Question about HP LaserJet 5550 Printer
How to replace the FM1 fan on a HP 5550DTN Laser printer
4 Suggested Answers
  • 2072 Answers
SOURCE: Laser Jet 5550DTN printing problem
I am reading your question and coming up with 2 different thoughts.
Are you wanting multiple prints of one page, or are you wanting to print out a 5 or 10 page document?
I am not sure how to answer.
Posted on Mar 01, 2008
wheatlandsvc
  • 1110 Answers
SOURCE: HP Laserjet 5550dtn printer is
This code means there is a Cyan Cartridge motor error. The most common cause of this error is the Cyan Toner/Drum cartridge is binding up and causing the motor to stop turning. I would try removing then re-installing the Cyan cartridge first and see if it goes away. If not then replace the Cyan cartridge with a new cartridge. If the problem persists then there is a problem with the drive assembly for the Cyan cartridge.
Good Luck and Thank You for using Fixya.
Posted on Sep 03, 2010
SOURCE: what is the replacement printer for HP Laser Jet
red singnal balink
Posted on Jul 09, 2011
My printer hp color laserjet displays a printer error 57.07 i need to a process to clear the code
Try looking up that specific error code and it should tell you what you need to do.
Dec 28, 2014 | HP Color Laserjet 5550 5550n 5550dn...
HP Partsufer
Tech guys only.. Remove rare,side,top covers, rare metal sheet cover, you can see the Low vol power supply, check input 220V/110V(depends power standards) fuse. If fuse burnt check primary section is there any component failed? replace same rated fuse the try it.. if successful no issue, if fuse burnt repeats replace "Power Supply".
If fuse burnt after fuser drive starts, replace another fuser then try it. (faulty fuser also one of the cause to fuse burnt)
Jul 11, 2012 | HP Color Laserjet 5550dtn Printer Laserjet...
Where to get manual of laser jet 555
Service manual here
User manual will be at HP.com
Jul 30, 2011 | HP LaserJet 5550dtn Printer
Could you please show me the scanner motor for hp laser jet 2420.
Figure 7-14. ECU wiring
1 FM1, main fan motor (J509)
2 Tray 1 pickup solenoid (J508)
3 Tray 1 sensor (J503)
4 Laser/scanner motor (J402)
5 Memory tag reader (J510)
6 Fuser motor (J501)
7 Main motor (J407)
8 Door switch (J408)
9 FM2, sub fan motor (J512)
10 Thermistors, rear-output-bin sensor, delivery sensor (J405)
Jul 03, 2011 | HP LaserJet 2420 Printer
Gettining error 57.03 in hp laserjet 5200 printer
57.x FAN FAILURE CALL SERVICE Control Panel Message 57.x FAN FAILURE CALL SERVICE Event Log Error Service Messages: 57.01.00 57.02.00 57.03.00 57.04.00 Required Action
  1. A fan motor failure occurred. All fans are enabled to low speed operation at printer power-on. Fans will go into high-speed operation during the print cycle. All fans are disabled during PowerSave Mode.
    • x = 1: FM1 (Laser/Scanner Fan)
    • x = 2: FM2 (Power Supply Cooling Fan)
    • x = 3: FM3 (Formatter Fan)
    • x = 4: FM4 (Face Down Deliver Fan)
  2. Cycle power. It the message continues, check and reseat cabling between the fan motor(s) and the DC Controller PCA.
    • Fan 1 J208
    • Fan 2 J216
    • Fan 3 J210
    • Fan 4 J225
  3. Replace the faulty fan motor.
Dec 22, 2010 | HP Office Equipment & Supplies
LaserJet 5550dtn Printer: blows mains fuse and power supply board fuse and b...
The fuse blows all time on High Voltage Poewr Supply, on HP Color Laserjet 5550dn,
May 16, 2010 | HP LaserJet 5550dtn Printer
57.03 error
    • Fan 1 J208
    • Fan 2 J216
    • Fan 3 J210
    • Fan 4 J225
Aug 20, 2009 | HP Media Center m7250n (ED842AA) PC...
Yellow toner not being recognized with new toner installed
Probably dirty contacts on side of cart. Also if you take out drum and cart unit together, clean copper contacts with alcohol and cotton bud, also make sure in machine where they contact is clean
May 01, 2009 | HP Color LaserJet 5550dn Q3715A Workgroup...
Feb 29, 2008 | HP LaserJet 5550dtn Printer
HP LaserJet 5550 Printer Logo
44 people viewed this question
Seeker5211
Seeker5211
