Question about Syntax S746FX Motherboard
Wont send anything to screen
It sounds like everything is booting up fine i think maybe the mobo is bad because i tried a new video card and nothing changed i also checked current vc with my comp and works fine.. Can anyone help me do i need a new mobo or is there a quick fix? again it boots up but nothing comes on the screen. Thanks tons!
  • 432 Answers
You tried two different video cards and you still don't have any video. But everything else works fine. Have you tried the video cards in other slots? Take out all the other cards, like modem card, etc. If you have two memory chips, take one out. Now try it. If none of this works It maybe the monitor. Make sure it has power to it.
Posted on Jul 01, 2007
6ya staff
SOURCE:
Dell PowerEdge 1600sc server won't boot.
> black screen & flashing cursor ...
Damaged boot-record on the disk-drive???
Was it configured to try to boot from 'A:' ?
Disconnect the hard-drive & CD/DVD drives.
Put a diskette into the drive, and see if it tries to find a boot-record on the diskette.
If it tries, then it has P.O.S.T.'d correctly.
> no beep codes
When it worked, did it beep _once_ when P.O.S.T. completed?
Taking out the RAM _should_ cause some beep codes, i.e., "no RAM".
> anyone?
Replace the monitor?
Replace a dead video-card?
Or, add-in a video-card, and connect a monitor to it, leaving the original monitor connected to the original video-card. One of the two displays should show the P.O.S.T.
Jun 12, 2010 | Dell PowerEdge 1600...
Installed new equipment, now monitor is blank
just dump everything and buy a branded new PC....
u will be increasing ur BP....it;s not worth this much effort....
the kind of work u have done...it seems ur an expert so u urself work it out what's wrong...and where did u make a mistake...
i guess ur CPU and MB are not getting along....some issue with ur integration.....of all parts....
Dec 18, 2009 | Computers & Internet
I have a gateway 383gm its worked fine for the past 4-5 years and the other day i turned it on and the monitor wont come on. I hooked the monitor up to another computer and it powers on fine (so monitor...
Have you already tried removing your memory card stick?If not, then remove the memory and then the pins of it using an eraser of a pencil and then put it back on..,reset again the bios and be sure to connect all the cords correctly of your computer and then power on. Hope this could help you.. Thanks..
Oct 23, 2009 | Gateway 838GM (RB838GM) PC Desktop
Hello, a friend recently brought me a Presario c700 asking me to fix it. When I inspected it, it has occured to me that the entire thing looks completely fine, inside and out, I've checked this thing with...
What I recommend is you remove everything you could possibly remove from the laptop (HDD, mems, cd rom, wifi cards, etc) just to check if it will turn off even when it's not booting or posting. Try turning it on with just the charger and WITHOUT the battery and see if it stays on. If it doesn't, then most likely the mobo itself is the problem.
Oct 06, 2009 | Compaq Presario C700T Notebook
New built, no boot
Glad it's fixed. Please remember to rate my answer. Thanks.
Dec 28, 2008 | Intel Motherboard
Toshiba Qosmio same problem as above.
you need to add new silver thermal paste to the video chip (GPU)... then uncheck both options from your turbo memory console.... that will "unclock" your video card ... and your pc should run smooth
Sep 04, 2008 | Computers & Internet
Led lights on yet nothing on the screen
thats usally bad onbord video card need whole new mobo sad to say sell it on ebay as parts get 200 toward ne woen or replace mobo
Mar 13, 2008 | Computers & Internet
I have a blank screen
so are you asking if there something wrong with your mobo?
if yes, try checking for the jumpers.
Jan 14, 2008 | ASUS P5N32-SLI Deluxe Motherboard
Bios Beeps and no boot
Remove and reinsert the dimms
reseat the video card also
put everything back and try agailn
If this dont work reseat the cpu and repeat steps above
If the above fails to fix
If it will boot into safe mode
and use the standard vga as
you did before and restart
and try to reinstall the drivers
You are sure you installed the rilght
drivers for your OS
It may be that the card is not compatible
wilth your mobo.Try checking compatability list
for your OD
Nov 16, 2007 | ASUS A8N-SLI Deluxe Motherboard
Syntax S746FX Motherboard Logo
70 people viewed this question
Top Syntax Computers & Internet Experts
Ekse
Robert Salgado
Robert Salgado
Eric Sutherland
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
