Question about Maytag PAV2300 Top Load Washer
I believe there is a silver chain necklace stuck in the motor and now the machine won't spin! Is it worth fixing??? How much do you think it would cost for the maytag repairman to fix? Approximate is fine....
  • rosemarie265 Jan 22, 2009
    Thanks for your help!!!!!! I appreciate your time.
  • 61 Answers
I would say it would defantly be worth looking at if it just something stuk in the pump or motor and no parts are needed it would be worth the repair if it needs a part the repair man should let you know how much the part is and you can compair that to the price of a new machine they start around 300 -350 a service call have the machine checked could run between 50 - 100 don't know what people charch where you are
Posted on Jan 21, 2009
Where can I get the best quality of chokers?
The choker is a close fitting necklace which is worn around the neck. It can be made of a variety of materials, including velvet plastic, beads, metal, leather such as silver, gold or platinum, etc.
I can suggest you the name of some of the best chokers :
1) Black Daisy Flower Lace Choker Necklace
2) Black Imitation Leather Choker Necklace
3) Black Velvet Stripes Retro Choker Necklace
4) Delicate White Lace Wedding Chain Choker
5) Double Leather Strap Choker Necklace
6) Double Leather Choker Necklace
You can buy best choker necklace online. All of the above chokers are available online, you can easily get it from there
Sep 04, 2017 | Pets - Others
Kitchenaid KAWS700G will fill and wash but won't drain and spin
My washer also did not drain. I disconnected the power supply and water hoses and the drain hose and lay the machine on its side.. The motor is at the bottom. Once I disconnected the hose and put my finger to look inside. There is a rubber stopper and once I moved that aside and looked inside I found my baby sock stuck in the the pump. Once I gently pulled the sock out It came out easily. Lucky me the motor is in working condition.
My washing machine was manufactured I believe in 1997.
This is the first time ever took look under any washing machine.
Best of luck!
Apr 15, 2013 | KitchenAid Washing Machines
I have a Kemnore 90 series washer that wont spin the water pumped out, the motor spins but the agitator won't spin. My question would be is it worth fixing?
Hello, Thats sounds like a broken motor coulpler,when its broke it will sound as if its agaitating/spinning yet it doesn't. The coupler is fairly easy to replace and this video will show you to replace it. The part number fot the coupler is 285753A it could be picked up from your local appliance parts store for no more that $20.00 or you could order it online from; assuredparts.com apdepot.com appliancepartspros.com searspartsdirect.com repairclinic.com Gene
Aug 08, 2011 | Kenmore Washing Machines
I have a necklace chain stuck between the washplate and the basket, how do i remove the washplate?
Remove the fabric softener on top of agitator and plastic insert. Use socket wrench to remove hex bolt and lift top half and then bottom half of agitator which should then expose chain.
Feb 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My daughter's necklace is stuck in the drum of my bosch nexxt 500 washer
the drum may have to be removed and taken apart in order to get the necklace out.or the chain may have to be broken and the rest ran down to the drain pump for removal
May 18, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Everything works-no spin-motor sounds like it won't engage
this is a whirpool style direct drive. most likely coupler is broken. it's a small part, between motor and gearcase about as big around as a silver dollar but thicker. lean the washer back so you can look under it and look right behind the motor. not a major repair. worth fixing. You will want to remove the cabinet so if you decide to do it mssg back for more info.
May 24, 2009 | Roper RAX4232KQ Top Load Washer
Washer won't spin!
I doubt if that would affect it unless you got the chain between the inner and outer tub. The pump might have a coin in it. Tip the washer back,remove the belt and turn the pump by hand to see if it is locked up.
Jan 21, 2009 | Maytag PAV2300 Top Load Washer
Necklace stuck in washer
Hold the bottom part of the Agitator,(The part that you are talking about),Undo the very top part in an anti-clockwise direction and it will come right off.Use a wrench to remove the nut on the top of the agitator and then lift it right out,you may need to move it from right to left.You will now be able to remove the necklace.Replace the Agitator the reverse of removal.
DW
Oct 18, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Daughters necklace caught in washing bin holes
If you cut the chain what is left could possible work its way into drain pump. Jamming it.
Jul 20, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
75 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
