Question about Measuring Tools & Sensors
How do you make a delta 62-042 electric motor run clockwise
It runs counter clockwise and I need it to go in reverse
    Problem Solver:
  • 5 Answers
Try running the wire reverse polarity i know this use to work on older items like clocks
Posted on Jan 09, 2013
23hr. kohler starter shaft runs clock wise. should run counter clockwise
Check the battery connections. Engine will not run backwards.
Most of the components are electrical and will operate on reverse voltage. The battery charger off of the fly wheel would not like the battery to be reversed.
Mower always have a negitive ground. Only older John Deere tractors have a positive ground.
Hope this helps?
Apr 14, 2016 | Garden
Why does fan run clockwise but not counter clockwise?
Should be a reverse switch on the fan. What make/model of fan do you have & how do you change speeds? (wall switch,remote or pull chain)
Aug 23, 2015 | Dryers
The drive stud on my vitamix 3600 blender sheared off. When screw is replaced it comes unscrewed when the blender is turned on. Does anyone know if the original design included epoxy weld?
If the motor runs in reverse to an Oster which uses counter clockwise thread then it follows that your thread should not be counter clockwise. If it comes loose when you turn it on surely the thread on the coupling must be faulty because according to your description the action of turning it on can only be to tighten the coupling. Most couplings with a thread that I have seen are counter clockwise so you will probably struggle to find another brand coupling to match.
Feb 28, 2015 | Vitamix Blenders
Whirlpool dryer awz 121 only tumbles counter clockwise. This is a dryer that briefly reverses direction, so the only tumbling is when it reverses. The rest of the time, the dryer makes a noise but d
You may want to contact a professional that will have the diagrams for your machine online. there are some here or you can go to another site. like (Just answer.) Be more specific about your problem. It can be fixed . There's no worries.
Are you saying that it does not heat up either ?In addition with not tumbling clockwise ?
Disconnect the dryer first. You can remove the top and front of the dryer to check to see what is happening. If it does not heat . You may need to replace the temperature control relay. If that does not work , the heating elements themselves may need to be replaced.
For the tumbling problem, they also have relay switches that go out.
BUT, if it is tumbling to one side and keeps tumbling then that will probably be enough to dry your clothes. As long as it is not too heavily loaded.
Mar 19, 2014 | Whirlpool Dryers
My fan in turning counter clockwise and there is no switch to reverse it, what can I do?
You need to check what sort of motor it is. Some motors will not go the other way around.
Aug 02, 2017 | Westinghouse 78127 Industrial Ceiling Fan
Just purchased an AO Smith condenser fan motor, installed it but it runs counter clockwise, how do i reverse it to run clockwise?
Hi, this is very easy to do. On the back end of the motor you will see a pair of wires plugged in to each other. Kill the power and just unplug and reverse these wires. This will reverse the rotation of the condenser fan motor. If you have no wires, check for an arrow on the motor housing. It will only go one way if there is one, and you will need to take it back. 2 pair of wires...., just reverse them very easy. Tie or tape them away from the blade.
Mar 19, 2012 | Heating & Cooling
Brand new delta roman tub faucet. Cold works great and hot side is anemic. All new pex tubing feeds it. When I got it out of box both faucets worked counter clock wise to open hot was anemic then. I pulled...
Cna you remove water line feeding hot side to make sure it has correct flow. It could have something blocking inside of water line. And check hot inlet side on faucet to make sure it is open and not blocked.
Remove line you can run water in a bucket to ensure that hot side water line has no blockage in it and have someone help you with turning water off and on for you.
Jul 31, 2011 | Delta Plumbing
HOW DOES A DC PERMANENT MAGNET MOTOR WORKS HOW DOES THE SPEED IS CONTROLED AND HOW THE DIRECTION IS CHANGED BY USING CHOPERCONTROLS AND WHERE DO WE GET CHOPER CONTROLS FOR EXAMPLE A DC PERMANENT...
a dc motor runs by voltage the higher the voltage the faster it spins, reversing the power and ground makes the moter fon either clockwise or counter-clockwise i hope this helps if you need more help get bak to me. also must have enough amperage to run the motor, Thanks Ray
Mar 05, 2011 | 2000 Volvo V40
Measuring Tools & Sensors Logo
104 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
