Question about Franklin FWC100 Wine Cooler
Franklin Chef model FWC100 is pooling water at the bottom of the wine cooling space. What could cause that?
Had the unit about 10 years, always worked fine, but lately has been accumulating water. Is there a filter to be cleaned? Could a condenser be frozen? Thanks
4 Suggested Answers
  • 87 Answers
SOURCE: Replacement Parts
Would suggest you try a distributor for this cabinet as sometimes they have more leeway with the supplier. Looking through sites would suggest someone like BeverageFactoy.com may have a route to the spares youre after. Hope this helps.
Posted on Feb 08, 2008
22yooper
  • 828 Answers
SOURCE: Franklin Chef FIM120 Ice Maker
http://www.tapplastics.com/shop/product.php?pid=12
If the damage is limited you can repair it by patching with a Epoxy such as you will find at the above URL.
Posted on Jul 01, 2008
SOURCE: The alarm in our Franklin Chef model FWC100 wine
Love this machine. Works great. Have had it for 6 years. Now it has a problem. The lights and fan work, and the temperature settings work. It behaves like either the freon is low (I don't hear the compressor starting), or whatever causes the compressor to start is crippled... Fuse looks good, nothing visibly burned on the motherboard, haven't opened the bottom.
Posted on Feb 03, 2013
My frigidaire air conditioner is making my apartment feel damp and when i took my filter out to clean it that part was damp too! What do I do to fix this?
You may have a clogged drain or the unit is installed without enough angle pitch for the water to drain to the back of the unit toward the outdoor section of the unit. I'm assuming it's a window air conditioner? The moisture condenses on the cooling coil near the filter and should drip down into a condensate drain pan, then the water should drain to the back of the unit into a pan at the condenser coil fan that is rejecting the heat outside. The fan blade usually has a ring on the outdoor fan that pick up the condensate moisture the fling accumulated water onto the hot condenser coil to evaporate it. Also the filter should not be touching the cooling coil. Make sure it in the correct slot. Some a/c cooling coil require a wetting agent that allow the water to slide down the coil and not pull off of the coil into the indoor circulating fan.
Sep 11, 2015 | Frigidaire Heating & Cooling
Doesn't cool
You have troubleshot this thing well. You may have a capacitor problem or starter problem. It will not be design let the unit come on. This is all to protect the expensive compressor.
Feb 03, 2013 | Franklin FWC100 Wine Cooler
The alarm in our Franklin Chef model FWC100 wine cooler keeps going off even though everything stays cool so we want to know how to turn off the alarm or cut the wire to the alarm. Thanks.
Jul 29, 2011 | Franklin FWC100 Wine Cooler
Dehumidifier runs but no water accumulates in the bin and I cannot control the humidity level
Mimi, there are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2. But, before you do any of the things listed below, turn the Master ON/OFF Switch to OFF & Unplug the unit and wait 10 minutes, before going thru steps 2 thru 5.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helped you.
Jul 06, 2011 | Goldstar DH504EL Dehumidifier
Kenmore dehumidifier 54701 runs but very little water accumulates in tank. It is 3 years old. It used to take out at least a tank of water every day.
There are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a Manually
Controlled unit (no LED screen) turn the humidity extraction knob to Maximum.
level
in basement applications . Raising the unit up off the floor,
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helped you to troubleshoot and solve the problem.
Jun 30, 2011 | Kenmore 54701 Dehumidifier
I have 4 ton carrier heat pump / puron. It is a new system been installed about 3 months. Live near Dallas Texas and lately the temp has dropped into the low 40's at night. The heat seems too be working...
The water is from humidity in the outdoor air which has condensed and then frozen to your heat pump outdoor coil. The heat pump will defrost occassionally, depending on how much frost has accumulated to the coil and will then generally drip off the unit and onto the ground. This is normal. To keep the water off the drive way may mean having to move the heat pump to a place where the condensation can run away from the drive area. Or provide some other means of redirecting the water.
Nov 20, 2010 | Heating & Cooling
Franklin FWC100 Wine Cooler Logo
Top Franklin Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Franklin Furniture Expert? Answer questions, earn points and help others
