Question about Motorola SURFboard Computers & Internet
Burning plastic smell coming from modems
I have it vent side up, but it still smells funny in the 3' vicinity around it
  • 55 Answers
SOURCE: Strong ''burning plastic'' type smell coming through heating ducts.
it sounds like you have a main air movement system motor that is burning out. it will probably quit on you in the next few days. likely cost to repair from company 375-700 somtimes more if you have a variable speed furnace, in which case you should consider replacing the whole furnace for what it would cost for the motor on one of those.
Posted on Sep 13, 2009
Testimonial: "Spot on. "
  • 3 Answers
SOURCE: LG TROMM DRYER DLE5977 Burning Smell
It is a POS dryer, we have the same one. My suggestion get another dryer. We vacuumed it all out (don't you have a problem with the lint catcher?) Then it started loud pounding noise, which a lot of people seem to have the same problem, then our sensor went out and we had to dry the clothes 5-10 x's...now crack in stainless steel drum and is chewing up all our expensive clothes!
Posted on Dec 31, 2009
  • 674 Answers
SOURCE: the air conditioner smells like burning plastic
The fan motor or some other electrical component. Either way I would quit using it until it gets fixed as an A/C unit is cheaper than a house.
Posted on May 03, 2010
heatman101
  • 43501 Answers
SOURCE: microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 07, 2010
caroldon
  • 17129 Answers
SOURCE: I have a burning smell
Remove the power plug and move your fridge forward. Now look at the rear bottom side of the fridge to see if there are any parts that heats up. You can trace this to the smell emitting from the heated part and confirm. It can be the motor, contactor or the defrost timer.
Posted on Mar 18, 2011
Burning plastic smell when cold out run heater and fan inside car and out
Are you loosing radiator fluid. sometimes the heater core will rupture and you will smell burn odor. also check for strange rubbing sounds or screeching coming from the blower fan motor. or engine exhaust manifolds are hot when car is on, make sure nothing is leaning on them which will cause a burn odor. Any odor coming from outside will find it's way inside through the fresh air vents.
Feb 13, 2016 | Cars & Trucks
Burning smell 2008 aveo coming into vents of my car
You might want to look at all the hot surfaces under the hood. it sounds like something made of plastic is touching something hot.
Feb 03, 2013 | 2008 Chevrolet Aveo
Burning plastic smell from under hood
You will need to check where the liquid is coming from, It may be anything from Air Con, Fuel, Transmission Fluid etc..
The fact you smell burning plastic could be 3 things..
1, Brake pads could smell and burn down if they are on too tight (Had this problem with a trailer). Hence when you apply the brakes it could be squirting brake fluid out due to too much pressure.
- Check brake fluid
2, If the smell and liquid is inside the car (front pass side) it could be the air ducts. Under the dashboard you have air ducts etc for the fans and in car cooling (brother had issue with this)
3, Whatever the fluid is, it could possibly drip onto something hot, unusual for liquid to smell like plastic though, Auto transmission oil smells like fish.
Best bet would be the brakes. Next time you smell it just smell in the wheel mag and see if you can smell it, check the engine fluids often and dont use A/C (Air Con) as that does drip fluid (normal). If it is the brakes smelling you will need to have the lines bled out, tyre places may be able to do this, and possibly new brake pads
Good luck
Oct 20, 2012 | 2007 Suzuki XL-7
Used our humidifier last winter, cleaned it, dryed it, and put it away. took it out to use it and it was a little dusty, so i cleaned and dryed it again, but for some reason it wont work. when you turn the...
If it smells like plastic burning. Stop using it immediately. As there could be an electrical short or overheating of the unit. If doesn't smell like plastic burning, you'll need to be more descriptive of what the odor smells like.
Feb 09, 2011 | Hunter 33201 Humidifier
The tv smells like a burning wire
Can you describe where the odor is coming from. Is it coming out from the side panels on the tv set itself, or perhaps the plug, on end of the main power wire. Check around the electrical outlet. Make sure nothing else is plugged into the same outlet. It sounds as if some of the electrical components on the circuit board are burnt or burning out. Tv may have experienced a power surge, etc. Check also if the power plug is heating up. Be careful and smell around top side vents on tv. Be sure and unplug the set before leaving it unattended if you cannot locate the source of the "burning wire smell."
Jan 22, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
Burnt plastic smell coming from bottom of frig
This is a sign of a short and should be looked at immediately. A smell like that is a sign of something burning. I could be the start relay and start capacitor with overload. But I would not sleep with the possibility of a fire. I will look over your model and see if I can find what this could be, Sea Breeze
Aug 28, 2009 | GE Refrigerators
Plastic burning smell coming from bottom front vents.
u may need to unplug it then tip it enough to see under it to see if maybe a mouse chewed on some wires and try to rewire or electic tape on some bare wires
Mar 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice tastes funny and a strange metallic or plastic type smell
Sometimes the smell comes from something in the freezer or even the refrigeratior and makes the ice taste funny. My suggestion is to clean out the freezer compartment of anything frozen that has been there a while and may have freezer burn. That may be the funny smell you are experiencing.
Hope this will help you.
Jan 15, 2009 | KitchenAid KSRS25IL Side by Side...
Brand new Whirlpool Duet Sport gas dryer & burning plastic smell
I would consult the place of purchase. If they do not stand behind the product, then get the manufacturers support #. They will stand behind their product, especially if it is a possible fire hazard. THe smell you are smelling could be anything, but without being there and taking off the cover and doing a visual check. it's hard to dianose. It is possible that something that is plastic has fallen out of a pocket and gotten inside the unit while it was drying clothes and fallen onto the igniter housing.
Nov 18, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Computers & Internet Logo
52 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
