://windows.microsoft.com/en-gb/windows/start-computer-safe-mode#start-computer-safe-mode=windows-vista
Jan 29, 2014 | Computers & Internet
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Microsoft Windows Vista and Windows 7 users
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
Can't get computer out of safe mode
From Windows Safe Mode click Start / Shutdown and restart the computer. This should start the computer automatically back into Normal Mode.
Note: Many users believe that they are still in Safe Mode because the colors or video may not look correct. Unless in the corners of the screen it says "Safe Mode", you are not in Safe Mode.
If you are rebooting the computer and it is rebooting back into Safe Mode (it does say "Safe Mode" in each of the corners), it is likely another problem exists with Windows preventing it from loading into Normal Windows.
If this does not work try: http://www.computerhope.com/basic.htm
Dec 30, 2009 | Compaq Presario Notebook
Frozen cursor
do you have a wired or wireless mouse?
Have you tried attaching a different mouse to your computer?
What is the brand name of your mouse?
Try booting your computer in Safe Mode. To do this, after turning on the computer, press F8 button several times. You will see a screen that will ask you to boot normally, boot in Safe Mode or boot in Safe Mode with Network Connections. Select Safe Mode.
See if your mouse works then.
Check back with me for further help, if needed. There are additional things you could try.
Oct 08, 2009 | E-Machines eMachines Desktop PC
Window vista is not booting the computer
Try starting in safe mode. If it does boot in safe mode then go to HELP, THEN SYSTEM RESTORE, pick a date before you had these problems. Good luck. You start in safe mode by pressing F8 then selecting SAFE MODE from the menu.
Jul 30, 2009 | Acer Aspire 3680 Laptop
Stop error with windows 2003 can only run my computer on safe mode
Hi
Try to restore windows in safe mode if not ram problem replace it.
Thanks
Mar 16, 2008 | MSI MS-6368 Motherboard
Start up
try starting the computer normally, this usually happens if you computers power was cut while booting up, its just a small harmless glitch.  As for the returning back to the prompt try running it with command prompt. when you get to the command prompt, type (chkdsk) and let it run this might also fix any other problems that you are not seeing.
Jan 09, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Computers & Internet Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
