Question about DISH Network ViP622 DVR DTV Receiver / 180-Hours Video Recorder
People are blue on my dish network
My satellite got unplugged.  When I tried to plug everything back in the people on the screen are blue.  The other colors seem fine and the second television's screen is fine (it is hooked to the same receiver).   I don't think that I altered the colors on the television.  Did I plug a cord in wrong?
    Problem Solver:
  • 12 Answers
Most likely you are connected to your TV via component video (green, blue, and red). The first thing I would check is the red cable making sure it is plugged in all the way to both the TV as well as the sat rcvr.
Posted on Jan 21, 2009
I have Dish 322 receiver. Everything was fine; a week or so ago satellite 119 reception was spotty, now we can't get 119 at all. We get 110 but only about 34%. Sometimes the receiver will power itself off...
hartpark
It looks like you have lost the signal for the 119 satellite from your dish. Are you getting an error message, either 002 or 015, saying the satellite signal has been lost or acquiring satellite signal? First, check the cables on the back of the receiver to make sure they are secure. You can also run a check switch test to see if there is a problem between your dish and receiver.
Press the Menu button on your remote. This will bring up the Main Menu on your TV screen. Input the numbers: 6 (System Setup), 1 (Installation), and 1 (Point Dish). On the right side of the Point Dish screen are 3 buttons. Select the Check Switch button. Within the 2 large boxes are satellite numbers and green or red boxes. Make a note of the satellite numbers (should be 119, 110), the trans, the device, and switch. Super dish and alternate should not be checked. Select the Test button on the bottom of the screen. If a box pops up with a warning about TV 2, select Yes. It will now run the check switch test. Let it complete the test. After completion, the screen will automatically go back to the Installation Summary screen. You may get a message stating that the Check Switch test has found fewer satellites than previously detected. If you get this message cancel out of each screen (do not save the results) till you are back to the TV screen and it is acquiring Satellite signal.
If you don't get that error message, see if the information on the Installation Summary has changed. Then select Done on the next 2 screens and cancel out of the others till you get the message, Acquiring Satellite Signal. After it finishes acquiring satellite signal and downloads the program guide, see if you are getting a picture - try different channels. If you still have problems, please email me at, ray.calo@dishnetwork.com. If you are still experiencing problems, we will need to send a technician to fix the problem.
Ray Calo
DISH Network
Apr 23, 2011 | DISH Network 322 DTV Receiver
Can't get EPG to display after set up
johnandja460
You haven't specified which type equipment you are experiencing the problem. With our DISH Network receivers, if the EPG does not display you can do 1 of 2 things. First, unplug the receiver from the electrical outlet for 10 seconds and plug back in. This causes the receiver to reboot and re-acquire satellite signal. Then it will download the EPG.
If you still don't have the EPG, you can then run a check switch test. Press the Menu button on the remote. Main Menu will display on the TV screen. Press 6 (System Setup), 1 (Installation), and 1 (Point Dish) on the number pad. Highlight the Check Switch button on the right of the screen and press select. On the Installation Summary screen, highlight the Test button on the bottom left. Press select. The receiver will perform a switch installation check. After the test is completed, exit out of all screens till you are back to the TV screen. The receiver will acquire satellite signal and download the EPG. I hope this helps.
Ray Calo
DISH Network
Jan 19, 2011 | Sony Televison & Video
When my dish network satellite box automatically switched channels to record a scheduled TV show recording, the channel switched and when it did only the top dislay of what channel it was on came up and...
Hello! This is what we call a black screen with banner. If you unplug the receiver for ten seconds this will reset the receiver and should correct this.
Daniel Busa
DISH Network Customer Service
Jan 13, 2011 | Olevia 742I 42 in. LCD TV
Had a power outage and when the power came back i got message 015 on tv it gose to progress 3 stay there for little then gose black then comes back when the same message then does the same thimg over...
Hello, my name is Matthew Gonzales with DISH Network customer service. If you are still having this issue there are a couple things you can try if you have not. First, unplug the receiver from the power outlet it is connected to, leave it unplugged for about 20 seconds, then plug it back in. Your receiver goes through a rebooting process which takes about 5 minutes. Another thing to check is making sure that all of the "satellite in" connections are hand tight from the back of the receiver to the wall. The next thing to try is a check switch test. To do a check switch test, you press menu on your DISH remote, then press the numbers 6-1-1, (system setup-installation-point dish) you should be on the point dish screen. Go up and select "check switch" on the right-hand side, on the installation summary, select "test" at the bottom. The receiver will do some tests, if you get a warning 836 at the end, select "cancel" on the warning. Cancel out of all the menus and once again you will let your receiver reacquire the signal, and see if the problem persists. If problems do continue, a technician will be needed at the home to correct the problem. I hope this helps, but if you are still having this issue, please email me at matthew.gonzales@dishnetwork.com so we can get everything back up and running.
Dec 21, 2010 | DISH Network ViP 612
Does not allow me to record a live tv showit says: error: unable to aquire program guide information what can i do to record it?
Guest,
Are you still having problems recording live TV shows? You can try unplugging the receiver from the power outlet for 10 seconds and plug back in. This will make the receiver reboot and then acquire satellite signal. Once the acquisition is complete, a program guide download will take place. Allow the download and see if the receiver will allow you to record.
If it doesn't, then run a check switch test. Press your menu button to bring up the main menu. Press 6, 1, and 1 on the remote which will take you to the Point Dish screen. Upper right hand corner of TV screen is a button, "Check Switch". Maneuver to that button and select. You will now be at the "Installation Summary" screen. At the bottom of screen, select "Test" button. Allow the test to run. After completing, it will automatically take you back to installation summary screen. Check for any errors windows. Exit completely out of all menus till you are back to "Acquiring Satellite Signal". Allow program guide download after acquisition, then check if you can record.
I hope this helps.
Ray Calo
DISH Network
Jul 15, 2010 | DISH Network DVR-625 DTV Receiver /...
I can't pause or rewind my moveie
fktrejo,
When you try to use the DVR features, do you get an error message (024 or 311)? Have you unplugged your 625 receiver yet? If not, unplugged the receiver for about 10 seconds and plug back in. This will cause the receiver to reboot and acquire satellite signal. When the picture comes back on, try to pause. If it still doesn't work, we may need to replace the 625 receiver. I hope this helps.
Ray Calo
DISH Network
Jun 28, 2010 | DISH Network DVR-625 DTV Receiver /...
Only green light on
shanonl,
If the lights will not turn on, try unplugging the receiver from the electrical outlet for about 10 seconds. Plug the receiver back in, which will make the receiver reboot and re-acquire satellite signal. If the receiver does not turn back on, at least the green and amber lights on, we may need to replace the receiver.
Ray Calo
DISH Network
May 15, 2010 | DISH Network DVR-625 DTV Receiver /...
We have a black screen with no audio. We are able to pull up the guide, but we can't watch tv or anything recorded on the DVR. How do we fix it?
No fatal error, try this. If you would, please unplug the receiver from the power outlet for about 2 minutes. After 2 minutes, plug it back in and let me know when it comes on (it will do this by itself). Once it does, it should be showing Message 015, “Acquiring Satellite Signal”.
http://tech.dishnetwork.com/departmental_content/TechPortal/index.shtml
Oct 10, 2009 | DISH Network 322 DTV Receiver
Dish program guide
this is a problem dish network is aware of and trying to fix, 311 receiver??
Aug 02, 2008 | DISH Network IR Remote Control
Dish Network - Dish 500 Satellite 110 is not being recognized
chances are that you have only lined up the dish to pick up one satellite. there are several satellites up there for dish and its easy to miss the ones that you need. try to line up the dish keeping this in mind. if that doesn't work, write back.
Apr 30, 2008 | Televison & Video
DISH Network ViP622 DVR  DTV Receiver / 180-Hours Video Recorder Logo
145 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
