Question about Exercise & Fitness
Tempo 621T treadmill stuck in incline postion scale is reading 0 but it is not completely down..How to reset my incline button
    Top Expert:
  • 12,223 Answers
Run the software calibration for troubleshooting and fix it. See the next steps. God bless you
The Steps for Newer Style Console Calibration
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Lube the elevation motor, shaft and gear. adjust the POTentiomer,
Tempo 621T treadmill stuck in incline postion scal - 1_9_2013_4_31_43_pm.jpg
Posted on Jan 09, 2013
  • 218 Answers
SOURCE: my treadmill is stuck on
incline motor is bad or needs calibrated, try this
1. remove safety key
2. press and hold the speed+ and stop keys at the same time
3. Put the safety key in/on and release the keys
4. press stop once
5. hit the incline + arrow and let the incline go the whole way up and down
6. remove safety key and try
Posted on Aug 13, 2010
  • 14 Answers
SOURCE: Pro-Form Sport 1000 treadmill does not stop inclining
Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
Posted on Apr 29, 2009
SOURCE: My Proform treadmill will not incline. It is stuck
My proform treadmill is stuck on the highest incline (10) and it doesn't budge from there..Help my workouts are killing me!
Posted on Jun 24, 2009
  • 103 Answers
SOURCE: Image 17.0 treadmill is stuck in incline position
Hello there, The first thing I would try is to calibrate the incline on the unit.
Do this using the following procedure.
With the safety key out, press the stop button along with the speed up button while inserting the safety key onto the unit.
remove your fingers from all buttons, Then press the stop button one time. Now press the incline up button one time.
The unit should go all the way to the top, then return to the bottom.
Remove the safety key and reinsert it to continue using the machine
If this does not work you can manually move the machine to the bottom using this procedure.
Remove the hood cover b removing 2 screws in the rear of the machine and removing the first 2 screws on the foot rails on each side.
You can now lift the cover out of the way.
At this point you will see the incline motor located in the center of the unit pointing in a downward direction.
On the top of the motor there will be a small fan encased inside of a metal cover. There will be a flat head screw located inside the metal frame where the fan is. Rotate this clockwise to lower the unit. (the motor is geared very high it may not seem as though it is moving but it is) be patient that procedure does take a little while.
Any questions please feel free to leave another message on this link.
Good Luck! Tim
Posted on Jan 12, 2010
maxtreadmill
  • 832 Answers
SOURCE: treadmill stuck on highest incline....and motor
If the incline is stuck, it could be a problem as simple as the gearbox on the motor being jammed. Unplug the treadmill remove the motor shroud then remove the incline motor from the treadmill, reconnect the wiring, plug in the treadmill and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
If the incline motor does not move, we need to figure out if the motor is getting voltage. Use a simple multi-meter and set it to AC volts. When you put it into calibration, it tries to calibrate the directions one at a time. Measure across the white and black wires first, then measure across the white and red wires second. If the motor is getting voltage you will read 120VAC (or thereabouts) one one of the measurements. If you have voltage but the motor won't move, you need to replace the motor. . If the incline motor does not move and you have done the voltage test and you do not have any voltage present, there is a problem in the electronics board that supplies the power, you need to replace the board.
Posted on May 17, 2010
Treadmill is stuck in incline postion and can not put down. screen says error
Unplug the treadmill. Remove motor cover . Look for the incline motor, follow the wires coming from the incline motor to the controll board. Starting from the top you will see a red,white and black wire. Under those wires you will see a white and black ( do not remove the lower white and black). Remove the red wire and the black wire . Swap the positions. Plug the treadmill back in and turn with the safty key in place.. The treadmill should go back down. Once it's down . Remove all 3 incline motor wires from the controller. This will get it back down so you can use it. It will still give you the incline err , just press stop to bypass it. As for what is causing the problem , a number of thing can cause this problem. I would call sole and ask for a tech in your area unless you're in NC you could call us. Good luck
Jan 08, 2015 | Sole Fitness F63 Treadmill
My New balance 1500 is stuck at the highest incline postion
Contact manufacturer, sounds like a defect with machine.
May 06, 2014 | New Balance Balance 1500 Treadmill
Tempo 621T treadmill incline Incline reads 0.0 but is not all the way down. How to bring it down.
you must RUN the software calibration, for troubleshooting and fix it.
See the steps.
The Steps fhor Newer Style Console Calibration:
    1. F" appeared in). Troubleshooting the failure would be the next step.
Jan 09, 2013 | Exercise & Fitness
Treadmill power incline stuck in upper postion after power outage
RUN inmediately the software calibration for diagnose, troubleshooting and fix it easy.
God bless you
Jul 11, 2012 | Proform Exercise & Fitness
My Tunturi j800 is stuck in the incline position. Other than that, it works great! How can I get it down? The screen reads that it's at 0% incline.
RUN THE SOFTWARE CALIBRATION FOR DIAGNOSE, TROUBLESHOOTING AND FIX IT.
2) you can lube the gear, shaft+ adjust the potentiometer+see the relais contact are clean it.
sincerely. God bless you
May 02, 2012 | Tunturi Exercise & Fitness
My nordictrack is stuck on a program &wont let u do anything else..cant change the speed or incline &the fans wont turn on..its like the consol is frozen or stuck on a program..how can i reset it...
How to Troubleshoot a Nordic Track C2500 X15616db0-ef56-4f0a-afbd-b1ae3379f47f.small.jpg Jolie Johnson
Based in Austin, Texas, Jolie Johnson has been in the fitness industry for over 12 years and has been writing fitness-related articles since 2008 for various websites. She received her Bachelor of Arts in English and philosophy from the University of Illinois.
By Jolie Johnson, eHow Contributor
updated April 15, 2011
Related Searches:
The NordicTrack is a treadmill designed for in-home use. It offers a speed range of 0 to 10 mph and an incline range of 0 to 10 percent. It folds up vertically to save space when you aren't working out and can be rolled to a different room. The console has 16 preset workout programs and features iFit interactive technology. If you have problems with the console or walking belt, you can often fix them yourself with some basic troubleshooting steps
Instructions
  1. Power Turns Off When You're Using the Treadmill
    • 1 Check the reset switch on the bottom of the treadmill near the power cord. If it has tripped, the top of the switch will protrude. Wait 5 minutes then press the switch.
    • 2 Check that the power cord is plugged in completely. If it is plugged in, unplug it, wait 5 minutes then plug it back in.
    • 3 Remove the magnetic key from the console then reinsert it.
    The Console Won't Turn Off
    • 1 Insert the magnetic key into the console. Your C2500 is stuck in demo mode if the console won't turn off after you remove the magnetic key from the console.
    • 2 Hold the "Stop" button down for a few seconds.
    • 3 Press the "Speed" down (-) button. Remove the magnetic key.
    The Incline Does Not Change Correctly
    • 1 Press and hold the "Stop" and the "Speed" up (+) button. While holding the buttons, insert the key into the console, then release the buttons.
    • 2 Press either the "Incline" up or down arrow button. Wait while the incline raises and lowers. This recalibrates the incline system.
    • 3 Remove the key from the console.
    Walking Belt Slows
    • 1 Unplug your C2500 and remove the key from the console.
    • 2 Turn both rear adjustment bolts, located on the back of the walking deck, to the left, a 1/4 turn.
    • 3 Lift the edge of the walking belt in the middle of the deck. You should be able to lift it 2 to 3 inches off the walking platform. If the belt is still too tight, loosen the bolts another 1/4 turn each.
    • 4 Plug the treadmill in and reinsert the console key. Walk on the belt at a slow speed to see if it still slows. Repeat Step 2 if necessary.
Sep 27, 2011 | Nordic Track NordicTrack Treadmill, A2550
Just bought from store press reset button it lights up but does not display after or start
Make sure the safety key is inserted this engages the power up sequence for the unit to start operating. Also as a simple test try to get the unit into calibration mode by pressing the stop and speed up buttons at the same time while inserting the safety key Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. Press either incline key and the incline will calibrate automatically. BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window). After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
If either attempts fail then call the store where you purchased the treadmill, either have them send a service tech out or exchange theunit.
Jun 26, 2010 | Weslo Cadence Ct 5.8 Treadmill
My health rider treadmill s300se is stuck in the highest incline position. How do i get it level again?
Try putting the key in while holding the down incline button in. This resets the height mechanism. Repeat with the up incline button.
Worked for me.
Aug 11, 2009 | HEALTHRIDER S300SE TREADMILL Drive Motor
Treadmill incline stuck @ steepest level (highest)
MAKE SURE YOU STAND TO THE SIDE OF THE TREADMILL WHILE PERFORMING THIS
1)Connect the wall power to the treadmill
2)Remove the safety key
3)Hold down the red stop button and red increase speed button (this is the red triangle next to the start button)
4)Insert the safety key while holding both buttons down in step3
5)The treadmill will now go into a diagnotstic calibration mode
6)Let go of both buttons in step 3 and press the oval stop button once
7) Now press the up arrow green incline button once(This is located to the left of the yellow program button)
8) Allow the treadmill to go through a calibration cycle, once it completes and stops moving remove the safety key count to 3 and reinsert.
Jan 08, 2009 | Exercise & Fitness
Exercise & Fitness Logo
164 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
